1. Re: After Effects error: zero denominator in ratio addition 17::16
Mylenium Aug 2, 2017 1:10 AM (in response to Sagesb17)This error can have al lsorts of causes and without better info nobody can really tell you where it is coming from. It's an internal math error, obviously, and can affect anything from decoding the footage to specific functions and effects. Based on your screenshot the only thing thatr comes to mind is trying to re-encode/ transcode your source file in case its streams are damaged. this may avoid the issue then...
Mylenium
2. Re: After Effects error: zero denominator in ratio addition 17::16
Kevin-MonahanAug 15, 2017 4:09 PM (in response to Sagesb17)
Hi SageSB,
Sorry for this issue. Did you ever find a solution? Please let us know if you have or if you still need help.
Kevin
3. Re: After Effects error: zero denominator in ratio addition 17::16
Sagesb17 Aug 17, 2017 2:42 PM (in response to Kevin-Monahan)No, unfortunately not. The other day it was working just fine, but I tried again today and the same issue occurred. I just do this for a hobby and have had no training, so I don't know how to re-code/transcode a source file like the other user suggested. Do you know how I can fix this? Thank you!
4. Re: After Effects error: zero denominator in ratio addition 17::16
Sagesb17 Sep 2, 2017 8:01 PM (in response to Kevin-Monahan)I'd really appreciate it if I got some help, I've also been getting a (27::15) error and it's really frustrating, sometimes AE will crash. I don't want to be paying for a software with some features unaccessible .
5. Re: After Effects error: zero denominator in ratio addition 17::16
aerinp2268496 Sep 4, 2017 1:48 PM (in response to Sagesb17)Aghhh! I have the same problem as well.. Whenever Im using the graph editor, it always says (17::16) error blah blah and crashes.. Its very annoying and I still haven't found a solution....
6. Re: After Effects error: zero denominator in ratio addition 17::16
Kevin-MonahanSep 11, 2017 3:06 PM (in response to Sagesb17)
Hi sagesb,
Did you do as recommended and transcode your file? You can do so in Media Encoder. Here's some basic steps: https://filmpost.co/2016/09/a-beginners-guide-to-transcoding-with-adobe-media-encoder/
Let us know if you have questions.
Kevin
7. Re: After Effects error: zero denominator in ratio addition 17::16
Sagesb17 Sep 16, 2017 2:13 PM (in response to Kevin-Monahan)YES! Thank you so much it's working just fine now.
8. Re: After Effects error: zero denominator in ratio addition 17::16
Dave LaRonde Sep 16, 2017 2:31 PM (in response to aerinp2268496)The last two posters, Sagesb17 and aerinp2268496, have provided precisely ZERO information to help with a diagnosis. They're just whining. So based on the wealth of information they provided, here's my response;
After Effects doesn't like you any more. You dd something to make it angry. You have to atone. I suggest buying it flowers and taking it out to a really nice restaurant for a fine candlelight dinner.
Hey, it's just as good a recommendation as anything else.
