2 Replies Latest reply on Aug 3, 2017 12:30 AM by ThomasFischer
    InDesign Server does not close "indesign-xml.tmp" on OSX
      i got a script that runs fine on windows but runs only once on OSX and crashes on every following try till InDesign Server is restarted.
      Note that indesign-xml.tmp is not a filename my script uses but seems to get created by InDesign Server (and never closed?)
      the Errormessage:
      Fehlernummer: 9491
      Fehlerzeichenfolge: In die Datei "indesign-xml.tmp" kann nicht gespeichert werden, da sie bereits geöffnet ist.
      (rough translation: the file "indesign-xml.tmp" can't be saved, because it is already opened)
      the Line of Code that causes the Problem:
      myXmlElement.exportFile(ExportFormat.XML, filename); // filename gets randomly generated so it is not indesign-xml
      Version of InDesign Server:
      CC2017 - OSX
      Has anyone else encountered this Problem before?
      The export is only used to stringify an already existing XmlElement. is there maybe a better way to do so?
      Thanks a lot in advance
