2 Replies Latest reply on Aug 6, 2017 2:59 AM by Pastingal
    How to completely uninstall a plugin ?
    Pastingal Level 1
      I've moved the LR6 catalogues for drive S to drive E using the right manner (including previews and parameters directories). Everything works well except the WSPP plugin. As far as I have seen, I've no other problem.
      WSPP plugin is used for publishing a web site directly from LR.
      When I publish, the transfer of the pictures works well but at the end appears the following message: "Couldn't open file S:\catalogues\cataloguesLR\parametresLR\webtemplates\mywebsite.lrtemplate for reading. Impossible to update that collection".
      This means that the plugin is still adressing the previous drive (S), not the new one (E).
      I've uninstalled and re-installing the plugin after having shutting down LR and even Windows. Reinstallation is properly achieved and turns green with the correct message (web engine has been installed, restart LR ...). I've re-created the web template in the web module
      But still, each time I want to publish, the plugin turns wrong with the same message that above (plugin turns yellow and says something is wrong)
      I've really no  idea of what to  do  next. It appears as if the desinstallation process of the plugin was incomplete and kept memory of the old location
      Do you have any solution? Is there a way to verify that the uninstallation has left a file or a parameter somewhere?
      I run the last version of LR6 on windows 10
      Thanks for help
