8 Replies Latest reply on Aug 11, 2017 3:58 AM by JackMyth
    Camera doesn't Work
    JackMyth Level 1
      I want to use this software,but the camera doesn't work.
      here is the screenshot:
      I'm using Notebook computer.This camera is the built-in camera.
      I reinstall the software and graphics driver. but this issue still happen.
      what should I do?
        • 1. Re: Camera doesn't Work
          oksamurai Employee Moderator
          Hmm that's a new one to me - my best guess is there's something with the camera that isn't supported. What type of notebook is it? Do you have any specs on what type of camera it is as well?
          • 2. Re: Camera doesn't Work
            JackMyth Level 1
            My notebook is Acer Predator G9-791 .In my memory my camera can work with a previous version.
            About the camera....I don't know anything about it.
            All software can work with the camera except Character Animator.Character Animator can detect the camera but can not get any image.
            • 3. Re: Camera doesn't Work
              Jeff Almasol Adobe Employee
              Do you have another application that's currently using the webcam (e.g., Skype, video capture device, etc.) at the time you launch Character Animator? Contention with another application that wants to use the webcam might be a possible cause. Try quitting other applications including ones that might be running in the background that might use the webcam, then restarting Character Animator to see if that helps.
              • 4. Re: Camera doesn't Work
                JackMyth Level 1
                Thanks For Your help , but it doesn't work . I'm sure there are no application using this camera. My camera have a LED. if camera is being used it will light. So I'm sure the camera is not  being used  when I open character Animator .
                • 5. Re: Camera doesn't Work
                  Is this a built-in webcam or one connected via USB?
                  If you use the Switch to Next Camera or Switch to Default Camera commands in the Camera & Microphone panel's menu (the three lines next to the panel's title), does it show any notification about switching cameras?
                  • 6. Re: Camera doesn't Work
                    JackMyth Level 1
                    It is a built-in webcam.
                    I use Switch to Next Camera command,It says Only Detected one camera.Use Switch to default camera command and it says switch to camera 1,but still can not get any image.
                    • 7. Re: Camera doesn't Work
                      Hmm, strange. If you do have another application (Skype, etc.) using the webcam, then launch Character Animator, do you see a message in that panel that says "Camera busy"?
                      I'm assuming you don't have a spare USB webcam available for testing to see if it's just that specific model of built-in webcam?
                      • 8. Re: Camera doesn't Work
                        JackMyth Level 1
                        if I open “Camera” Application first, I can see image in it.But when I open Character Animator, I don't see the "Camera busy" Message.
                        if i open Character Animator First,I can not see any image.When I open "Camera" Application,"Camera Application" Give me "Camera busy" message.
                        I don't have spare USB webcam,so I install a virtual camera and it works fine.
                        I will try to find a previous version and see if it can work with my camera.
