3 Replies Latest reply on Jul 6, 2008 2:21 PM by BKBK
    OO-design
    jeremyis
      I am developing with an OO-design in mind and I have most of my code written. I have a directory in the webroot
      called 'com'.
      I want to use/create an object/component in another manager-like object in the same directory. So I have a product component (com/product.cfc) which is just a Bean-like component. I also have a productmanager component (com/productmanager.cfc) which has methods manage products and specifically one to return a product object. What should that method's returntype be? And when i create an instance of a product inside some productmanager method do i call createobject with "com.product" or just "product"?
      <cffunction name="getProduct" returntype="com.product" ... >
      OR
      <cffunction name="getProduct" returntype="product" ... >
      I'm guess I'm just missing the basics about when to specify the path and when not to. I create an instance of the productmanager in the application scope and reference that in my display pages. Any body have any advice on best practices here?
        • 1. Re: OO-design
          Vurcease
          I'm fairly confident that if you don't specify the full path, and the CF server is configured to validate component paths (this is an option in 8) an exception will be thrown.
          I've made a habit of specifying full paths for these reasons, as well as to avoid duplicate named component confusion amongst the team.
          To further accommodate this setup, we use a central API, which is mapped for all the applications and sites. So we instantiate things such as API.com.mydomain.service. The full path for that component is always available on all sites and environments.
          • 2. Re: createobject
            Level 7
            You might want to extend that dir structure a bit to include your company
            name and your application name:
            com.acme.eStore.Product
            com.product
            Either will work, but I think the full dotted path is less ambiguous.
            Again, I'd use the full path.
            > not to.
            I'm not sure there's a "right" way, per se, but deciding on an approach and
            sticking with it uniformly is perhaps a good way to do things.
            > practices here?
            That's a pretty vague question...
            Adam
            • 3. Re: OO-design
              BKBK Adobe Community Professional & MVP
              Topic Title OO-design
              Topic Summary should i specify the whole path or just the component name?
              Take as much advice as you can from Vurcease and Adam, but rest assured that what you seek has little or nothing to do with objected-oriented design.
