5 Replies Latest reply on Aug 3, 2017 7:16 AM by ericsten
    Offset effect has different behavior with LoopOut expression than expected?
    Coresmith Level 1
      Im trying to use LoopOut("continue") expression on the Offset effect, AE 2017.
      The problem is that it seams the continue loop has some relation with the Comp size vs the Layer Size.
      If ratio is the same the offset effect continues at the same speed, If ratio is smaller or bigger the speed is smaller
      or bigger respectively.
      Does any one has a solution?
      Thank you
