• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Photoshop Premier Elements 7 stops working after a while
New Here ,
Aug 03, 2017 Aug 03, 2017
I have started my first project in Premier Elements 7. After I have uploaded video clips I am only able to place six or seven clips on the board at the bottom before I get a message telling me the program has stopped working. My operating system is Windows 8. Could it be that I have insufficient space on my C: drive?
Views
269
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Aug 04, 2017 Aug 04, 2017
There is no program called Photoshop Premiere Elements. Since you're talking about video editing, I assume you're talking about Premiere Elements.
It's possible that you've run out of space or that your computer is under-powered -- but you don't list your specs, so it's hard to say. What processor do you have with how much RAM? How much free, clean, defragmented space is on your hard drive?
The more likely issue is that you're editing with version 7, which was designed pretty much to work only with tape-based miniDV and HDV video. It can't edit any of the modern video standards like MP4 and AVCHD. What model of camcorder is your video coming from and what is the video's resolution and format?
Votes
Translate
Translate
Report
Report
New Here ,
The video I am uploading is in MP4 format from my Sanyo camcorder. I would have to check on the video's resolution. Note that all the video files are uploaded successfully, the program only breaks down when I drag 6,7 or 8 clips to  the timeline below (I am not looking at it now so I forget the correct name). If the MP4 format is the problem, can I change the files to the correct format using some sort of software?
Here are my specs (perhaps more specs than you need):
            Operating System
                  Windows 8 Pro 32-bit
            CPU
                  Intel Core 2 Duo E6300 @ 1.86GHz    82 °C
                  Conroe 65nm Technology
            RAM
                  4.00GB Dual-Channel DDR2 @ 399MHz (6-6-6-18)
            Motherboard
                  Gigabyte Technology Co. Ltd. G41M-Combo (Socket 775)  74 °C
            Graphics
                  SMB2030 (1600x900@60Hz)
                  Intel G41 Express Chipset (Gigabyte)
            Storage
                  465GB Seagate ST3500413AS ATA Device (SATA)     36 °C
                  298GB Imation M100 USB 3 USB Device (USB (SATA))      30 °C
                  14GB ?????? ?? Card (USB)
            Optical Drives
                  TSSTcorp CDDVDW SH-224BB ATA Device
            Audio
                  Realtek High Definition Audio
Operating System
      Computer type: Desktop
      Installation Date: 02/12/2015 15:12:23
            Windows Security Center
                  User Account Control (UAC)    Enabled
                  Notify level      2 - Default
                  Firewall    Enabled
            Windows Update
                  AutoUpdate  Download Automatically and Install at Set Scheduled time
                  Schedule Frequency      Every Day
                  Schedule Time
            Windows Defender
                  Windows Defender  Disabled
            Antivirus
                        Avast Antivirus
                              Antivirus   Enabled
                              Virus Signature Database      Up to date
                        Windows Defender
                              Antivirus   Disabled
            .NET Frameworks installed
                  v4.5 Full
                  v4.5 Client
                  v3.5 SP1
                  v3.0 SP2
                  v2.0 SP2
            Internet Explorer
                  Version     10.0.9200.17607
            PowerShell
                  Version     3.0
            Java
                        Java Runtime Environment
                              Path  C:\Program Files\Java\jre1.8.0_111\bin\java.exe
                              Version     8.0
                              Update      111
                              Build 14
                              Path  C:\Program Files\Java\jre1.8.0_121\bin\java.exe
                              Version     8.0
                              Update      121
                              Build 13
                              Path  C:\Program Files\Java\jre1.8.0_66\bin\java.exe
                              Version     8.0
                              Update      66
                              Build 18
                              Path  C:\Program Files\Java\jre1.8.0_91\bin\java.exe
                              Version     8.0
                              Update      91
                              Build 14
            Environment Variables
                  USERPROFILE C:\Users\Roger_000
                  SystemRoot  C:\WINDOWS
                        User Variables
                              DASHLANE_DLL_DIR      C:\Users\Roger_000\AppData\Roaming\Dashlane\4.8.3.33797\bin\Firefox_Extension\{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components;C:\Users\Roger_000\AppData\Roaming\Dashlane\4.8.3.33797\ucrt
                              Path      C:\Users\Roger_000\AppData\Roaming\Dashlane\4.6.5.21982\bin\Firefox_Extension\{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components
                              C:\Users\Roger_000\AppData\Roaming\Dashlane\4.6.6.23032\bin\Firefox_Extension\{442718d9-475e-452a-b3e1-fb1ee16b8e9f}\components
                              %DASHLANE_DLL_DIR%
                              TEMP  C:\Users\Roger_000\AppData\Local\Temp
                              TMP   C:\Users\Roger_000\AppData\Local\Temp
                        Machine Variables
                              asl.log     Destination=file
                              CLASSPATH   .;C:\Program Files\Java\jre1.8.0_121\lib\ext\QTJava.zip
                              ComSpec     C:\WINDOWS\system32\cmd.exe
                              FP_NO_HOST_CHECK  NO
                              NUMBER_OF_PROCESSORS    2
                              OS    Windows_NT
                              Path  C:\ProgramData\Oracle\Java\javapath
                              C:\WINDOWS\system32
                              C:\WINDOWS
                              C:\WINDOWS\System32\Wbem
                              C:\WINDOWS\System32\WindowsPowerShell\v1.0\
                              C:\Program Files\Common Files\Ulead Systems\MPEG
                              C:\Program Files\QuickTime\QTSystem\
Votes
Translate
Translate
Report
Report
Community Expert ,
As I said, version 7 was not designed to edit non-tape-based video. it's not going to work well with an MP4.
If you're going to edit MP4s, I'd very much recommend you upgrade to at least version 11.
Though you're also going to have trouble editing any video with your current video processor. Your processor rates about a 1700 on this benchmark chart. In my books I always recommend editing with a processor that rates at least a 5000.
PassMark CPU Benchmarks - Low Mid Range CPUs
Votes
Translate
Translate
Report
Report
New Here ,
I can't afford to upgrade and I only use the program every so often so it looks like I'm stuck with something that doesn't work. What format was used with tape cameras?
Votes
Translate
Translate
Report
Report
Community Expert ,
miniDV and HDV.
Votes
Translate
Translate
Report
Report
New Here ,
Aug 07, 2017 Aug 07, 2017
Further to all of the above, I converted my MP4 files to MPG and was able to load 50+ clips (as against 6 or 7 MPREG). After that I got the same error message I got before. Doesn't this suggest that my problem is space related rather than processor related? I now have to work out the best way to use the stabilizer.
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Not necessarily. Since version 7 didn't edit MPEGs natively, it was easy to overload the program.
As I've said, version 7 pretty much worked natively with miniDV and HDV tape-based video.
Votes
Translate
Translate
Report
Report
