2 Replies Latest reply on May 2, 2018 1:56 PM by snbaem
    Several Resolved / Installed Bundles will not change to Active State
    cynthiac32817762 Level 1
      I have 2 instances of AEM 6.2 running on Linux VM's. One of the instance starts and processing documents fine. The other instance is having problems with bundles changing from Resolved / Installed to Active.
      Here is a snippet from the error.log and this is consistently repreated:
      03.08.2017 07:37:01.273 *WARN* [sling-oak-observation-567] org.apache.jackrabbit.oak.jcr.observation.ChangeProcessor Error while dispatching observation events for /etc/workflow//*[10101b, cq:Workflow, cq:Payload, no local]@com.adobe.granite.workflow.core.eventsupport.JcrToWorkflowEventService
      java.lang.NullPointerException: null
              at com.adobe.granite.workflow.core.eventsupport.JcrToWorkflowEventService.onEvent(JcrToWorkf lowEventService.java:209)
              at org.apache.jackrabbit.commons.observation.ListenerTracker$1.onEvent(ListenerTracker.java: 164)
              at org.apache.jackrabbit.oak.jcr.observation.ChangeProcessor.contentChanged(ChangeProcessor. java:317)
              at org.apache.jackrabbit.oak.spi.commit.BackgroundObserver$1$1.call(BackgroundObserver.java: 131)
              at org.apache.jackrabbit.oak.spi.commit.BackgroundObserver$1$1.call(BackgroundObserver.java: 125)
              at java.util.concurrent.FutureTask.run(FutureTask.java:266)
              at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
              at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
              at java.lang.Thread.run(Thread.java:745)
        • 1. Re: Several Resolved / Installed Bundles will not change to Active State
          Additional information from the log:
          03.08.2017 07:36:20.877 *ERROR* [discovery.connectors.common.runner.bc0bd855-d54a-4961-b299-d4ce0cf499e6.connectorPinger] org.apache.sling.discovery.base.commons.PeriodicBackgroundJob safelyRun: got a RuntimeException executing 'discovery.connectors.common.runner.bc0bd855-d54a-4961-b299-d4ce0cf499e6.connectorPinger' : java.lang.RuntimeException: Exception while talking to repository (org.apache.sling.api.resource.PersistenceException: Unable to commit changes to session.)
                  at org.apache.sling.discovery.oak.OakDiscoveryService.doUpdateProperties(OakDiscoveryService .java:542)
                  at org.apache.sling.discovery.oak.OakDiscoveryService.updateProperties(OakDiscoveryService.j ava:562)
                  at org.apache.sling.discovery.oak.pinger.OakViewChecker.updateProperties(OakViewChecker.java :330)
                  at org.apache.sling.discovery.base.commons.BaseViewChecker.issueHeartbeat(BaseViewChecker.ja va:213)
                  at org.apache.sling.discovery.base.commons.BaseViewChecker.heartbeatAndCheckView(BaseViewChe cker.java:181)
                  at org.apache.sling.discovery.base.commons.BaseViewChecker.run(BaseViewChecker.java:167)
                  at org.apache.sling.discovery.base.commons.PeriodicBackgroundJob.safelyRun(PeriodicBackgroun dJob.java:86)
                  at org.apache.sling.discovery.base.commons.PeriodicBackgroundJob.run(PeriodicBackgroundJob.j ava:77)
          Caused by: org.apache.sling.api.resource.PersistenceException: Unable to commit changes to session.
                  at org.apache.sling.jcr.resource.internal.helper.jcr.JcrResourceProvider.commit(JcrResourceP rovider.java:482)
                  at org.apache.sling.resourceresolver.impl.providers.stateful.AuthenticatedResourceProvider.c ommit(AuthenticatedResourceProvider.java:215)
                  at org.apache.sling.resourceresolver.impl.helper.ResourceResolverControl.commit(ResourceReso lverControl.java:411)
                  at org.apache.sling.resourceresolver.impl.ResourceResolverImpl.commit(ResourceResolverImpl.j ava:1224)
                  at org.apache.sling.discovery.oak.OakDiscoveryService.doUpdateProperties(OakDiscoveryService .java:533)
                  ... 8 common frames omitted
          Caused by: javax.jcr.InvalidItemStateException: OakMerge0004: OakMerge0004: Following exceptions occurred during the bulk update operations: [org.apache.jackrabbit.oak.plugins.document.ConflictException: The node 6:/var/discovery/oak/clusterInstances/bc0bd855-d54a-4961-b299-d4ce0cf499e6/properties was changed in revision
          r15d8c14cf6f-0-1 (not yet visible), which was applied after the base revision
          r15d8c14cf32-0-1,r15d8c16d48a-0-2,r15cc66cd95d-0-3,r15d74dc0e76-0-4,r15da8184e51-0-5,r15da 595db9a-0-6, before
          r15da818c0f7-0-6] (retries 5, 300191 ms)
                  at org.apache.jackrabbit.oak.api.CommitFailedException.asRepositoryException(CommitFailedExc eption.java:239)
                  at org.apache.jackrabbit.oak.api.CommitFailedException.asRepositoryException(CommitFailedExc eption.java:212)
                  at org.apache.jackrabbit.oak.jcr.delegate.SessionDelegate.newRepositoryException(SessionDele gate.java:670)
                  at org.apache.jackrabbit.oak.jcr.delegate.SessionDelegate.save(SessionDelegate.java:496)
                  at org.apache.jackrabbit.oak.jcr.session.SessionImpl$8.performVoid(SessionImpl.java:419)
                  at org.apache.jackrabbit.oak.jcr.delegate.SessionDelegate.performVoid(SessionDelegate.java:2 74)
                  at org.apache.jackrabbit.oak.jcr.session.SessionImpl.save(SessionImpl.java:416)
                  at sun.reflect.GeneratedMethodAccessor63.invoke(Unknown Source)
                  at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
                  at java.lang.reflect.Method.invoke(Method.java:498)
                  at org.apache.sling.jcr.base.SessionProxyHandler$SessionProxyInvocationHandler.invoke(Sessio nProxyHandler.java:116)
                  at com.sun.proxy.$Proxy11.save(Unknown Source)
                  at org.apache.sling.jcr.resource.internal.helper.jcr.JcrResourceProvider.commit(JcrResourceP rovider.java:480)
                  ... 12 common frames omitted
          Caused by: org.apache.jackrabbit.oak.api.CommitFailedException: OakMerge0004: OakMerge0004: Following exceptions occurred during the bulk update operations: [org.apache.jackrabbit.oak.plugins.document.ConflictException: The node 6:/var/discovery/oak/clusterInstances/bc0bd855-d54a-4961-b299-d4ce0cf499e6/properties was changed in revision
                  at org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreBranch.merge0(DocumentNodeSto reBranch.java:202)
                  at org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreBranch.merge(DocumentNodeStor eBranch.java:126)
                  at org.apache.jackrabbit.oak.plugins.document.DocumentRootBuilder.merge(DocumentRootBuilder. java:158)
                  at org.apache.jackrabbit.oak.plugins.document.DocumentNodeStore.merge(DocumentNodeStore.java :1508)
                  at org.apache.jackrabbit.oak.core.MutableRoot.commit(MutableRoot.java:247)
                  at org.apache.jackrabbit.oak.jcr.delegate.SessionDelegate.commit(SessionDelegate.java:347)
                  at org.apache.jackrabbit.oak.jcr.delegate.SessionDelegate.save(SessionDelegate.java:494)
                  ... 21 common frames omitted
          Caused by: org.apache.jackrabbit.oak.plugins.document.ConflictException: Following exceptions occurred during the bulk update operations: [org.apache.jackrabbit.oak.plugins.document.ConflictException: The node 6:/var/discovery/oak/clusterInstances/bc0bd855-d54a-4961-b299-d4ce0cf499e6/properties was changed in revision
          r15da818c0f7-0-6]
                  at org.apache.jackrabbit.oak.plugins.document.Commit.checkConflicts(Commit.java:561)
                  at org.apache.jackrabbit.oak.plugins.document.Commit.applyToDocumentStore(Commit.java:326)
                  at org.apache.jackrabbit.oak.plugins.document.Commit.applyToDocumentStore(Commit.java:262)
                  at org.apache.jackrabbit.oak.plugins.document.Commit.applyInternal(Commit.java:231)
                  at org.apache.jackrabbit.oak.plugins.document.Commit.apply(Commit.java:220)
                  at org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreBranch.persist(DocumentNodeSt oreBranch.java:292)
                  at org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreBranch.persist(DocumentNodeSt oreBranch.java:262)
                  at org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreBranch.access$300(DocumentNod eStoreBranch.java:57)
                  at org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreBranch$InMemory.merge(Documen tNodeStoreBranch.java:499)
                  at org.apache.jackrabbit.oak.plugins.document.DocumentNodeStoreBranch.merge0(DocumentNodeSto reBranch.java:182)
                  ... 27 common frames omitted
          03.08.2017 07:36:21.185 *WARN* [sling-oak-observation-559] org.apache.jackrabbit.oak.jcr.observation.ChangeProcessor Error while dispatching observation events for /etc/workflow//*[10101b, cq:Workflow, cq:Payload, no local]@com.adobe.granite.workflow.core.eventsupport.JcrToWorkflowEventService
          03.08.2017 07:36:22.196 *WARN* [sling-oak-observation-562] org.apache.jackrabbit.oak.jcr.observation.ChangeProcessor Error while dispatching observation events for /etc/workflow//*[10101b, cq:Workflow, cq:Payload, no local]@com.adobe.granite.workflow.core.eventsupport.JcrToWorkflowEventService
          03.08.2017 07:36:42.222 *INFO* [qtp1702366321-3409] org.apache.sling.auth.core.impl.SlingAuthenticator getAnonymousResolver: Anonymous access not allowed by configuration - requesting credentials
          03.08.2017 07:37:03.292 *WARN* [sling-oak-observation-554] org.apache.jackrabbit.oak.jcr.observation.ChangeProcessor Error while dispatching observation events for /etc/workflow//*[10101b, cq:Workflow, cq:Payload, no local]@com.adobe.granite.workflow.core.eventsupport.JcrToWorkflowEventService
