6 Replies Latest reply on Aug 5, 2017 3:50 PM by Eli-zabelle
    Lock fields with password
    Eli-zabelle Level 1
      My aim is to lock a number of fields in a form with a password chosen by the person who will administrate the form. It is not a question of high security, it is only to make sure that the fields will not be modified by accidental clics or deletes.
      I was able to accomplish what I wanted with the code suggested in this post : Re: Form Field Security .
      I slightly modified the code for the password to be extracted from another field. Here it is :
      (function () {
      // Get one of the fields in the group
      var f = getField("admin.logo");
      // Determine new readonly state, which
      // is the opposite of the current state
      var readonly = !f.readonly;
      var readonly_desc = readonly ? "deactivate" : "activate";
      // Ask user for password
      var resp = app.response({
      cQuestion: "To " + readonly_desc + " the fields, enter the password:",
      cTitle: "Enter password",
      bPassword: true,
      cLabel: "Password"
      var pw=this.getField("Mot_passe").value;
      switch (resp) {
      case pw: // Your password goes here
      getField("admin").readonly = readonly;
      app.alert("The fields are now " + readonly_desc + "d.", 3);
      break;
      case null : // User pressed Cancel button
      break;
      default : // Incorrect password
      app.alert("Incorrect password.", 1);
      break;
      I applied this code as an action on a checkbox field, it works very well.  Now, I also want the password field to hide if the fields have indeed locked, but to reappear when the fields unlock. So I created a following action with this code :
      var a = this.getField("admin").readonly;
      var b = this.getField("Mot_passe");
      if (a = true) b.display=display.hidden;
      else
      b.display=display.visible;
      It obeys perfectly to hiding the password field when my group of fields is locked, but will not return it to visible when the fields unlock.
      Please, what do I need to change, if anyone can help?  Thank you!
