1 Reply Latest reply on Aug 1, 2017 9:45 AM by kerrishotts
    Preferences not working
    ENDRNL
      Hey everyone,
      I'm just learning how to work with phonegap, but I've run into a rather annoying problem.
      I've tried adding some preferences (fullscreen and orientation) the config.xml, but neither seem to work. Here is the code:
      <?xml version="1.0" encoding="UTF-8" ?>
      <widget xmlns   = "http://www.w3.org/ns/widgets"
          xmlns:gap   = "http://phonegap.com/ns/1.0"
          id          = "com.phonegap.example"
          versionCode = "10"
          version     = "1.0.1" >
      <!-- versionCode is optional and Android only -->
        <name>app</name>
        <description>
            An example for phonegap build docs.
        </description>
        <author href="https://build.phonegap.com" email="support@phonegap.com">
            Name
        </author>
        <preference name="orientation" value="portrait" />
        <preference name="fullscreen" value="true" />
      </widget>
      I've tested the app with an Android 4.2.2 and the Chrome Mobile device simulator.
      How do I fix this? The app looks really weird in landscape mode.
        • 1. Re: Preferences not working
          kerrishotts Adobe Employee
          Only when you build your app via PhoneGap will it read preferences from config.xml. Chrome will not do so. If you're using the PhoneGap Developer app, it also won't read config.xml. (You have to build either with PhoneGap Build or your local PhoneGap CLI)
          Also, 4.2.2 is pretty old and doesn't support a lot of modern web features. Expect lots of odd glitches if you aren't writing CSS, HTML, and JS that it will understand. I would suggest targeting 5+ if you can.
