1 Reply Latest reply on Aug 17, 2017 5:29 PM by erick41218978
    Anyone else having problems with facebookads-plugin?
    erick41218978 Level 1
      Currently trying to get Facebook Audience plugin to install but builds keep failing for Android. Any help would be helpful.
      GitHub - floatinghotpot/cordova-plugin-facebookads: Cordova/PhoneGap plugin for Facebook Audience Network Ads
      Log files below:
      Build Date: 2017-08-07 23:07:19 +0000
      Subproject Path: CordovaLib
      Configuration on demand is an incubating feature.
      Incremental java compilation is an incubating feature.
      :preBuild UP-TO-DATE
      :preReleaseBuild UP-TO-DATE
      :checkReleaseManifest
      :preDebugBuild UP-TO-DATE
      :CordovaLib:preBuild UP-TO-DATE
      :CordovaLib:preDebugBuild UP-TO-DATE
      :CordovaLib:checkDebugManifest
      :CordovaLib:prepareDebugDependencies
      :CordovaLib:compileDebugAidl
      :CordovaLib:compileDebugNdk UP-TO-DATE
      :CordovaLib:compileLint
      :CordovaLib:copyDebugLint UP-TO-DATE
      :CordovaLib:mergeDebugShaders
      :CordovaLib:compileDebugShaders
      :CordovaLib:generateDebugAssets
      :CordovaLib:mergeDebugAssets
      :CordovaLib:mergeDebugProguardFiles
      :CordovaLib:packageDebugRenderscript UP-TO-DATE
      :CordovaLib:compileDebugRenderscript
      :CordovaLib:generateDebugResValues
      :CordovaLib:generateDebugResources
      :CordovaLib:packageDebugResources
      :CordovaLib:processDebugManifest
      :CordovaLib:generateDebugBuildConfig
      :CordovaLib:processDebugResources
      :CordovaLib:generateDebugSources
      :CordovaLib:incrementalDebugJavaCompilationSafeguard
      :CordovaLib:compileDebugJavaWithJavac
      :CordovaLib:compileDebugJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      Note: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      :CordovaLib:processDebugJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForDebug
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
      :CordovaLib:mergeDebugJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
      :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
      :CordovaLib:bundleDebug
      :CordovaLib:preReleaseBuild UP-TO-DATE
      :CordovaLib:checkReleaseManifest
      :CordovaLib:prepareReleaseDependencies
      :CordovaLib:compileReleaseAidl
      :CordovaLib:compileReleaseNdk UP-TO-DATE
      :CordovaLib:copyReleaseLint UP-TO-DATE
      :CordovaLib:mergeReleaseShaders
      :CordovaLib:compileReleaseShaders
      :CordovaLib:generateReleaseAssets
      :CordovaLib:mergeReleaseAssets
      :CordovaLib:mergeReleaseProguardFiles
      :CordovaLib:packageReleaseRenderscript UP-TO-DATE
      :CordovaLib:compileReleaseRenderscript
      :CordovaLib:generateReleaseResValues
      :CordovaLib:generateReleaseResources
      :CordovaLib:packageReleaseResources
      :CordovaLib:processReleaseManifest
      :CordovaLib:generateReleaseBuildConfig
      :CordovaLib:processReleaseResources
      :CordovaLib:generateReleaseSources
      :CordovaLib:incrementalReleaseJavaCompilationSafeguard
      :CordovaLib:compileReleaseJavaWithJavac
      :CordovaLib:compileReleaseJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      :CordovaLib:processReleaseJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForRelease
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease
      :CordovaLib:mergeReleaseJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForRelease
      :CordovaLib:transformNative_libsWithSyncJniLibsForRelease
      :CordovaLib:bundleRelease
      :prepareComAndroidSupportAnimatedVectorDrawable2531Library
      :prepareComAndroidSupportAppcompatV72531Library
      :prepareComAndroidSupportCardviewV72531Library
      :prepareComAndroidSupportCustomtabs2531Library
      :prepareComAndroidSupportRecyclerviewV72531Library
      :prepareComAndroidSupportSupportCompat2600Alpha1Library
      :prepareComAndroidSupportSupportCoreUi2600Alpha1Library
      :prepareComAndroidSupportSupportCoreUtils2600Alpha1Library
      :prepareComAndroidSupportSupportFragment2600Alpha1Library
      :prepareComAndroidSupportSupportMediaCompat2600Alpha1Library
      :prepareComAndroidSupportSupportV132340Library
      :prepareComAndroidSupportSupportV42600Alpha1Library
      :prepareComAndroidSupportSupportVectorDrawable2531Library
      :prepareComFacebookAndroidAudienceNetworkSdk4250Library
      :prepareComFacebookAndroidFacebookAndroidSdk4250Library
      :prepareComGoogleAndroidExoplayerExoplayerR203Library
      :prepareComGoogleAndroidGmsPlayServicesAds1102Library
      :prepareComGoogleAndroidGmsPlayServicesAdsLite1102Library
      :prepareComGoogleAndroidGmsPlayServicesAnalytics1102Library
      :prepareComGoogleAndroidGmsPlayServicesAnalyticsImpl1102Library
      :prepareComGoogleAndroidGmsPlayServicesBase1102Library
      :prepareComGoogleAndroidGmsPlayServicesBasement1102Library
      :prepareComGoogleAndroidGmsPlayServicesClearcut1102Library
      :prepareComGoogleAndroidGmsPlayServicesGass1102Library
      :prepareComGoogleAndroidGmsPlayServicesGcm1102Library
      :prepareComGoogleAndroidGmsPlayServicesIid1102Library
      :prepareComGoogleAndroidGmsPlayServicesSafetynet1102Library
      :prepareComGoogleAndroidGmsPlayServicesTagmanagerV4Impl1102Library
      :prepareComGoogleAndroidGmsPlayServicesTasks1102Library
      :prepareMeLeolinShortcutBadger1114Library
      :prepareProjectCordovaLibUnspecifiedReleaseLibrary
      :compileReleaseAidl
      :mergeReleaseResources
      :processReleaseManifest/project/AndroidManifest.xml:27:9-38 Error:
      Attribute meta-data#android.support.VERSION@value value=(26.0.0-alpha1) from [com.android.support:support-v4:26.0.0-alpha1] AndroidManifest.xml:27:9-38
      is also present at [com.android.support:appcompat-v7:25.3.1] AndroidManifest.xml:27:9-31 value=(25.3.1).
      Suggestion: add 'tools:replace="android:value"' to <meta-data> element at AndroidManifest.xml:25:5-27:41 to override.
      See http://g.co/androidstudio/manifest-merger for more information about the manifest merger.
      :processReleaseManifest FAILED
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':processReleaseManifest'.
      > Manifest merger failed : Attribute meta-data#android.support.VERSION@value value=(26.0.0-alpha1) from [com.android.support:support-v4:26.0.0-alpha1] AndroidManifest.xml:27:9-38
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 5.203 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      * What went wrong:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at maybeClose (internal/child_process.js:877:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
