1 Reply Latest reply on Jul 28, 2017 11:16 AM by Captiv8r
    Workflow
    bonellij
      Does RoboHelp do the following
      Support workflow visual displayWorkflow graphic display showing a work stream with its related steps
      Support workflow definitionWorkflow definition: workflow stream and associated workflow steps
      Association of workflow steps with knowledge management content elementsLinking of a workflow step to one, or more, knowledge management elements (text, image, video, and documents)
      Thank you!
        • 1. Re: Workflow
          Hi there
          This can be accomplished, sure. But it will require other tools. RoboHelp does offer a screen capture utility called RoboScreen Capture. But it's a manual thing. You would have to build the images, then insert them into RoboHelp.
          Sorry, but this one needs more information before anything resembling a cohesive answer can be given. You need to explain that question in more detail.
          Definitely possible to achieve using RoboHelp.
          Hopefully this helps... Rick
