3 Replies Latest reply on Jun 29, 2008 8:41 PM by Newsgroup_User
    Volume linked to cursor proximity
    Bob220867
      Hi
      What I want to achieve is that the cursor (or a sprite controlled by cursor keys) dictates the volume of a soundfile by it's proximity to a 'place' sprite, i.e. when the cursor gets within a certain radius of the sprite it starts the soundfile playing and then as it gets nearer it gets louder.
      Not being good these things I would normally get the place sprite to test for whether the cursor is near it by checking above, below and on each side. However, I presume there must be a basic trigonometric thing where I can work out the radius and use that. Any ideas on this or a better approach would be appreciated.
      Many thanks
      Bob
        • 1. Re: Volume linked to cursor proximity
          Level 7
          property spriteNum
          on exitFrame me
          -- calculates the distance between the cursor
          -- and the registration point, using
          -- Pythagorean theorem:
          -- a squared plus b squared equals c squared
          a = abs(sprite(spriteNum).locH - the mouseH)
          b = abs(sprite(spriteNum).locV - the mouseV)
          c = sqrt (a * a + b * b)
          put c
          end
          • 2. Re: Volume linked to cursor proximity
            Level 7
            FWIW, there's no need to take the absolute value since when squared the
            result will always be positive (ignoring imaginary numbers...)
            • 3. Re: Volume linked to cursor proximity
              Level 7
              True, good point. Given that this is executing on every exitFrame event,
              one less function call could improve performance. So
              property spriteNum
              on exitFrame me
              a = sprite(spriteNum).locH - the mouseH
              b = sprite(spriteNum).locV - the mouseV
              put c
              end
              Bob, you should be able to replace the "put c" line with your own code
              to adjust the volume depending on the value of c.
