5 Replies Latest reply on Dec 24, 2008 11:39 AM by beian_smith
    Unable To Install Dreamweaver CS4 Trial
    beian_smith
      I downloaded Adobe Dreamweaver CS4 30 day trial and was interested in trying it out and to compare it to other similar software. Unfortunately when I try to install, it installs kuler, anchor service and everything else fine apart from Dreamweaver.
      It fails and I click more info and it says "Adobe Dreamweaver CS4 : Fatal Error Occured During Installation Error 1603" (or something similar to that but definately fatal 1603).
      I searched this forum and many others and went on every google link up to page 5 and tried all the posted solutions but none of them worked. I made a log and found where it was going wrong (I think) but i don't know what any of it mean so have put it below.
      MSI (s) (F4:98) [13:27:07:562]: Error in rollback skipped. Return: 5
      MSI (s) (F4:98) [13:27:07:578]: No System Restore sequence number for this installation.
      MSI (s) (F4:98) [13:27:07:578]: Unlocking Server
      MSI (s) (F4:98) [13:27:07:968]: PROPERTY CHANGE: Deleting UpdateStarted property. Its current value is '1'.
      Action ended 13:27:07: InstallFinalize. Return value 3.
      Action ended 13:27:07: INSTALL. Return value 3.
      Property(S): AdobeCode = {289C46A2-F2F7-4887-A8DA-5CB1AB65754D}
      Property(S): ProductName = Adobe Dreamweaver CS4
      This is part of the log. I would post it all but it is about 20mb. If i posted the wrong part of the log, I shall upload the full log somehow (any suggentions would be great).
      Please help. Thanks.
        • 1. Re: Unable To Install Dreamweaver CS4 Trial
          coding_funky
          Do you have an acer pc? i had the very same problem 2 days ago.
          • 2. Re: Unable To Install Dreamweaver CS4 Trial
            Level 7
            If you're using an Acer computer, there's a known conflict between
            Dreamweaver and Acer eDataSecurity Management V3.0. You can find a patch
            here:
            http://www.egistec.com/oem-acer001/program-update.html
            David Powers, Adobe Community Expert
            Author, "The Essential Guide to Dreamweaver CS4",
            "PHP Solutions" & "PHP Object-Oriented Solutions"
            http://foundationphp.com/
            • 3. Unable To Install Dreamweaver CS4 Trial
              beian_smith Level 1
              No, I have an IBM. Thanks for the suggention though. Dreamweaver used to work until I did a system restore of my computer.
              Does anyone understand this log??? I read somewhere that the problem could be solved by posting your log on a forum and people could analyze to problem from there because 1603 is a general error and could mean many things. Thanks to any more contributers who would like to help me.
              • 4. Unable To Install Dreamweaver CS4 Trial
                beian_smith Level 1
                I've just been on Google and it says this could be beacause of my specs. I definately have enough though. (2GB ram 3GHZ processor, 20GB free Hard Drive space).
                • 5. Re: Unable To Install Dreamweaver CS4 Trial
                  beian_smith Level 1
                  I think I know the problem but not how to solve it:
                  MSI (s) (F4:98) [13:27:09:656]: Product: Adobe Dreamweaver CS4 -- Installation operation failed.
                  MSI (s) (F4:98) [13:27:09:656]: Windows Installer installed the product. Product Name: Adobe Dreamweaver CS4. Product Version: 10.0. Product Language: 0. Installation success or error status: 1603.
                  MSI (s) (F4:98) [13:27:09:750]: Attempting to delete file C:\WINDOWS\Installer\282d1b.mst
                  MSI (s) (F4:98) [13:27:09:765]: Unable to delete the file. LastError = 32
                  MSI (s) (F4:98) [13:27:09:781]: Cleaning up uninstalled install packages, if any exist
                  MSI (s) (F4:98) [13:27:09:781]: Attempting to delete file C:\WINDOWS\Installer\282d1b.mst
                  MSI (s) (F4:98) [13:27:09:781]: MainEngineThread is returning 1603
                  MSI (s) (F4:28) [13:27:09:796]: No System Restore sequence number for this installation.
                  === Logging stopped: 22/12/2008 13:27:09 ===
                  MSI (s) (F4:28) [13:27:09:843]: User policy value 'DisableRollback' is 0
                  MSI (s) (F4:28) [13:27:09:843]: Machine policy value 'DisableRollback' is 0
                  MSI (s) (F4:28) [13:27:09:843]: Incrementing counter to disable shutdown. Counter after increment: 0
                  MSI (s) (F4:28) [13:27:09:843]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
                  MSI (s) (F4:28) [13:27:09:843]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
                  MSI (s) (F4:28) [13:27:09:843]: Restoring environment variables
                  MSI (c) (C0:D0) [13:27:09:843]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
                  MSI (c) (C0:D0) [13:27:09:843]: MainEngineThread is returning 1603
                  === Verbose logging stopped: 22/12/2008 13:27:09 ===
                  The bit that I think is causing the problem is the MainEngineThread because it says "MainEngineThread is returning 1603"
                  Any solutions would be greatly appreciated.
