Hey gang.
1st time poster, long time user. (i am using the newest CC with an I7 MBP)
my issue, Ive seen many similar posts.. Namely these:
Adjustment Layer, Keyframes, and the Rate Stretch Tool
Adjustment Layer: Keyframes don't work
Problem Adjustment Layer PP CS6
but stretch is not really my concern
Im trying to do something as simple as a ramp up or down, either in Opacity, or effect range within an adjustment layer.
In the past, to say create a white washout to go along with a musical creshendo, Id add a white color matte, blend mode it, and keyframe it 0-100
I wanted to start using the adjustment layer to do this because certain effects really wont sweep evenly over a few dozen 1/2 second clips for the desired
tension and effect Im trying to create...
to be clear after trying it initially with effects like glow and solarize, I dumbed down my efforts and tried to just get a simple opacity 100 - 0 with a brightness filter
(remember im sliding this AL over dozens of tiny clips, so doing individual keyframes right on the file isnt an option)
heres how it goes down.
create adjustment layer
put above desired file on the time line
test effect with paramenter slider. yes
set 0 point with key frame button and parameter at 0
move playhead to end of AL and slide parameter to 100..... nothing
doing it in reverse (setting the 100 first and working backwards) you can see as soon as you hit the keyframe button the functionality of all
the parameter sliders; both for the single effect , and the AL have shut down (despite seeing the actual keyframes displayed)
I was able to get this functionality to work on the same project with the Gaussian Blur though
