5 Replies Latest reply on Aug 15, 2017 4:43 PM by Kevin-Monahan
    Ram preview 15 layer ?
    Redcritimo Level 1
      Hi, I would like to ram preview 15 cars passing by at the same time, here is my timeline :2017-08-04 21_46_31-Adobe After Effects CC 2017 - E__Documents_After Effects_cloning gto.aep _.png
      Just like this :
      The problem is that the ram preview does not load, it gets stuck, is there a work around please ?
        • 1. Re: Ram preview 15 layer ?
          Nobody can tell you anything without exact system info or other technical details. Aside from that I see nothing unusual. RAM previews are called that for a reason and always have a limited duration thatr is determined by the available system RAM. You may simply not have enough of it.
          Mylenium
          • 2. Re: Ram preview 15 layer ?
            Andrew Yoole MVP & Adobe Community Professional
            AS Mylenium says, RAM Preview duration is governed by how much available RAM is in your computer.
            To increase the duration of RAM Previews, reduce the preview resolution.  You can also reduce the preview frame rate from the Preview panel.
            If you still don't get enough preview time you might need to consider adding more RAM to your computer.
            • 3. Re: Ram preview 15 layer ?
              Redcritimo Level 1
              Thanks for the answers
              You are right, here are the specification of my PC:
              Windows 7 64bit
              12gb RAM
              Intel i7
              AE is installed on a SSD drive
              Nvidia Geforce GT 425M
              I just would like to do a ram preview of approximately 10s, that does not seem much, reducing the preview resolution does not seem to make it faster... It simply
              I was wondering if by any chance, I was doing something wrong and AE was processing more stuff than it should ?
              • 4. Re: Ram preview 15 layer ?
                When you say it gets stuck, could you be a bit more descriptive?
                Also, what, exact, version number of AE are you using?
                • 5. Re: Ram preview 15 layer ?
                  Kevin-Monahan Adobe Employee
                  Hi Redcritimo,
                  Sorry for this issue. Did you ever find a solution? Please let us know if you have or if you still need help.
                  Kevin
