• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Remove unused paragraph styles while keeping in mind based on styles
New Here ,
Jul 31, 2017 Jul 31, 2017
i was trying to remove unused paragraph styles the same way as indesign do it while keeping in mind the basedon property but it is still not working properly
here is my code and i dont know the problem
var myParStyles = app.activeDocument.paragraphStyles;
var flag = true;
for (i = myParStyles.length-1; i >= 2; i--){
   app.findTextPreferences = app.changeTextPreferences = NothingEnum.nothing;
   app.findTextPreferences.appliedParagraphStyle = myParStyles
   var myFoundStyles = app.activeDocument.findText();
   if (myFoundStyles == 0) {
for (x = myParStyles.length-1; x >= 2; x--){
if (myParStyles.basedOn.name == myParStyles.name) {
var myFoundStyles1 = app.activeDocument.findText();
if (myFoundStyles1 == 0) {myParStyles.remove();}
flag = false; break;}}
if (flag) {myParStyles.remove();}}}
alert("Done");
Views
703
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee , Jul 31, 2017 Jul 31, 2017
I made the below script in a hurry and did not test extensively, but it works for me...
var myParStyles = myDoc.paragraphStyles;
for (i = myParStyles.length-1; i >= 2;i-- )
    var itr=0;
    itr=removeUnusedParaStyle(myParStyles);
    alert(myParStyles.name);
    if(itr==1)
function removeUnusedParaStyle(myPaStyle)
  app.findTextPreferences = app.changeTextPreferences=null;
  app.findTextPreferences.appliedParagraphStyle = myPaStyle;
Votes
Translate
Translate
Adobe Employee ,
    var itr=0;
    if(itr==1)
  var myFoundStyles = myDoc.findText();
                for (var k = myParStyles.length-1; k >= 2; k-- )
                if (myParStyles.basedOn.name == myPaStyle.name)
                    return 0;
            return 1;
       return 0;
In the script, a paragraph style "p" will be considered unused when
1. Document has no text with that style applied
2. And no other style is based on "p"
InDesign however considers a style "p" unused when no other style is based on "p"
Indesign will consider a style "p" used, even if an empty paragraph (with no text) has that style applied.
Example: If i create 2 style p1 and p2 and make a blank frame with p1 selected, then InDesign will consider only p2 unused. The script above will consider both p1 and p2 unused.
Let me know if this helps.
-Aman
Votes
Translate
Translate
Report
Report
New Here ,
Aug 01, 2017 Aug 01, 2017
LATEST
many thanks to you i think it works fine now, but is there any way to improve it or it is fine as it is
Votes
Translate
Translate
Report
Report
