Hey guys, I'm quite new to this forum and I was just wondering if I could get some help? My Illustrator CC 2017 crashes when I open up any kind of file, and it doesnt even have an error report or anything of the sort, it just freezes up and I have to force quit it. I thought it might be my computer being slow but I left it on overnight and still to no avail. I've tried reinstalling throught the Creative Cloud app thing, is there anything else I can do?
Cheers! Avi.
This actually solved my problem. I did this, just in case anyone is having the same problem (in Windows)
1) Open your Printers & Scanners settings
2) Uncheck the checkbox that let Windows manage your default printer
3) Click on the "Microsoft Print to PDF" (or however is called in your version)
4) Select "Manage"
5) Select "Set as Default"
6) Open the program
It worked for me, hope it helps
Avi,
You may have a look at especially Clause B) below, and failing that, on the list.
If things that should work simply refuse to (all possibilities exhausted including the A) - C) below (and carefully making sure you are performing (all) the needed things)), you may try (the relevant part(s) of) the list 1) - 6) below.
Sometimes, (certain) things may fail or stop working for no apparent reason. When the (other) possible reasons/cures fail to work, it may be some kind of (temporay or permanent) corruption, or even some inconvenient preference setting(s), which may be cured with something on the following list set up in an attempt to provide a catchall solution for otherwise unsolvable cases. It starts with a few easy and harmless suggestions 1) and 2) for milder cases, and goes on with two alternative ways 3) and 4) of resetting preferences to the defaults (easily but irreversibly and more laboriously but more thoroughly and also reversibly), then follows a list 5) of various other possibilities, and it ends with a full reinstallation 6). If no other suggestions work, or if no other suggestions appear, you may start on the list and decide how far to go and/or which may be relevant.
The following is a general list of things you may try when
A) The issue is not in a specific file,
B) You have a printer correctly installed, connected, and turned on if it is physical printer (you may use Adobe PDF/Acrobat Distiller as the default printer with no need to have a printer turned on, obviously you will need to specify when you actually need to print on paper), and
C) It is not caused by issues with opening a file from external media.
You may have tried/done some of them already; 1) and 2) are the easy ones for temporary strangenesses, and 3) and 4) are specifically aimed at possibly corrupt/inconvenient preferences); 5) is a list in itself, and 6) is the last resort.
If possible/applicable, you should save current artwork first, of course.
1) Close down Illy and open again;
2) Restart the computer (you may do that up to at least 5 times);
3) Close down Illy and press Ctrl+Alt+Shift/Cmd+Option+Shift during startup (easy but irreversible);
4) Move the folder (follow the link with that name) with Illy closed (more tedious but also more thorough and reversible), for CS3 - CC you may find the folder here:
https://helpx.adobe.com/illustrator/kb/preference-file-location-illustrator.html
5) Look through and try out the relevant among the Other options (follow the link with that name, Item 7) is a list of usual suspects among other applications that may disturb and confuse Illy, Item 15) applies to CC, CS6, and maybe CS5);
Even more seriously (this may be serious because you may need to restore plugins and whatnot afterwards if you have customized things), you may:
6) A) Uninstall (ticking the box to delete the preferences if applicable), B) run the Cleaner Tool (if you have CS3/CS4/CS5/CS6/CC), and C) reinstall. You may try without step B), but sometimes it is needed, because otherwise things may linger.
As it appears from this thread, it may be worth repeating this if it fails to help the first time:
https://forums.adobe.com/thread/2283530
To uninstall:
Cleaner Tool:
Which version, which system?
In many cases this is caused by not having a printer connected. So first make sure you have a printer and it is turned on and set up as the default printer. If you don't have a printer, set up a PDF printer. On WIndows there is one already installed. On Mac OS, installing a PDF printer might get really complicated.
Printer queues may also cause errors.
4) Select "Manage"
6) Open the program
If the printer option didn't work, you could try disabling some of your display adapters in the device manager. All of my adobe products kept crashing until I disabled my Radeon display adapter.
