Am trying to use a plugin that I recently installed for After effects but when I try and use it I get this message (see img below). I installed to plugin into the ScriptUI Panels folder in my ae applications folder as instructed by the plugin. The plugin is called Ouroboros v2.
Any help would be much appreciated, thanks
There is a setting you need to check in the General section of the Preferences that allows scripts to write.
Hi Rick
Yes I have found the right check box and it works now thank you
