4 Replies Latest reply on Aug 4, 2017 5:12 AM by marco san
    offset corner pin with different x y offset values
    marco san
      Hello!
      Suppose you have a keyframed corner pin effect. Is there a way to extend a pin point (example: top left corner point) with different offset values for X and Y using expressions?
      I tried everything, but I can't get it to work: the extended point doesn't stick with the right proportion over the animation.
      This expression is one of the many i applied without any success. It works only if offset X and Y values are equal (ex.
      Any suggestion? Thanks.
      // CALCULATE CENTER COORDINATES
      TL = effect("Pin")(1);
      TR = effect("Pin")(2);
      DL= effect("Pin")(3);
      DR = effect("Pin")(4);
      var vertices_x = [];
      var vertices_y = [];
      var min_x = Math.min(TL[0],TR[0],DL[0],DR[0]);
      var max_x = Math.max(TL[0],TR[0],DL[0],DR[0]);
      var min_y = Math.min(TL[1],TR[1],DL[1],DR[1]);
      var max_y = Math.max(TL[1],TR[1],DL[1],DR[1]);
      var mid_x = (min_x + max_x) / 2;
      var mid_y = (min_y + max_y) / 2;
      center = [mid_x,mid_y];
      // OFFSET
      offset = [20,50];
      // TOP LEFT VECTOR
      vector = normalize(TL - center);
      // CALCULATE NEW TOP LEFT
      x = TL[0] + * vector[0] * offset[0];
      y = TL[1] + * vector[1] * offset[1];
      [x,y]
