6 Replies Latest reply on Aug 4, 2017 3:10 AM by maxr2403253
    Blinking twice when exported
    maxr2403253
      I have a flawless project and I choose "Export and Share" with 1920 x 1080, Best Quality, MP4, 29fps, Processing Rate = 8580kbps, Total Transfer Rate = 8737kbps.
      When it is ready and I will play the video, the video will flash in the bottom of 1/3 of the image. The first 0:00:44 and the last 0:00:46 and the total time of the video is 0:04:45. No other problem can be detected!
      However, there is nothing visible in the Premiere timeline.
      You can see blinking places here: https://youtu.be/1zF7aXCjW7M
      Please ask for more information if this is not enough to resolve.
        • 1. Re: Blinking twice when exported
          whsprague Adobe Community Professional
          When I have done that it is because of how I trimmed clips.  If you zoom in on the time line can you see anything but a perfect clip cut?  You are looking for gaps or stray single frames.
          Good luck with your project.  The video is wonderful!
          • 2. Re: Blinking twice when exported
            maxr2403253 Level 1
            Thank you!
            With Premiere timeline I can't find anything special things. Here's screen capture of timeline between 45s05 ... 47s00 and I have marked with red arrows to screen capture few things:
            A) Cursor shows time before last blink
            B) It is  00;00;45;05
            C) Timeline's "Zoom" has maximum level
            What I can try to search next?
            • 3. Re: Blinking twice when exported
              Remake the title or...
              Remove still from project.
              Resave in Photoshop,
              and rename the still.
              Then try again.
              • 4. Re: Blinking twice when exported
                maxr2403253 Level 1
                Thank you
                I make again text to this gap. I have removed also photo from gap and prepared a new one with a new file name and drag&drop it to gap but results are exactly same than early
                Now I have made full scanned to my computer by using two different software but can't found any horses etc. malicious..
                I made also a new test project with Premiere and every things fine whole 5 minutes video.
                Maybe I need to try this project again completely from zero. If still have problem, then uninstall Premiere and install again?
                Any other ideas?
                • 5. Re: Blinking twice when exported
                  Alas no other ideas.
                  • 6. Re: Blinking twice when exported
                    maxr2403253 Level 1
                    I am a novice with Premiere software and it is always helpful to see what things need to check if there is a problem. So I got good service from you.
                    Amendment:
                    Is it possible that "Garden Gate Image" had too much details?
                    I believe because continued testing:
                    1: I removed the original image from Timeline and replaced it with a completely different picture - the disorder was removed.
                    2: I removed from the Timeline a different image and added Photoshop's original image again with a new jpg name - the disorder returned.
                    3: I opened the "Garden Gate" original in Photoshop and made a Gaussian Blur for layer with trees.
                    4: I removed the "Garden gate original" image from Timeline and replaced it with a new "Garden Gate blurred background". Now it works great!!!
                    garden gate original:
                    garden gate background blurred:
