Problem with a date format
saidatula55878595 Aug 6, 2017 7:48 AMonce i submit this form, i got error on GetSQLValueString($_POST['tarikh'], "date")); the error shows
Warning: sprintf(): Too few arguments in on line 53
Query was empty
How can i solve this problem?
so, this is my php file
<?php require_once('Connections/athira.php'); ?>
<?php
if (!function_exists("GetSQLValueString")) {
function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
if (PHP_VERSION < 6) {
$theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
switch ($theType) {
case "text":
$theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
break;
case "long":
case "int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
break;
case "double":
$theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
break;
case "date":
$theValue = ($theValue != "") ? "'" . date('Y-m-d',$theValue) . "'" : "NULL";
break;
case "defined":
$theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
break;
return $theValue;
$editFormAction = $_SERVER['PHP_SELF'];
if (isset($_SERVER['QUERY_STRING'])) {
$editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "form")) {
$insertSQL = sprintf("INSERT INTO tempahan (nama, matrik, ic, jabatan, pejabat, faks, telefon, emel, tempat, tujuan, tarikh) VALUES (%s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, %s, NOW())",
GetSQLValueString($_POST['nama'], "text"),
GetSQLValueString($_POST['matrik'], "int"),
GetSQLValueString($_POST['ic'], "varchar"),
GetSQLValueString($_POST['jabatan'], "varchar"),
GetSQLValueString($_POST['pejabat'], "int"),
GetSQLValueString($_POST['faks'], "int"),
GetSQLValueString($_POST['telefon'], "int"),
GetSQLValueString($_POST['emel'], "varchar"),
GetSQLValueString($_POST['tempat'], "varchar"),
GetSQLValueString($_POST['tujuan'], "text"),
mysql_select_db($database_athira, $athira);
$Result1 = mysql_query($insertSQL, $athira) or die(mysql_error());
$insertGoTo = "tempahan_list_user.php";
$insertGoTo .= (strpos($insertGoTo, '?')) ? "&" : "?";
$insertGoTo .= $_SERVER['QUERY_STRING'];
header(sprintf("Location: %s", $insertGoTo));
$query_register = "SELECT * FROM tempahan";
$register = mysql_query($query_register, $athira) or die(mysql_error());
$row_register = mysql_fetch_assoc($register);
$totalRows_register = mysql_num_rows($register);
session_start();
$role = $_SESSION['sess_userrole'];
if(!isset($_SESSION['sess_username']) && $role!="tempahan"){
header('Location: index.php?err=2');
and this is my insert form
<td><font size="2" color="#000000" face="Geneva, Arial, Helvetica, sans-serif ">Nama:</font></td>
<td><input name="nama" type="text" id="nama" size="65" maxlength="80" pattern="[a-z A-Z /]*" required></td></tr>
<tr>
<td><font size="2" color="#000000" face="Geneva, Arial, Helvetica, sans-serif">No.Staf/Matrik:</font></td>
<td><input name="matrik" type="text" id="matrik" size="20" maxlength="12" pattern="[0-9]*" required></td></tr>
<tr>
<td><font size="2" color="#000000" face="Geneva, Arial, Helvetica, sans-serif">Kad Pengenalan:</font></td>
<td><input name="ic" type="text" id="ic" size="40" maxlength="12" pattern="[0-9]*" required></td></tr>
<tr>
<td><font size="2" color="#000000" face="Geneva, Arial, Helvetica, sans-serif">Jabatan/Kolej/Inasis/Unit:</font></td>
<td><TEXTAREA name="jabatan" rows=2 cols=60 required></TEXTAREA></td></tr>
<tr>
<tr>
<td><font size="2" color="#000000" face="Geneva, Arial, Helvetica, sans-serif">No.Tel(Pej):</font></td>
<td><input name="pejabat" type="text" id="pejabat" size="20" maxlength="11" pattern="[0-9]*" ></td></tr>
<tr>
<tr>
<td><font size="2" color="#000000" face="Geneva, Arial, Helvetica, sans-serif">No.Faks:</font></td>
<td><input name="faks" type="text" id="faks" size="20" maxlength="11" pattern="[0-9]*" ></td></tr>
<tr>
<tr>
<td><font size="2" color="#000000" face="Geneva, Arial, Helvetica, sans-serif">No.H/P:</font></td>
<td><input name="telefon" type="text" id="telefon" size="20" maxlength="11" pattern="[0-9]*" required></td></tr>
<tr>
<tr>
<td><font size="2" color="#000000" face="Geneva, Arial, Helvetica, sans-serif ">Emel:</font></td>
<td><input name="emel" type="text" id="emel" size="40" maxlength="60" pattern="[a-zA-Z,@,.,0-9,_]*" required></td></tr>
<tr>
<td><font size="2" color="#000000" face="Geneva, Arial, Helvetica, sans-serif">Butiran Tempahan:</font></td>
<td><SELECT name="tempat" required="required"/>
<OPTION>-sila pilih-</OPTION>
<OPTION>Dewan Seminar</OPTION>
<OPTION>Bilik Kuliah</OPTION>
<OPTION>Bilik Komputer</OPTION>
<OPTION>Bilik Kuliah Masjid Sultan Badlishah</OPTION>
</SELECT></td></tr>
<tr>
<tr>
<td><font size="2" color="#000000" face="Geneva, Arial, Helvetica, sans-serif">Tujuan/Program:</font></td>
<td><TEXTAREA name="tujuan" rows=5 cols=60 required></TEXTAREA><br><font color="#FF0000">*100 patah perkataan sahaja</font></td></tr>
<tr>
<tr>
<td><font size="2" color="#000000" face="Geneva, Arial, Helvetica, sans-serif">Tarikh Program:</font></td>
<td><input type = "date" name="tarikh" value=" <?php echo date('Y-m-d'); ?>
