In Photoshop 2017.1.1 I am trying to place a png. file over top of a jpeg. file and keep getting a pop-up with and error message saysing " Could not place because the source rectangle is empty."
I tried the same with other png. files and it worked.
I tried making a new layer and that did not help either.
The png. file is my watermark, and is fully transparent in some parts and partially transparent in others.
Any ideas?
ScottK
WIndows 7 Professional, Version 6.1
Hi ScottK,
Please take a look t this article Could not place because the source rectangle is empty and let us know if that helps.
Akash
Hi Akashm,
I went to Preferences and clicked on "Reset Preferences On Quit", but that did not help.
I just tried resetting the colour to RGB from Interlaced but that did not help.
I just noticed that I cannot use this watermark anyhow. It was made for Stockbox Photo software to automatically place it over images, and it worked fine on my web-site. Problem is sort of solved for now.
Scott
I tried Lightroom and it inserting the png. file worked fine!
Why is MrDill marked the answer? That does not provide a fix for the error received in Photoshop nor does it explain why this error is happening...
Same for "Place" issues... my resolution was weird... like 30000x30000 inches by 1 pixel for supposed 1920x1080 (72dpi) footage. Changed the resolution to 1920x1080 - 72 dpi... try placing and... Voilà ! It works. I guess it's time to make a batch to convert all footage to appropriate resolution.
I put my picture in powerpoint and saved the picture again and then imported to photoshop and it worked
