4 Replies Latest reply on Jun 30, 2008 6:04 AM by LDJessee
    Regular Expression Help
    LDJessee
      Hello,
      I am trying to validate an input field using Regular Expression. I have gotten regexp to work great for me in the past, including things like dates, email addresses and such, but this one is kicking my butt.
      From what I have read, this pattern should work:
      [CGNPRST][AELMNUS][1-6]?[A-Z0-9]{2,2}
      (4 or 5 characters, with the middle 1-6 optional)
      This should match items like:
      CL01
      CL0F
      SS0F
      SM20
      SMTU
      TE11
      PA3IT
      PACH
      And should not match:
      PA9IT
      PAIT9
      I thought the question mark made the previous character optional (match 0 or 1 time).
      If I take the ? out, then I can get PA3IT to work and PA9IT does not, but neither does PACH or SS0F.
      Any suggestions?
      Doug Jessee
      (At CFUnited 2008 I learned too much, now I have to change everything.)
        • 1. Re: Regular Expression Help
          BKBK Adobe Community Professional & MVP
          ... should not match:
          PA9IT
          PAIT9
          It doesn't. It matches PA9I and PAIT, but not PA9IT or PAIT9.
          It also matches PA3IT, PACH and SS0F, as you require.
          • 2. Re: Regular Expression Help
            Did you once use {2,3} in place of {2,2}? Just a thought.
            • 3. Re: Regular Expression Help
              LDJessee Level 1
              Hello and thanks for responding.
              I did not use {2,3}.
              What I am trying to get to work is a Regular Expression that matches the items in 'should' and not match the 'should not'.
              I have tried several variations, but from what I have read, the regular expression I included should match those patterns. In actual usage, it does not, atleast not in ColdFusion v7.0.2.
              The regular expression I included will correctly match things like PA3IT, but will also match things I dont want it to, like PA9IT. It also does not match things like SS0F.
              I say it does or does not work from actually trying it on a coldfusion server.
              Any help or suggestions as to changing the regular expression would be greatly appreciated.
              LDJ
              • 4. Re: Regular Expression Help
                LDJessee Level 1
                A former coworker figured it out.
                I simply needed to put boundaries at the beginning and end.
                ^[CGNPRST][AELMNUS][1-6]?[A-Z0-9]{2,2}$
                By simply adding the carrot (^) and dollar sign ($), it works as expected.
                LDJ
