0 Replies Latest reply on Aug 1, 2017 2:41 PM by mikeb41294032
    Error trying to open pdfs exported by script on a network file server
    mikeb41294032
      Hello Forum!
      I am getting the below Error message when trying to open pdfs output to specific folders within a project on a network file server created by two specific scripts.
      I can use other scripts like the page Exporter Utility or a direct export out of InDesign on the same server/project folder structure without any issue.
      Could there possibly be something with the scripts causing this?
      Thanks in advance for any help!
      The two scripts that are giving me the issue;
        var doc = app.activeDocument;
         for(var p = 0; p < app.documents[0].pages.length; p=p+2) {
           var frames = app.documents[0].pages[p].textFrames;
           var pdf_name = null;
           for(var i = 0; i < frames.length; i++) {
                if(frames[i].paragraphs[0].appliedParagraphStyle.name == 'UAVC-IHD') {
                     pdf_name = frames[i].paragraphs[0].contents;
                     break;
           if(pdf_name != null) {
      app.pdfExportPreferences.pageRange =
      "+"+( doc.pages[p].documentOffset+1 ) + "," +
      "+"+( doc.pages[p+1].documentOffset+1 );
                var export_preset1 = app.pdfExportPresets.item("[High Quality Print]");
                var export_preset2 = app.pdfExportPresets.item("[Smallest File Size]");
      var myFolder = app.activeDocument.filePath.parent;
      myDoc.exportFile(ExportFormat.PDF_TYPE, File(myFolder+'/Final_Deliverables/Publish/' + pdf_name + "HR.pdf"), false, export_preset1);
      myDoc.exportFile(ExportFormat.PDF_TYPE, File(myFolder+'/Final_Deliverables/Proofs/'  + pdf_name + "-00.pdf"), false, export_preset2);
      alert("Done Exporting Pdf's!");
      And..............
      var myDoc = app.activeDocument,
          p, i, frames, pdf_name,
          myFolder = myDoc.filePath.parent;
      for(p = 1; p < myDoc.pages.length; p=p+2) {
          frames = myDoc.pages[p].textFrames;
          pdf_name = null;
          for(i = 0; i < frames.length; i++) {
                 break;
          if(!pdf_name) continue;
          app.pdfExportPreferences.pageRange = myDoc.pages[p-1].name + "-" + myDoc.pages[p].name;
      Here's a script that is used without issue.
      d = app.activeDocument;
      preset1 = app.pdfExportPresets.itemByName("[High Quality Print]");
      preset2 = app.pdfExportPresets.itemByName("[Smallest File Size]");
      if (!(preset1.isValid && preset2.isValid)){
      alert("One of the Export Options does not exist.");
      exit();
      mDocName = d.name.substr (0, d.name.lastIndexOf(‘.’));
      mSourcePath = d.fullName.parent.toString();
      mRootPath =mSourcePath.substr (0, mSourcePath.lastIndexOf(‘/’));
      mTargetPath=mRootPath.concat(‘/final/’);
      mTargetPath1=mRootPath.concat('/Final_Deliverables/Publish/');
      mTargetPath2=mRootPath.concat('/Final_Deliverables/Proofs/');
      mNameHR = mTargetPath1.concat(mDocName,'HR.pdf');
      mName00= mTargetPath2.concat(mDocName,'-00.pdf');
      if (!d.saved){
          d.save;
      d.exportFile(ExportFormat.PDF_TYPE, new File(mNameHR), false, preset1);
      d.exportFile(ExportFormat.PDF_TYPE, new File(mName00), false, preset2)
