3 Replies Latest reply on Aug 2, 2017 3:32 PM by clutch-cargo
    Qwertyfly's script function 'myTrace()', but can't find trace preset?
    clutch-cargo Level 1
      I found this script from a post 2 years ago from Qwertyfly.  Being so old I though I would post my issue in a new thread.  It appears to be exactly what want however when I run the script I always get the following error message "cannot find tracing preset that has been set in the script".  I have tried several of the default trace presets but always the same message.
      What I am doing is using a VBscript to load a TIFF file, I make sure the document is selected then call the myTrace script.  I also tried the script by having it in the Illustrator's File/Scripts folder and running it directly.  Same error message.  FYI, I am using Illustrator CS6.
      If Qwertyfly happens to see this or if someone can chime in that would be great.
      Here's the script.  I commented out the lines of code that play an action.   Just want to trace for now.
      function myTrace(){
          //-----User Set Variables-------
          var Tracing_Preset = '16 colors';
          //var My_Action_Name = 'Rotate .5';
          //var From_Set_Name = 'MyActions';
          if(app.tracingPresetsList.indexOf(Tracing_Preset)<0){
              alert('cannot find tracing preset that has been set in the script');
              return;
          var doc = app.activeDocument;
          var sel = doc.selection;
          for(var i = 0; i<sel.length; i++){
              //if(sel[i] == '[RasterItem ]'){              //This line was quoted as a mistake and new line is below it.
                if(sel[i].typename == 'RasterItem'){
                  var pic = sel[i].trace();
                  pic.tracing.tracingOptions.loadFromPreset(Tracing_Preset);
                  pic.tracing.expandTracing().selected = true;
          // no test to confirm the action is present. make sure action name and set name are correct. they are case sensitive.
          //app.doScript(My_Action_Name, From_Set_Name);    // don't want this Action to happen so commented out.
      // add indexOf prototype to Array's
      Array.prototype.indexOf = function(needle) {
          for(var i = 0; i < this.length; i++) {
              if(this[i] === needle) {
                  return i;
          return -1;
      myTrace();
