13 Replies Latest reply on Mar 8, 2018 5:51 AM by pedrog8756632
    Shuffle selected layers only
    mubashara78943322 Level 1
      Hi.. Can you please tell me the script to shuffle randomly "Selected Layers" only. Which may or may not be in a layerset. I just want to shuffle only my selected layers, not the whole document layers. Thank you very much
      c.pfaffenbichler SuperMerlin
        • 1. Re: Shuffle selected layers only
          Adobe Photoshop Scripting | Adobe Developer Connection
          User here try to help you.  We all have different abilities.   You can use script other provide you should not expect that someone will be willing to program a script that will work with the next document structure you come up with and automate what you want to do.   You would need to design a script to implement your what you want to do.  You would need to design some document structure that would work with the script you designed and programmed.  Scripting is programming not a simple recorded and edit action.
          Script can be very powerful. If you look at a Plug-in script like Image Processor Pro you will see it contains 10,000+ lines of code that is not something you develop quickly.  Layer Comps to files is over 2,500 line of code and much more flexible then the custom script SuperM programmed for you.   Scripting is powerful programming a script is more work than you can handle. Scripting Photoshop is not simple and easy.  Some thing can be done with little code but thay are usually very simple and specific.
          • 2. Re: Shuffle selected layers only
            SuperMerlin Level 5
            Please try this...
            #target photoshop;
            app.bringToFront();
            if(documents.length) app.activeDocument.suspendHistory('Shuffle Layers', 'main()');
            function main(){
            try{
            var list = getSelectedLayersIdx();
            if(list.length < 2){
                alert("You need to select two or more layers!");
                return;
            var IDs = [];
            for (var a in list){IDs.push(getLayerIDbyIndex(Number(list[a])));}
            var shuffleIDs = shuffle(IDs);
            for(var k = 0;k<shuffleIDs.length;k++){
                selectLayerById(Number(shuffleIDs[k]));
                moveActiveLayerToIndex (Number(shuffleIDs[(shuffleIDs.length - (k + 1))]));
            }catch(e){$.writeln(e + "\n" + e.line);}
            function moveActiveLayerToIndex (ID){
             var desc2 = new ActionDescriptor();
                    var ref3 = new ActionReference();
                    ref3.putEnumerated( charIDToTypeID('Lyr '), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
                desc2.putReference( charIDToTypeID('null'), ref3 );
                    var ref4 = new ActionReference();
                    ref4.putIndex( charIDToTypeID('Lyr '), getLayerIndexByID(ID) );
                desc2.putReference( charIDToTypeID('T   '), ref4 );
                desc2.putBoolean( charIDToTypeID('Adjs'), false );
                desc2.putInteger( charIDToTypeID('Vrsn'), 5 );
                executeAction( charIDToTypeID('move'), desc2, DialogModes.NO );
            function selectLayerById(id,add){
            var ref = new ActionReference();
            ref.putIdentifier(charIDToTypeID('Lyr '), id);
            var desc = new ActionDescriptor();
            desc.putReference(charIDToTypeID("null"), ref );
            if(add) desc.putEnumerated( stringIDToTypeID( "selectionModifier" ), stringIDToTypeID( "selectionModifierType" ), stringIDToTypeID( "addToSelection" ) );
            desc.putBoolean( charIDToTypeID( "MkVs" ), false );
            try{
            executeAction(charIDToTypeID("slct"), desc, DialogModes.NO );
            }catch(e){}
            function getLayerIndexByID(ID){
            ref.putIdentifier( charIDToTypeID('Lyr '), ID );
            try{
            activeDocument.backgroundLayer;
            return executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" ))-1;
            }catch(e){
            return executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" ));
            function shuffle(array) {
              var currentIndex = array.length, temporaryValue, randomIndex;
              while (0 !== currentIndex) {
                randomIndex = Math.floor(Math.random() * currentIndex);
                currentIndex -= 1;
                temporaryValue = array[currentIndex];
                array[currentIndex] = array[randomIndex];
                array[randomIndex] = temporaryValue;
              return array;
            function getSelectedLayersIdx(){
                  var selectedLayers = new Array();
                  var backGroundCounter = 1;
                        if(activeDocument.artLayers.length > 0){
                        backGroundCounter = activeDocument.artLayers[activeDocument.artLayers.length - 1].isBackgroundLayer ? 0 : 1;
                  ref.putProperty(charIDToTypeID("Prpr"), stringIDToTypeID("targetLayers"));
                  ref.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                  var desc = executeActionGet(ref);
                  if( desc.hasKey( stringIDToTypeID( "targetLayers" ) ) ){
                     desc = desc.getList( stringIDToTypeID( "targetLayers" ));
                      var c = desc.count;
                      for(var i=0;i<c;i++){
                           selectedLayers.push(  desc.getReference( i ).getIndex() +backGroundCounter );
                  if(app.version.match(/^\d+/) > 15) return selectedLayers ;
                   }else{
                     ref.putProperty( charIDToTypeID("Prpr") , charIDToTypeID( "ItmI" ));
                     ref.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                     if(!backGroundCounter){
                        selectedLayers.push( executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" )) -1);
                        }else{
                            selectedLayers.push( executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" )));
                 var vis = app.activeDocument.activeLayer.visible;
                    if(vis == true) app.activeDocument.activeLayer.visible = false;
                    var desc9 = new ActionDescriptor();
                var list9 = new ActionList();
                var ref9 = new ActionReference();
                ref9.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                list9.putReference( ref9 );
                desc9.putList( charIDToTypeID("null"), list9 );
                executeAction( charIDToTypeID("Shw "), desc9, DialogModes.NO );
                if(app.activeDocument.activeLayer.visible == false) selectedLayers.shift();
                    app.activeDocument.activeLayer.visible = vis;
                  return selectedLayers;
            function getLayerIDbyIndex(idx) {
            ref.putIndex( charIDToTypeID( "Lyr " ), idx );
            return executeActionGet(ref).getInteger(stringIDToTypeID( "layerID" ));
            function getNameByID(ID) {
                ref.putProperty( charIDToTypeID("Prpr") , charIDToTypeID( "Nm  " ));
                ref.putIdentifier( charIDToTypeID( "Lyr " ), ID );
                return executeActionGet(ref).getString(charIDToTypeID( "Nm  " ));;
            2 people found this helpful
            • 3. Re: Shuffle selected layers only
              SuperMerlin Amazing! Just got what I want.. Thank you so much
              • 4. Re: Shuffle selected layers only
                JJMack These two script (this one, and last one you replied to earlier thread) i direly needed it! I use various script, and these are lot more fast even from photoshop actions.. I use them frequently in my work flow to deliver work to various clients.
                • 5. Re: Shuffle selected layers only
                  pixxxel schubser MVP & Adobe Community Professional
                  Hi @SuperMerlin,
                  I didn't try your code yet.
                  But I don't understand this if-clause
                         }else{
                  if version >15 do something
                  or
                  if version >15 do the same
                  • 6. Re: Shuffle selected layers only
                    If you ask here User will tell you if it can be done with an Action the action will be fasteter than a script. Actions are canned Photoshop steps with the exception of a few conditional codition steps. They  have no plane text logic that  needs to be interpited into machine code and executed.  Action are faster than scripts. However they are not as powerful and flexable as a script can be. So yes you would need a script to loop through your document to do what you want.  If you were asking for help writting a script you will find many willing to help you learn Photoshop scripting better.
                    IMO you have been very lucky that SuperM has done your work for you for free. You are not actually asking for help here which is what these forums are for. You are  asking for other to work for you for free for you are unable the do what you want to do and do not seem to want to learn.  For me that not what there forums were created for.  You most likely do not even read the code posted here for you.  You just use it and do not undetstans alert messages a script may give you. I hope your luck  will continues.  However if you come up with something that is very complex you will most likely fine you luck has run out.
                    • 7. Re: Shuffle selected layers only
                      If you look at the else code you will see the code uses a diffent method in not > 15 it does not return it continues on. Also the way JIVE messes up formatting it is difficult to see where the first If is in the scripts structure. IS that else for that fits if you show?
                      The function always returns selected layers the are three return point in the function.  Reformatted the function  you will see that else is not for the first if.
                      • 8. Re: Shuffle selected layers only
                        SuperMerlin Level 5
                        Photoshop versions upto and including  CS6 need to do a further test to see if only one layer or none is selected, the CC versions have fixed this bug so further testing for a single layer is not required.
                        • 9. Re: Shuffle selected layers only
                          Yes some bugs are fixed new bugs are introduces some by design and other bugs seems to be deemed OK.  Adobe management's  way of supporting Photoshop.
                          • 10. Re: Shuffle selected layers only
                            JJMack  schrieb
                            …  Reformatted the function  you will see that else is not for the first if.
                            OK. I see. It's clear now for me.
                            • 11. Re: Shuffle selected layers only
                              pedrog8756632
                              Is it possible to keep selected the layers after suffle?
                              • 12. Re: Shuffle selected layers only
                                SuperMerlin Level 5
                                #target photoshop;
                                app.bringToFront();
                                function main(){
                                try{
                                    return;
                                var IDs = [];
                                deselectLayers();
                                for(var g = 0;g<shuffleIDs.length;g++){
                                    selectLayerById(Number(shuffleIDs[g]),true);
                                function deselectLayers() {
                                    var desc01 = new ActionDescriptor();
                                        var ref01 = new ActionReference();
                                        ref01.putEnumerated( charIDToTypeID('Lyr '), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
                                    desc01.putReference( charIDToTypeID('null'), ref01 );
                                    executeAction( stringIDToTypeID('selectNoLayers'), desc01, DialogModes.NO );
                                try{
                                }catch(e){}
                                try{
                                }catch(e){
                                    currentIndex -= 1;
                                  return array;
                                          var c = desc.count;
                                       }else{
                                            }else{
                                ref.putProperty( charIDToTypeID("Prpr") , stringIDToTypeID( "layerID" ));
                                • 13. Re: Shuffle selected layers only
                                  pedrog8756632 Level 1
                                  Amazing. Thank you so much SuperMerlin!
