1 Reply Latest reply on Aug 9, 2017 5:36 AM by Steve Grisetti
    Footage looks bad after import - highlights are blown out.  PE12
    bazzshot
      When I import footage into the Organizer or into Premiere Elements 12 Expert edit, it comes in with all the highlights blown out to the point where it's almost unusable! Can anyone help me out here?  The footage looks fine in Lightroom and when viewed directly from the USB drive it's stored on but when I import it, Premiere is doing something to it that ruins it!!
      I'm using a PC with Windows 10, 64 bit.  The raw footage is .mp4 shot at 30fps.
        • 1. Re: Footage looks bad after import - highlights are blown out.  PE12
          When you add your first clip to your timeline in Expert view, do you see a yellow-orange "render" line above the clip on your timeline?
          If you don't see this line, then the project settings match your video specs and you are seeing a video that has no changes made to it by Premiere Elements. The blow-outs could be related to your monitor settings -- or Premiere Elements preview. Right-click on the Premiere Elements Monitor panel and set the view to highest quality.
          But until you add effects to your video, Premiere Elements is not changing it in any way.
