8 Replies Latest reply on Aug 3, 2017 8:28 AM by Chuck Uebele Branched to a new discussion.
    Issue creating a new refined list in a listbox
    Dale_
      I have created a table using the following code from "ScriptUI for Dummies".
      entry.onChanging = function ()
      var temp = entry.text,
      tempArray = [];
      for (var i = 0; i < array.length; i++)
      if (array[i].toLowerCase().indexOf (temp) == 0)
      tempArray.push (array[i]);
      if (tempArray.length > 0)
      // Create the new list with the same bounds as the one it will replace
      tempList = w.add ("listbox", list.bounds, tempArray, {scrolling: true});
      w.remove(list);
      list = tempList;
      list.selection = 0;
      } // entry.onChanging
      It works in CC2014, but in CC2017 it seems to mess up as soon as I change the edittext box.
      From what I can see, the issue is on line 11 (above), where list.bounds seems to cause an issue, however I also believe the issue may be elsewhere.
      Am I missing something?
      Thanks in advance for your help.
        • 1. Re: Issue creating a new refined list in a listbox
          Chuck Uebele Adobe Community Professional & MVP
          When you remove the listbox items, you have to replace them in the listbox, not just the array. Here's an example:
          #target photoshop
          var dlg = new Window('dialog','listbox text')
          var list = ['one','two','three']//original list
          var list2 = ['four','five','six']//new list
          dlg.btn = dlg.add('button',undefined,'reset')
          dlg.listBx = dlg.add('listbox',undefined,list,{numberOfColumns: 1});
          dlg.btn.onClick = function(){
              dlg.listBx.removeAll();
              for(var i=0;i<list2.length;i++){
                  dlg.listBx.add('item',list2[i])//adds the array items back to the listbox
          dlg.show()
          • 2. Re: Issue creating a new refined list in a listbox
            Dale_ Level 1
            Hi Chuck,
            That replaces the list. I want to update the list with items I have.
            So for example. When I type "Ma" - it will only show options that start with "ma"
            My end goal is to create a listbox that will list a large number of items that I can search easily with an edittext search bar.
            Would that be possible in CC2017?
            • 3. Re: Issue creating a new refined list in a listbox
              That would be the same sort of thing. You would have to use the text box, then loop through your original array doing a search for entries that match, push those to your temp array, then replace each item as I showed. You will want to leave the original array untouched, so that you could reset the listbox.
              • 4. Re: Issue creating a new refined list in a listbox
                Dale_ Level 1
                Cheers Chuck, I am afraid I am not very comfortable with Javascript yet. I am primarily a retoucher.
                Would you mind giving me an example that includes an 'edittext' search bar so I can see it in action.
                I have tried changing a few things to follow your example, but I am not having any luck.
                • 5. Re: Issue creating a new refined list in a listbox
                  Dale_ Level 1
                  Here is a sample of my code:
                  The actual code is much longer, so I have cleaned it to just show the important areas
                  #target Photoshop
                  picked = type_ahead ([ 'Apple','Apricot','Avocado','Banana','Bilberry','Blackberry','Blackcurrant','Blueberry','Boysenberry','Currant','Cherry','Cherimoya','Cloudberry','Coconut','Cranberry','Cucumber','Custard apple','Damson','Date','Durian','Elderberry','Feijoa','Goji berry','Gooseberry','Raisin','Guava','Honeyberry'
                  ,'Huckleberry','Jabuticaba','Jackfruit','Jambul','Jujube','Juniper berry','Kiwifruit','Kumquat','Lemon','Loquat','Longan','Lychee','Mango','Marionberry','Melon','Cantaloupe','Honeydew','Watermelon','Mulberry','Nectarine','Nance','Olive','Orange','Blood orange','Clementine'
                  ,'Mandarine','Tangerine','Papaya','Peach','Pear','Physalis','Plantain','Plum','Prune','Pineapple','Plumcot','Pomegranate','Pomelo','Quince','Raspberry','Salmonberry','Redcurrant','Salal berry','Salak','Soursop','Star fruit','Solanum quitoense','Strawberry','Tamarillo','Tamarind','Ugli fruit'
                  ,'Yuzu']);
                  function type_ahead (fruits) {
                  var w = new Window ('dialog {text: "fruits", alignChildren: "fill"}', undefined, undefined, {closeButton: true});
                  var entry = w.add ('edittext {active: true}')
                  var list = w.add ('listbox', [0, 0, 120, 500], fruits);
                  list.selection = 0;
                  entry.onChanging = function () {
                  // entry changing logs fine
                  var temp = this.text,
                  tempArray = [];
                  for (var i = 0; i < fruits.length; i++) {
                  if (fruits[i].toLowerCase().search (temp) == 0) {
                  tempArray.push (fruits[i]);
                  // upper and lower case changes log fine
                  } //lowercase
                  else if (fruits[i].toUpperCase().search (temp) == 0) {
                  } //uppercase
                  var tempList = w.add ('listbox', list.bounds, tempArray);
                  w.remove(list);
                  list = tempList;
                  list.selection = 0;
                  } // templlist
                  } //for
                  }// entry.onChanging = function () {
                  ListItem.add
                  var btn = w.add ('button', undefined, 'OK', {name: 'ok'})
                  list.onDoubleClick=function(){
                  if (list.selected){
                  // do something here
                  } //if (list.selected){
                  w.close();
                  }// list.onDoubleClick=function(){
                  if (w.show () != 2){
                       var clicked = list.selection.text
                  alert(clicked);
                  } // if (w.show () != 2){
                  w.close();
                  } //function type_ahead (fruits) {
                  Many Thanks in advance!
                  • 6. Re: Issue creating a new refined list in a listbox
                    I adapted your code and my code to a new example. I still used your part where you search the original array and push that info into the tempArray. But rather than replacing the listbox, I just removed it's items and replaced them with the ones in the tempArray.
                    #target photoshop
                    var w = new Window('dialog','listbox text')
                    var entry = w.add('edittext',undefined,'');
                    entry.size = [200,20];
                    w.listBx = w.add('listbox',undefined,list,{numberOfColumns: 1,scrolling: true});
                    tempArray = [];
                    for (var i = 0; i < list.length; i++)
                    if (list[i].toLowerCase().indexOf (temp) == 0)
                    tempArray.push (list[i]);
                    // Create the new listBx with the same bounds as the one it will replace
                    w.listBx.removeAll()
                    for (var i=0;i<tempArray.length;i++){
                        w.listBx.add('item',tempArray[i])
                    w.listBx.selection = 0;
                    w.show()
                    • 7. Re: Issue creating a new refined list in a listbox
                      Dale_ Level 1
                      Many thanks Chuck, this worked.
