1 Reply Latest reply on Aug 8, 2017 2:15 AM by try67
    Create CC address from field value
    Clarkopolous Level 1
      I am creating a form which will be submitted via email. I need the form to CC an email address based on a field value.
      I need it to be based on: field = employee ID then cc the email address for the particular ID
      I've currently got the rest of it working. Just want to add in this CC function to streamline a process.
      so far I've got:
      var Subject = getField("fieldname").value;
      cTo: "email address",
      cSubject: "Additonal text"=Subject,
      cSubmitAs: "PDF"
        • 1. Re: Create CC address from field value
          You should read the full documentation of the mailDoc method... There's a built-in parameter that allows you to do that, called cCc.
          So your could would be:
          var Subject = this.getField("fieldname").value;
          var ccAddress = this.getField("employee ID").value;
               bUI: false,
               cCc: ccAddress
               cSubject: "Additonal text"+Subject,
          I also fixed some other mistakes you had in your code...
