4 Replies Latest reply on Aug 10, 2017 12:38 AM by Cliff Mosdall
    Axis problem
    Cliff Mosdall Level 1
      I'm using Coldfusion 11 and I'm trying to consume a web service but I'm getting the following error:
      org.apache.axis2.AxisFault: An error occurred while checking the security for the message.
      I can create an object of the WSDL and cfdump it, so there's no problem with the definition. The error occurs when I try to call one of the functions.
      <cfset ws = createObject( "webservice", "https://testapi.kedin.nl/mediatorservice.svc?wsdl" )>
      <cfdump var="#ws#">
      Has anyone seen this error before?
        • 1. Re: Axis problem
          BKBK Adobe Community Professional & MVP
          How are you consuming the web service? Your WSDL suggests you have to pass the security credentials by means of a Web Services Policy (WSP).
          • 2. Re: Axis problem
            Hi BKBK,
            Thanks for the reply. I wasn't clear in the original post. The webservice requires a username and password. The error occurs when I call one of the methods. It's not a CF problem. I'm sure there's some sort of incompatibility between the webservice and Axis - that's my guess. Here's the code:
            <cfset ws = createObject( "webservice", "https://teststub.kedin.nl/KedinStubService.svc?wsdl", {username="StubUser",password="T68tlChm"} )>
            <cfdump var="#ws#">
            <cfset args = StructNew()>
            <cfset args.testRequest.TestProperty = "Test working!">
            <cfset x = ws.GetResponse( args )>
            <cfdump var="#x#">
            • 3. Re: Axis problem
              That looks all right. Is the service perhaps expecting a SOAP request? What about trying something like
              <!--- SOAP message to send to web service--->
                <cfsavecontent variable="msg"><?xml version="1.0" encoding="UTF-8" ?>
                  <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
                        <soapenv:Body>
                          <getResponse soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
                                <testRequest>
                                    <testProperty>Test working!</testProperty>
                                </testRequest>
                          </getResponse>
                      </soapenv:Body>
                  </soapenv:Envelope>
                  </cfsavecontent>
                  <cftry>
                      <!--- Invoke web service to send message--->
                      <cfhttp url="https://teststub.kedin.nl/KedinStubService.svc?wsdl" method="post" username="StubUser" password="T68tlChm">
                          <cfhttpparam type="header" name="content-type" value="text/xml">
                          <cfhttpparam type="header" name="accept-encoding" value="no-compression"/>
                          <cfhttpparam type="header" name="SOAPAction" value="">
                          <cfhttpparam type="header" name="content-length" value="#len(msg)#">
                          <cfhttpparam type="header" name="charset" value="utf-8">
                          <cfhttpparam type="xml" name="message" value="#trim(msg)#">
                      </cfhttp>
                      <cfdump var="#cfhttp#" >
                  <cfcatch type="any">
                      <cfdump var="#cfcatch#">
                  </cfcatch>
                  </cftry>
              Does the provider provide any information on how to consume the service? That would offer us the best clue.
              • 4. Re: Axis problem
                Thanks for taking the time to do that! I've tried that and various other things including addSOAPRequestHeader.
                After days making attempts, the webservice provider is now writing a wrapper that does not need authentication in the request. I'll be providing a Token as part of the function call for security.
                Once again, thanks for all your efforts.
                Cliff
