2 Replies Latest reply on Nov 8, 2017 4:55 AM by kulpreet singh
    Question about GeForce GTX 1080 Ti render with CUDA
    padermsaks21678672 Level 1
      I have Geforce GTX 1080Ti as GPU
      My pc build is
      Ryzen 7 1700(3.9ghz)
      Ram 32 GB Bus 2400
      Window 10 Home 64 bit
      Nvidia Driver version 384.94
      I've rendering My video at 1920x1080
      with Adobe media encoder using CUDA
      My GPU load peak at 27% (usually at 0-20%) Monitor with HWMonitor
      I've Tried To render Without using CUDA same project i used almost 1 hour 20 mins
      in CUDA enable is 1 hour  10 mins
      Is it Normal?
        • 1. Re: Question about GeForce GTX 1080 Ti render with CUDA
          Peru Bob Adobe Community Professional & MVP
          It may very well be normal.  Not all effects are GPU accelerated.
          What are your source media file types and codecs and sequence settings?
          What effects are applied?
          • 2. Re: Question about GeForce GTX 1080 Ti render with CUDA
            kulpreet singh Adobe Employee
            Hi Padermsaks21678672,
            Encoding is a CPU centric process in Premiere Pro & Adobe Media Encoder.
            Some effects can take advantage of the processing power of a certified graphics card to accelerate rendering.
            The GPU will only accelerate the following in the export process: scaling, frame conversion, blending modes, deinterlacing, and color space conversion.
            The GPU will also accelerate the processing of GPU based video effects, including the Lumetri color effect.
            Example:
                • If you are encoding a 4K file to a 4K HEVC H.265 file, GPU acceleration is not engaged in the exporting process because no scaling was used.
                • If you are encoding a 4K file to a HD H.264 file, the GPU acceleration is engaged in the exporting process because scaling was needed.
            If your GPU is disabled or "grayed out" and it has capable specs, then that is a different troubleshooting problem.
            Check this for more information: GPU-accelerated effects
            Kulpreet Singh
