Expand my Community achievements bar.
We are excited to introduce our latest innovation to enhance the Adobe Campaign user experience — the Adobe Campaign v8 Web User Interface!
SOLVED
Copying a tab in a split
Avatar
Level 2
Hello
Does anyone know if we can copy/duplicate a tab in a split to create an other tab?
thanks
Zelia
1 Accepted Solution
Avatar
Correct answer by
Employee Advisor
Hi Zelia,
It is not possible. You will have to create it manually.
Regards,
Vipul
View solution in original post
Avatar
Correct answer by
Employee Advisor
Hi Zelia,
Regards,
Vipul
Avatar
Level 3
Hi Zeila,
It is not possible with UI. But, if you have good understanding on XML than you can do it by following below steps.
1. Right click on workflow and select "Edit xml source ...."
2. Look for your split activity.
3. look for XML code for existing tab, will look like this
4. Copy and paste the code and save the XML.
PS: This is not a preferred route to do it, as it will require playing with XML code and possibility to corrupt your workflow if something went wrong.
Regards,
Ankur A.
