9 Replies Latest reply on May 6, 2010 2:42 PM by Junaid Atari
    Cursor Pointing Problems
    ArnoP
      I am having a problem lately with Fireworks CS3. When I point to the tool icon with the mouse I only show a hand.
      I have to position the mouse on next lower Icon and it then selects the one above.
      The distance of this error becomes worse the closer I get to the middle of the Toolbar.
      Left and right icons select ok.
      It also shows up in Dreamweaver. When I select the pointing tool to point to a picture file for instance the arrow appears about an inch above the mouse pointer.
      I have searched high and low with out getting a clue. I have replaced the display driver and used all kinds of different pointing devices. (several mice, tablet and built in pointing device on my Thinkpad T60p.
      Any ideas out there?
      thanks
        • 1. Re: Cursor Pointing Problems
          Level 7
          This seems to be a recently discovered problem. It has happened to me, but
          unfortunately I haven't discovered a solution. The problem can vanish
          without trace, and has done for me several times.
          It has been suggested that deleting the Fireworks preference file may help.
          Good luck, sorry I couldn't be more help.
          Peter
          ___________________
          "ArnoP" <webforumsuser@macromedia.com> wrote in message
          news:g49bhu$lm$1@forums.macromedia.com...
          icon
          one
          | above.
          the
          | Toolbar.
          to a
          | pointer.
          mice,
          | thanks
          • 2. Re: Cursor Pointing Problems
            ArnoP Level 1
            I forgot to mention that I have tried to fix it by deleting the preferences file to no avail before I posted.
            Peter
            ___________________
            icon
            one
            | above.
            the
            | Toolbar.
            to a
            | pointer.
            mice,
            | thanks
            • 3. Re: Cursor Pointing Problems
              thegendreamer Level 1
              hey thanks for all the information well read by myself
              • 4. Re: Cursor Pointing Problems
                visibility99
                Has anyone solved this yet? I recently moved Fireworks CS3 from a Windows XP machine to a Windows 7 machine on a 1920x1200 resolution laptop, and now I've got the same weird mouse pointer mismatch. There is a hover offset between the mouse pointer and the toolbar, and the farther I get from the upper left corner the larger the offset is.  Just partway down the screen, I have to hover an inch below and a little to the right of the tool I that I want to select.  The right column is completely inaccessible, presumably because the right (horizontal) offset has taken me off the toolbar completely. If I am able to successfully click a button with a submenu, I can select the submenu item with no offset and no difficulty.
                Oddly, in the main screen work area, there is no problem - the mouse works perfectly.  It is in the tool panels on either side of the screen that this offset occurs.
                I did try deleting the preferences file, but that did not help.
                • 5. Re: Cursor Pointing Problems
                  visibility99 Level 1
                  Hmmm, anyone have an idea? Problem still exists.
                  • 6. Re: Cursor Pointing Problems
                    Junaid Atari
                    Sometime this would be happen on windows 7 but i open my FireWorks "Run as Administrator" and everything goes fine.
                    • 7. Re: Cursor Pointing Problems
                      Excellent solution. I have NO idea why that works, but running FW "as administrator" seems to clear up the cursor misalignment issue.
                      Thanks!
                      • 8. Re: Cursor Pointing Problems
                        drjury Level 1
                        Tap the space bar a few times and it will return to pointer.
                        • 9. Re: Cursor Pointing Problems
                          Junaid Atari Level 1
                          Running FW as Admin will disable some features like:
                          File Drag 'n Drop on FW Canvas...
                          -- Sag-e-Attar Junaid Atari
