2 Replies Latest reply on Aug 4, 2017 10:45 PM by oaklander
    watermark on pdf
    oaklander
      I can apply the watermark, but the document will not print.  Have not had this problem before.  Please advise
        • 1. Re: watermark on pdf
          The document doesn't print at all, or do you mean that the watermark doesn't print?
          Also, what does "doesn't print" mean, exactly?
          And what application (including exact version number) are you using?
          • 2. Re: watermark on pdf
            oaklander Level 1
            I have adobe professional XI.  The document will stall in printing, and then give an error message and need to be cancelled in the print cue.  It only happens with documents that have a watermark and that are also long.  There is  a work around I found.  It is in the Adobe help, but buried under print problems.  File, print, advanced.  Then print as image.  Then ok.  Then print, then ok.  It works!
            Jocelyn
