0 Replies Latest reply on Jul 31, 2017 8:51 AM by Naoki-Hada
    [Q] Is there way to suspend Photoshop UI update while script running?
    Naoki-Hada Level 1
      Hi all,
      Details:
      1) I have some code to modify values on Adjustment Layer parameters by user operation.
      2) Issue came up as user operate, it records bunch of History State.
      3) So I changed as following.
          3-1) Once backward from last recorded History State
                  This is from ScriptListner code.
          3-2) Change values on Adjustment Layer
                  This is modified ScriptListner code to support parameters.
      4) Then there's issue on History State.
           So I used app.activeDocument.suspendHistory() function to have unique name on History State.
           I'm not sure if there's other way to rename History State.
      5) Now I have issue on following as user operate to change values on Adjustment Layer.
          Win: Adjustment Layer's Slider got flickering on Photoshop UI
          Mac: Above 4) 's History State is flickering on Photoshop UI
          Both does not look good.
      Thank you,
      Naoki
