Hi
I have problem with new release 2017.012.20093. When I open a file on hebrew in the application it look good. But If I sent the file to a printer hebrew words flips over.
It true for PDF version 1.5 (Acrobat 6.x). If I opened a file version 1.4 (Acrobat 5.x) it showen correct.
Windows 7/10 64 bit
Hi Alex,
Thanks for providing the files.
My findings:
What type of printer are you sending this to? Printer model and PDL (page description language - PCL, PostScript, etc.?) please!
I personally tried printing a Hebrew PDF file (PDF 1.7) to a Phaser 7500 Adobe PostScript 3 printer with the latest Acrobat update and did not experience the symptoms you are describing.
It might also assist us if you could post your sample PDF files (both PDF 1.5 and PDF 1.4) for us to reproduce your problem.
- Dov
Thank you Dov!
I tried in different printers HP OfficeJet Pro 6960, HP OfficeJet 7000, Cannon Laser printer. I didn't try to print PDF 1.7, but for PDF version 1.5 (Acrobat 6.x) this problem exist.
Also the version 1.4 (Acrobat 5.x) work correct.
I think it depend from PDF file version.
I'll sent you pdf v.1.4, 1.5 on Sunday for test.
I'm looking forward to seeing your files. There shouldn't (famous last words) be any difference in terms of printing based on the PDF version since the printing code in Acrobat doesn't even look at that as a factor for determining what and how the document prints. And I have now tried printing a PDF 1.5 file with Hebrew and again, no problems on my systems with my printers.
- Dov
Hi Alex,
My findings:
The bottom line is that the original V1.5.pdf file was defective in construction (fonts and encodings). It had nothing to do with it being PDF 1.5. Yes, it does print correctly on PostScript devices. And for some reason it did print OK on earlier Acrobat/Reader releases (or at least the Spring 2017 release), but non-PostScript drivers are fairly sensitive to encoding issues and it is likely that one or more fixes in the Summer 2017 release to fix other printing issues on non-PostScript printer required us to be more machmir in terms of providing proper coding information to the driver.
The real fix is to fix whatever is producing these bogus PDF files.
Please advise if you have further questions!
- Dov
Thank you Dov!
