3 Replies Latest reply on Aug 10, 2017 5:51 AM by Sheena Kaul
    No Image after Download
      Hello, I purchased a Picture (File Nr. 110031812), it's an AI-File.
      If I try to open it, I can't see the Image, but a Text-Image with this content:
      "This is an Adobe® Illustrator® file that was saved without PDF content. To place or open this file in other applications, it should be re-saved from Adobe Illustrator with the "Create PDF Compatible File" options turned on. This option is in the Illustrator Native Format Options dialog box, which appears when saving an Adobe Illustrator file using the Save As command."
      There seems to be a problem with the Image File. Where can I get the original Image?
      Kindly Regards
