• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
script to move and copy an object with opacity mask
Community Beginner ,
Aug 09, 2017 Aug 09, 2017
I have script which can help me to move and copy an object, but I just found that it can not copy the object with opacity mask.
it is there anyone have any idea to solve this problem.
maybe we can used adobe action, but it only can copy 1 time, however, usually  we need copy more than 10 times..
function dup(sel,item,qty,tran1,tran2){
  for (var i=0; i<[qty]; i++){
  sel[item].duplicate();
  sel[item].translate(tran1,tran2);
TOPICS
Scripting
Views
1.8K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Valorous Hero , Aug 10, 2017 Aug 10, 2017
Sorry to say, but this can be done in a way that is not so easy: it can be done with a dynamic action. See this thread: Creating a dynamic action to use with app.doScript() method.
Simply put, opacity masks do move when used with the regular Move dialog (ctrl + shift + M), and when a move action is recorded and played back. With a script you can write your own move action by placing your own numbers where the numbers would go. You do this by recording a couple instances of the manual action move
Votes
Translate
Translate
Adobe
Valorous Hero ,
Simply put, opacity masks do move when used with the regular Move dialog (ctrl + shift + M), and when a move action is recorded and played back. With a script you can write your own move action by placing your own numbers where the numbers would go. You do this by recording a couple instances of the manual action move command with different parameters in the dialog. By analyzing the differences in the .aia files, you can tell which part corresponds with the various parameters you need.
Votes
Translate
Translate
Report
Report
Enthusiast ,
Aug 11, 2017 Aug 11, 2017
Other methods:
  • Create a symbol from the object, then copy/move the symbol item
  • Apply a transform effect, then expand the effect
  • Copy, change center of view to desired position, paste
Votes
Translate
Translate
Report
Report
Sep 11, 2017 Sep 11, 2017
LATEST
thanks all,  both of your methods is helpful for me. the action method and transform effect are great.
Votes
Translate
Translate
Report
Report
