4 Replies Latest reply on Aug 8, 2017 8:39 AM by Dale_
    List subfolders in a function
    Dale_ Level 1
      I want to add a small function to a script that logs the name of every subfolder in the root folder/parent folder of the one I am working from.
      Here is what I have so far:
      var docRef = app.activeDocument;
      var sourceFolder = Folder (docRef.path);
      var sourceName = sourceFolder.name;
      var rootFolder= Folder (sourceFolder.path);
      var rootName = rootFolder.name;
      function sLog (){
          var folderName = String(rootFolder.name);
          var sub = folderName.includeSubFolders;
          alert (sub);
      sLog();
      I want the alert to be able to list every folder.
      Any ideas?
        • 1. Re: List subfolders in a function
          SuperMerlin Level 5
          Something like this.
          #target photoshop;
          var folders =[];
          var topLevel = Folder.selectDialog("Please select top level folder");
          folders = FindAllFolders(topLevel, folders);
          folders.unshift(topLevel);
          alert(folders.join("\n"));
          function FindAllFolders( srcFolderStr, destArray) {
              var fileFolderArray = Folder( srcFolderStr ).getFiles();
              for ( var i = 0; i < fileFolderArray.length; i++ ) {
                  var fileFoldObj = fileFolderArray[i];
                  if ( fileFoldObj instanceof File ) {
                  } else {
                   destArray.push( Folder(fileFoldObj) );
                  FindAllFolders( fileFoldObj.toString(), destArray );
              return destArray;
          • 2. Re: List subfolders in a function
            Dale_ Level 1
            Cheers Merlin, this result includes the full path.
            Any ideas on how to remove the path "~/Documents/Base/FileName" so it just shows "FileName" for the list?
            • 3. Re: List subfolders in a function
              SuperMerlin Level 5
              #target photoshop;
              var folders =[];
              var List = [];
              for(var a in folders){List.push(decodeURI(folders[a].name));}
              alert(List.join("\n"));
                      } else {
                  return destArray;
