• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
illustrator javascript for "Identify overset text in a text frame and reduce the font size"
Community Beginner ,
Aug 07, 2017 Aug 07, 2017
HI All
I have a illustrator document contain lot of  text frames. Some of the text frames content over-set text.( half portion of text is hidden)
I already using the java script to change the text frame height I have attached script and screen shot for your reference.
var includeExtraLines = 0.5;
if(documents.length > 0) {
    doc = activeDocument;
    mySelection = activeDocument.selection;
    // If there are enough to process
    if (mySelection instanceof Array)
        // For each of the selected items
        for(i=0; i<mySelection.length; i++) {
            // That are textFrames
            if (mySelection.typename == "TextFrame" && mySelection.kind == TextType.AREATEXT ) {
                obj = mySelection;
                // We only want to do this on rectangular text areas
                // TODO: Take care of rotation issues from MakePointType script
                if( obj.textPath.pathPoints.length == 4 ) {
                    objTop = obj.top;
                    objLeft = obj.left;
                    // Make the new point type object and locate it
                    // Make sure the new object is in the same Z stacking order as the original
                    copy1 = obj.duplicate(obj, ElementPlacement.PLACEBEFORE);
                    //copy1.move(obj, ElementPlacement.PLACEBEFORE);
                    // now make the text box much bigger, but not absurdly big
                    // TODO: This could be better approximated by itterating thru all the WORDS in the textFrame and
                    // comparing it to all the WORDS in each of the visible text LINES. Then apply the difference / total words to the scaling
                    if( copy1.height * 10 < 2000 ) {
                        copy1.textPath.height = copy1.height * 10;
                    } else {
                        copy1.textPath.height = 2000;
                    howManyLines = copy1.lines.length;
                    outlineObject = copy1.duplicate();
                    outlineObject = outlineObject.createOutline();
                    targetHeight = outlineObject.height + includeExtraLines * (outlineObject.height / howManyLines );
                    // Now assign y-axis depth of the point text to the area text box
                    rect = obj.parent.pathItems.rectangle(copy1.textPath.top, copy1.textPath.left, obj.width, targetHeight);
                    copy2 = obj.parent.textFrames.areaText(rect);
                    copy2.selected = true;
                    rect.selected = true;
                    // Always delete these intermediate objects
                    outlineObject.remove();
                    copy1.remove();
                    // Now take care of the end and original objects
                    obj.textRange.duplicate(copy2);
                    obj.remove();
But I need to reduce the overset  text frame font size.
Please advise me
Thanks in advance.
Ashok
TOPICS
Scripting
Views
3.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Enthusiast , Aug 17, 2017 Aug 17, 2017
This function can apply to all textFrames.
function reduceSizeOfOversetText(t) {
    var d;
    while (
        d = t.duplicate(),
        d.name = 'temp',
        d.convertAreaObjectToPointObject(),
        d = t.parent.textFrames['temp'],
        d.contents.replace(/[\x03\r]/g, '') !== t.contents.replace(/[\x03\r]/g, '')
        d.remove();
        t.textRange.characterAttributes.size -= 1;
    d.remove();
reduceSizeOfOversetText(app.selection[0]);
Another way: you can create an temp textFrame
Votes
Translate
Translate
Adobe
Valorous Hero ,
Let's make a text overset function which detects the overset on multiline text.
There may be several ways to accomplish this, I am thinking of the following:
  1. Read the text of the entire text area and take note of it in a variable.
  2. Go through every line of the text area and replace the text in the variable previously defined by taking the line's text and removing it from the text contents.
  3. If all the lines were showing without overset, the result of the contents variable should be an empty string.
  4. If there was overset, then some of the contents did not get replaced by some of the lines which were hidden below the frame.
Here is a snippet to start you off:
#target illustrator
function test(){
  var doc = app.activeDocument;
  var sel = doc.selection[0];
  var contents = sel.contents;
  for(var i = 0; i < sel.lines.length; i++){
    contents = contents.replace(sel.lines.contents, "");
  alert(contents);
test();
Votes
Translate
Translate
Report
Report
Aug 08, 2017 Aug 08, 2017
Thank you for your reply. the above code is for selected text frame(frame need to selected manually) but my request is in an illustrator document where there are more than 100 textframes and i need to identify the overset text and reduce the fontsize of the overset text in all the 100 text frame.
Kindly help me on this please.
Regards
Ashok
Votes
Translate
Translate
Report
Report
Hi Silly-V
As per your guidance selected text frame overset text is showing correctly. but i want to identify the overset text and reduce the font to fix the overset text.below code shows only the entire line like screenshot & code attached below.
function texts(){
   var docRef = activeDocument;
   // clear the old selection
   var piArr=[];
   activeDocument.selection = null;
  //var contents = sel.contents;
   // select all text art items that contain the target string
   for (j = 0; j < docRef.textFrames.length; j++){
  // var t=docRef.textFrames
//var t=docRef.textFrames
contents=t.contents
        for(var i = 0; i < t.lines.length; i++){
          contents = contents.replace(t.lines.contents, "");
//piArr.push(contents);
alert(contents)
   //   alert(t.textRange.size);
       if(contents!=""){
        var fs=t.textRange.size
         if (fs<=6)
alert(fs+"small font"+"Still overset")
//exit();
else
   t.textRange.characterAttributes.size = fs-1
   s()
else
//contentString = docRef.textFrames.contents;//  contentString.lines.length;
// var contents = docRef.textFrames.contents;
  //contentString.length;
function s(){
if(piArr=="")
    exit()
    }else{
   alert("still overset")
texts()
   //redraw();
texts()
Regards
Ashok
Votes
Translate
Translate
Report
Report
Enthusiast ,
    var d;
    while (
        d = t.duplicate(),
        d.name = 'temp',
        d.remove();
    d.remove();
Another way: you can create an temp textFrame and set .nextFrame property to it, then compare TextFrame's contents to Story's contents.
Votes
Translate
Translate
Report
Report
Valorous Hero ,
Hey, nice job! what is the character "\x03" ?
Votes
Translate
Translate
Report
Report
Enthusiast ,
So called "soft return"? Use centents.toSource() to get it.
When convert area text to point text, line end will add a soft return, and if orginal line end is soft return, it will convert to hard return.
Votes
Translate
Translate
Report
Report
Aug 24, 2017 Aug 24, 2017
Thank you so much for your help.
But the script only run on selected text frame.
i want to identify the overset text and reduce the font size for all overset text frames.
#target illustrator
function test(){
alert(contents);
test();
        var d;
        while (
            d = t.duplicate(),
            d.name = 'temp',
            d.remove();
        d.remove();
kindly help on this.
Regards
Ashok
Votes
Translate
Translate
Report
Report
Community Expert ,
Feb 27, 2023 Feb 27, 2023
LATEST
Hi all, for anyone finding this old thread, also please have a look at @femkeblanco's answer here. - Mark
Votes
Translate
Translate
Report
Report
