As soon as I launch the software it crashes.
Faulting application name: AcroRd32.exe, version: 17.9.20058.37826, time stamp: 0x59595c34
Faulting module name: AcroRd32.dll, version: 17.9.20058.37826, time stamp: 0x59595c17
Exception code: 0xc0000005
Fault offset: 0x0005e5a0
Faulting process id: 0x1ce0
Faulting application start time: 0x01d30f815fcf02df
Faulting application path: C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AcroRd32.exe
Faulting module path: C:\Program Files (x86)\Adobe\Acrobat Reader DC\Reader\AcroRd32.dll
Report Id: 56ce5d18-27aa-4734-aa3c-5d9d81371c14
Faulting package full name:
Faulting package-relative application ID:
I have found that if I add a DWORD key bProtectedMode = 0 at HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Adobe\Acrobat Reader\DC\FeatureLockDown then I am able to run the software but only if I run as administrator.
How do I run the software as a non-administrative user?
After trying for several hours I tried setting the disbled protected mode through group policy and it worked.
Now group policy sets the same reg key, which I confirmed, but it still works with GP and not the reg key.
Either it also sets another key as well (I suppose I could open the adm template in a text editor to find out), or maybe it changes the permission of the key.
Either way it now works and I don't much care.
Adobe should really fix protected mode.
While you didn't tell us anything in your "answer" i have found something which fixes my issue.
I had exact the same problem, i found a few years ago online a fix.
it worked for me with different versions of Adobe Reader, now i have used it with version:
2019.008.20080
I add by an policy the following Registery key:
Hive: HKEY_CURRENT_USER
Key path: Software\Adobe\Acrobat Reader\DC\Privileged
Value name: bProtectedMode
Value type: REG_DWORD
Value data: 0x0 (0)
