Hello
I just setup a new computer with Adobe Bridge CC and I´m experiencing a color issue.
The Thumbnail in Content Panel is saturated particularly in reds, while Preview Panel is correctly matching Photoshop results.
This happens both in laptop and external monitor.
Both monitors are color calibrated calibrated, and I have cleaned the cache.
Color settings are set to be synchronized in Adobe apps.
Computer:
MacBook Pro (13" 2016)
OS Sierra
2.4 GHz Intel Core i7
16GB RAM, Intel Iris Graphics 540
Adobe Photoshop CC
Adobe Bridge CC
Thank you for your support
Hi juanpablo,
As I understand that you are facing color mismatch issue between the content and preview panel in Adobe Bridge. You have proper resources to run this application, I would suggest you reset & purge cache for Adobe Bridge and check if that helps
Refer the document: Troubleshoot Adobe Bridge for errors and freezes
Regards,
Mohit
Hi Mohit
Thank you for the advice. I have tried that with no results.
I am suspicious about the hdmi to usb type c connector. It is not original and maybe that creates the problem, currently waiting for the original one.
Regards
Hij Juanpablo,
Could you please let us know if the original connector worked fine or not?
Regards,
Sahil
