4 Replies Latest reply on Mar 6, 2018 6:16 PM by WobertC
    ARW not converting to DNG
    kristyo92574519
      I am currently importing a bridal session to LR, and just realized it isn't converting the images to DNG. I always convert, and I did have it selected to convert.
      I am using the latest CC version of LR
      My camera is the Sony a7II
      I did search the forum for an answer, and didn't see anything, just issues with LR not reading ARW. My LR is reading it, just not converting.
      Thank you.
        • 1. Re: ARW not converting to DNG
          WobertC Adobe Community Professional
          The Convert to DNG process takes some considerable time after the import process has finished. If you are importing many photos you may have to wait as you see each photo preview slowly change to DNG in the grid. (Do not try moving photos in the folder panel until there are no processes running above the Navigator panel.)
          Check your import options- they may have changed (without you realizing). Open the import dialog to see if the "Copy as DNG" is still set above the import window.
          Have you tried converting an ARW file to DNG from the main menu- (Library>Convert Photo to DNG). Does this work?
          Can you report your Lr version number from {Menu>Help>System Info}  (The top line of the report)  "Latest Version" does not always mean what it suggests!
          2 people found this helpful
          • 2. Re: ARW not converting to DNG
            kristyo92574519 Level 1
            I never noticed that before I upgraded to CC! You are absolutely right. I checked the images just now, and they are now DNG. I remember them always converting immediately.
            Thank you so much!
            • 3. Re: ARW not converting to DNG
              rlbo65129331 Level 1
              I am having this issue right now. I have 462 remaining that were imported as DNG from approximately 2600 images days ago. I'm chewing through them at this moment by using convert to DNG as they have been imported.
              Lightroom version: CC 2015.13 [ 1141928 ]
              Operating system: Mac OS 10 Version: 10.13 [2]
              • 4. Re: ARW not converting to DNG
                I'm chewing through them....
                I am not sure what you mean by this.
                If you used the import option "Copy as DNG", then the process should continue automatically for the 2600 images- and that WILL take some time!. (as each raw file is 'read' , converted, 'written' )
                I hope you did not go to the Menu and select  Library>Convert Photo to DNG, as that is just doubling the process. (Converting a DNG to a DNG?)
                One suggestion, update Lightroom. You are four updates behind the current Classic v7.2
