10 Replies Latest reply on Aug 17, 2017 9:37 AM by Bill Gehrke
    Unusual response from tech team regarding 4k realtime playback
    PrashantMac
      I am facing some serious issue with my new machine to play back realtime 4k RED footage. I keep getting frames drop within couple of secs. I reported this to the customer care and they reverted with a stupid reply without even knowing my hardware details. The reply is as follows:
      Hi Prashant,
      I hope you are doing well,
      As far as I can understand the concern you are having regarding the 4k files to have a real time playback in Premiere pro . there is no 100% surety that the Premiere pro can give you a real-time playback.
      In your case, you can use the proxy workflow  which is design for such conditions
      Please check the link below and follow the same
      https://helpx.adobe.com/premiere-pro/using/proxy-workflow.html
      Regards
      Bhaskar Das
      DVA Support
      The only reason I bought creative package was it was realtime.
      I hand picked this config so that it can play realtime 4k. PP 2015.3 was able to play. Why can't the new one?
      My hardware:
      i7 6900k processor (tried both 3.2 and 4.0 GHz) with water cooler
      64 GB Corsair RAM
      Quadro p4000
      X99 ASUS workstation E motherboard.
      850 watt Corsiar RM power supply
      1TB samsung 850 pro hard dial
      Also 8 TB RAID 0 (zero) hard disk.
      It's connected to LG widescreen 34 inch Wide screen monitor and 4k 10 bit monitor
      I have been using premiere since Premiere 6 5 (before CS and Pro series). But this time it's turning into a big disappointment.
      I have tried every possible thing from reinstalling windows to checking all preferences. Any help will be appreciated
      [Moderator note: moved to best forum]
        • 1. Re: Unusual response from tech team regarding 4k realtime playback
          R Neil Haugen Adobe Community Professional & MVP
          First, "real time playback" is nice when it works, but hardly necessary for most workflows. Second, depending on which format/codec out of that RED, any one computer may do better or worse than you'd "expect". Third, the way you work ... which effects you use, plus any 3rd party plugins & all, WILL affect how the playback works.
          This last is where a lot of people hit a wall ... they say plop Warp Stabilizer on multiple long clips off the bat ... then add other things. It can't do real-time, it keeps re-analyzing ... it's terrible! Well, yea, just do a test sequence to make sure that WS will work properly on a clip, maybe with your other expected effects applied also, but don't apply it in your working sequences until near the end of the editing process.
          Lumetri, especially in multiple layers, kills playback ...  also do it last. As with video denoising.
          So work smarter considering PrPro as it exists, not how you think or want it to be.
          And also ... download & run Bill Gehrke 's PPBM8 process, to get real good & hard data on how well that entire machine actually works within PrPro.
          Neil
          http://ppbm8.com/index.html
          • 2. Re: Unusual response from tech team regarding 4k realtime playback
            PrashantMac Level 1
            I am not using any effect. Just Playback. :/ Even in source Monitor it drops. Whats the use of spending so much? And why does Adobe claim 4k 60 fps realtime playback?
            • 3. Re: Unusual response from tech team regarding 4k realtime playback
              PrashantMac Level 1
              R Neil Haugen Did the test. Every export of the sequence took less than a min. The vbs file doesn't execute; gives an error in windows 10.
              • 4. Re: Unusual response from tech team regarding 4k realtime playback
                You will need to have all the system monitoring stuff installed & running, and send the output logs to Bill for him to evaluate, that's how that works. Then from the data, you'll be able to see exactly how each subsystem performed.
                I've never seen any actually absolute claim of 4k playback in 60fps of any codec on any system ... nothing even close. In fact, the entire reason they came out with their new proxy setup on ingestion was because format/codec changes (larger "K", faster frame-rates, often at higher compression and/or long-GOP) are outpacing hardware upgrades rather substantially.
                It's so quick to pop between the proxies & the original media ... single click or keyboard short ... that it's to me a puzzlement why some folks don't use it. Although there are some situations where the new proxy process doesn't work as well, they aren't so common.
                Which settings for the format/codec are you using on that RED?
                Neil
                • 5. Re: Unusual response from tech team regarding 4k realtime playback
                  Bill Gehrke Most Valuable Participant
                  PrashantMac  wrote
                  https://forums.adobe.com/people/R+Neil+Haugen  Did the test. Every export of the sequence took less than a min. The vbs file doesn't execute; gives an error in windows 10.
                  It most likely gives you an error message because we do not know where your files were exported to.  The exports have to be where to script is located .  DO NOT copy and move the files CUT and paste them so the timestamps are not changed.  IF the MPEG2-DVD export without GPU assistance took less than a minute you are doing something wrong
                  • 6. Re: Unusual response from tech team regarding 4k realtime playback
                    I have an 8K R3D 6 second clip which I can playback on my 3-year old laptop at 1/8 resolution and after cleaning the Media Cache and Media Cache Files misses 1 frame but the second playback i get perfect playback
                    • 7. Re: Unusual response from tech team regarding 4k realtime playback
                      MyerPj Level 3
                      Did you catch the 3rd test where you turn off Mercury Playback. That test will take more than a minute and if you are missing a test you get that error from the .vbs.
                      • 8. Re: Unusual response from tech team regarding 4k realtime playback
                        PrashantMac Level 1
                        HI All,
                        Thank You for your support.
                        I did a screen sharing session with an adobe representative now, He couldnt figure out what was the issue. I played davinci resolve and it played 8k realtime. I showed him that :/
                        MyerPj  Bill Gehrke I didnt have 3rd test in the project. There is Test 1, 2 and 4. Re-downloading it. When I open the project it asks me to rename the project file because it has got upgraded. Is there a specific file name I need to enter? for the version 2017.1.2? Will it affect the vbs script?
                        R Neil Haugen I took the footage from: RED | Sample R3D Files | Test drive your RAW workflow I started working on davinci resolve 14 for now because it is playing in full resolution. right from the timeline without frames dropped.    I miss premiere now.
                        I have requested the support to team to send someone who can help in solving it. They tried resetting the preference and the software.
                        Bill Gehrke I have installed the Speccy software. Here are the details:
                        0Summary
                        Operating System
                        Windows 10 Enterprise 64-bit
                        CPU
                        Intel Core i7 6900K @ 3.20GHz 37 °C
                        Broadwell-E/EP 14nm Technology
                        RAM
                        64.0GB Unknown @ 1199MHz (15-17-17-35)
                        Motherboard
                        ASUSTeK COMPUTER INC. X99-E WS (SOCKET 2011) 46 °C
                        Graphics
                        LG ULTRAWIDE (3440x1440@60Hz)
                        LG TV (3840x2160@60Hz)
                        4095MB NVIDIA Quadro P4000 (NVIDIA) 55 °C
                        Storage
                        7452GB Intel Raid 0 Volume (RAID)
                        1863GB Seagate ST2000DX001-1NS164 (SATA) 31 °C
                        2794GB Seagate FA GoFlex Desk USB Device (USB (SATA))
                        953GB Samsung SSD 850 PRO 1TB (SSD) 37 °C
                        3726GB Seagate ST4000DX001-1CE168 (SATA) 31 °C
                        1863GB Seagate ST2000DX002-2DV164 (SATA) 33 °C
                        2794GB Seagate ST33000651AS (SATA) 38 °C
                        2794GB Western Digital WD Elements 107C USB Device (USB (SATA)) 30 °C
                        2794GB Western Digital WD Elements 107C USB Device (USB (SATA)) 32 °C
                        1862GB Western Digital WD My Book 111D USB Device (USB (SATA)) 37 °C
                        Optical Drives
                        No optical disk drives detected
                        Audio
                        Realtek High Definition Audio
                        Operating System
                        Computer type: Desktop
                        Installation Date: 20-05-2017 21:46:16
                        Serial Number: KT6X7-HKD4G-V98JB-PKMG3-GF4CD
                        Windows Security Center
                        User Account Control (UAC) Enabled
                        Notify level 1 - Rare Notify
                        Windows Update
                        AutoUpdate Not configured
                        Windows Defender
                        Windows Defender Enabled
                        Firewall
                        Firewall Enabled
                        Display Name ESET Personal firewall
                        Antivirus
                        ESET Smart Security
                        Antivirus Disabled
                        Company Name ESET
                        Product Version 10.1.210.0
                        Virus Signature Database Not updated
                        Windows Defender
                        Antivirus Enabled
                        Virus Signature Database Up to date
                        .NET Frameworks installed
                        v4.7 Full
                        v4.7 Client
                        v3.5 SP1
                        v3.0 SP2
                        v2.0 SP2
                        Internet Explorer
                        Version 11.540.15063.0
                        PowerShell
                        Version 5.1.15063.0
                        Environment Variables
                        USERPROFILE C:\Users\AndMediaTwo
                        SystemRoot C:\Windows
                        User Variables
                        OneDrive C:\Users\AndMediaTwo\OneDrive
                        Path C:\Users\AndMediaTwo\AppData\Local\Microsoft\WindowsApps
                        TEMP C:\Users\AndMediaTwo\AppData\Local\Temp
                        TMP C:\Users\AndMediaTwo\AppData\Local\Temp
                        Machine Variables
                        CLASSPATH .;C:\Program Files (x86)\QuickTime\QTSystem\QTJava.zip
                        ComSpec C:\Windows\system32\cmd.exe
                        INTEL_DEV_REDIST C:\Program Files (x86)\Common Files\Intel\Shared Libraries\
                        NUMBER_OF_PROCESSORS 16
                        OS Windows_NT
                        Path %INTEL_DEV_REDIST%redist\intel64\compiler
                        C:\Program Files (x86)\Intel\iCLS Client\
                        C:\Program Files\Intel\iCLS Client\
                        C:\Windows\system32
                        C:\Windows
                        C:\Windows\System32\Wbem
                        C:\Windows\System32\WindowsPowerShell\v1.0\
                        C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common
                        C:\Program Files (x86)\Intel\Intel Management Engine Components\DAL
                        C:\Program Files\Intel\Intel Management Engine Components\DAL
                        C:\Program Files (x86)\Intel\Intel Management Engine Components\IPT
                        C:\Program Files\Intel\Intel Management Engine Components\IPT
                        PATHEXT .COM;.EXE;.BAT;.CMD;.VBS;.VBE;.JS;.JSE;.WSF;.WSH;.MSC
                        PROCESSOR_ARCHITECTURE AMD64
                        PROCESSOR_IDENTIFIER Intel64 Family 6 Model 79 Stepping 1, GenuineIntel
                        PROCESSOR_LEVEL 6
                        PROCESSOR_REVISION 4f01
                        PSModulePath %ProgramFiles%\WindowsPowerShell\Modules
                        C:\Windows\system32\WindowsPowerShell\v1.0\Modules
                        QTJAVA C:\Program Files (x86)\QuickTime\QTSystem\QTJava.zip
                        RG_GPU_FRAMEWORK_ENGINE_RESOURCEDIR C:\Program Files\Red Giant\RGFX
                        TEMP C:\Windows\TEMP
                        TMP C:\Windows\TEMP
                        USERNAME SYSTEM
                        windir C:\Windows
                        Power Profile
                        Active power scheme High performance
                        Hibernation Enabled
                        Turn Off Monitor after: (On AC Power) 35 min
                        Turn Off Hard Disk after: (On AC Power) 35 min
                        Suspend after: (On AC Power) Never
                        Screen saver Disabled
                        Uptime
                        Current Session
                        Current Time 17-08-2017 15:43:29
                        Current Uptime 10,092 sec (0 d, 02 h, 48 m, 12 s)
                        Last Boot Time 17-08-2017 12:55:17
                        Services
                        Running Adobe Acrobat Update Service
                        Running Adobe Genuine Software Integrity Service
                        Running AdobeUpdateService
                        Running apmwinsrv
                        Running Application Information
                        Running Application Management
                        Running ASUS Com Service
                        Running ASUS HM Com Service
                        Running ASUS System Control Service
                        Running AsusFanControlService
                        Running Background Intelligent Transfer Service
                        Running Background Tasks Infrastructure Service
                        Running Base Filtering Engine
                        Running Bluetooth Support Service
                        Running Chrome Remote Desktop Service
                        Running CNG Key Isolation
                        Running COM+ Event System
                        Running Computer Browser
                        Running Connected Devices Platform Service
                        Running Connected Devices Platform User Service_5e974
                        Running Connected User Experiences and Telemetry
                        Running Contact Data_5e974
                        Running CoreMessaging
                        Running Credential Manager
                        Running Cryptographic Services
                        Running Data Usage
                        Running DCOM Server Process Launcher
                        Running Delivery Optimization
                        Running Desktop Video Helper Service
                        Running Device Association Service
                        Running DevicesFlow_5e974
                        Running DHCP Client
                        Running Diagnostic Policy Service
                        Running Diagnostic Service Host
                        Running Diagnostic System Host
                        Running Distributed Link Tracking Client
                        Running DNS Client
                        Running DTSAudioSvc
                        Running ESET Service
                        Running FABS - Helping agent for MAGIX media database
                        Running Function Discovery Provider Host
                        Running Function Discovery Resource Publication
                        Running Geolocation Service
                        Running Group Policy Client
                        Running HomeGroup Provider
                        Running HP LaserJet Service
                        Running Human Interface Device Service
                        Running IKE and AuthIP IPsec Keying Modules
                        Running Intel Dynamic Application Loader Host Interface Service
                        Running Intel Integrated Clock Controller Service - Intel ICCS
                        Running Intel Management and Security Application Local Management Service
                        Running Intel PROSet Monitoring Service
                        Running Intel Rapid Storage Technology
                        Running Intel Security Assist
                        Running IP Helper
                        Running IPsec Policy Agent
                        Running Local Session Manager
                        Running Network Connected Devices Auto-Setup
                        Running Network Connection Broker
                        Running Network List Service
                        Running Network Location Awareness
                        Running Network Store Interface Service
                        Running NVIDIA Display Container LS
                        Running NVIDIA LocalSystem Container
                        Running NVIDIA Telemetry Container
                        Running NVIDIA WMI Provider
                        Running Peer Name Resolution Protocol
                        Running Peer Networking Identity Manager
                        Running Plug and Play
                        Running postgresql-x64-9.5 - PostgreSQL Server 9.5
                        Running Power
                        Running Print Spooler
                        Running Program Compatibility Assistant Service
                        Running Radio Management Service
                        Running Remote Procedure Call (RPC)
                        Running RPC Endpoint Mapper
                        Running Secondary Logon
                        Running Security Accounts Manager
                        Running Security Center
                        Running Sentinel LDK License Manager
                        Running Server
                        Running Service KMSELDI
                        Running Shell Hardware Detection
                        Running SSDP Discovery
                        Running State Repository Service
                        Running Storage Service
                        Running Superfetch
                        Running Sync Host_5e974
                        Running System Event Notification Service
                        Running System Events Broker
                        Running Task Scheduler
                        Running TCP/IP NetBIOS Helper
                        Running TeamViewer 12
                        Running Themes
                        Running Tile Data model server
                        Running Time Broker
                        Running TokenBroker
                        Running User Data Access_5e974
                        Running User Data Storage_5e974
                        Running User Manager
                        Running User Profile Service
                        Running Windows Audio
                        Running Windows Audio Endpoint Builder
                        Running Windows Connection Manager
                        Running Windows Defender Antivirus Network Inspection Service
                        Running Windows Defender Antivirus Service
                        Running Windows Defender Security Center Service
                        Running Windows Driver Foundation - User-mode Driver Framework
                        Running Windows Event Log
                        Running Windows Firewall
                        Running Windows Font Cache Service
                        Running Windows Image Acquisition (WIA)
                        Running Windows License Manager Service
                        Running Windows Management Instrumentation
                        Running Windows Push Notifications System Service
                        Running Windows Push Notifications User Service_5e974
                        Running Windows Search
                        Running Windows Time
                        Running Windows Update
                        Running WinHTTP Web Proxy Auto-Discovery Service
                        Running WLAN AutoConfig
                        Running WMI Performance Adapter
                        Running Workstation
                        Running X-Rite Device Services Manager
                        Stopped ActiveX Installer (AxInstSV)
                        Stopped AllJoyn Router Service
                        Stopped App Readiness
                        Stopped Application Identity
                        Stopped Application Layer Gateway Service
                        Stopped AppX Deployment Service (AppXSVC)
                        Stopped Auto Time Zone Updater
                        Stopped BitLocker Drive Encryption Service
                        Stopped Block Level Backup Engine Service
                        Stopped Bluetooth Handsfree Service
                        Stopped BranchCache
                        Stopped Certificate Propagation
                        Stopped Client License Service (ClipSVC)
                        Stopped COM+ System Application
                        Stopped Data Sharing Service
                        Stopped Device Install Service
                        Stopped Device Management Enrollment Service
                        Stopped Device Setup Manager
                        Stopped DevQuery Background Discovery Broker
                        Stopped Distributed Transaction Coordinator
                        Stopped dmwappushsvc
                        Stopped Downloaded Maps Manager
                        Stopped Embedded Mode
                        Stopped Encrypting File System (EFS)
                        Stopped Enterprise App Management Service
                        Stopped Extensible Authentication Protocol
                        Stopped Fax
                        Stopped File History Service
                        Stopped Firebird Server - MAGIX Instance
                        Stopped FlexNet Licensing Service
                        Stopped Google Update Service (gupdate)
                        Stopped Google Update Service (gupdatem)
                        Stopped HomeGroup Listener
                        Stopped HV Host Service
                        Stopped Hyper-V Data Exchange Service
                        Stopped Hyper-V Guest Service Interface
                        Stopped Hyper-V Guest Shutdown Service
                        Stopped Hyper-V Heartbeat Service
                        Stopped Hyper-V PowerShell Direct Service
                        Stopped Hyper-V Remote Desktop Virtualization Service
                        Stopped Hyper-V Time Synchronization Service
                        Stopped Hyper-V Volume Shadow Copy Requestor
                        Stopped Infrared monitor service
                        Stopped Intel Bluetooth Service
                        Stopped Intel Capability Licensing Service TCP IP Interface
                        Stopped Intel Security Assist Helper
                        Stopped Interactive Services Detection
                        Stopped Internet Connection Sharing (ICS)
                        Stopped IP Translation Configuration Service
                        Stopped KtmRm for Distributed Transaction Coordinator
                        Stopped Link-Layer Topology Discovery Mapper
                        Stopped LPA Service
                        Stopped MessagingService_5e974
                        Stopped Microsoft Diagnostics Hub Standard Collector Service
                        Stopped Microsoft Account Sign-in Assistant
                        Stopped Microsoft App-V Client
                        Stopped Microsoft iSCSI Initiator Service
                        Stopped Microsoft Passport
                        Stopped Microsoft Passport Container
                        Stopped Microsoft Software Shadow Copy Provider
                        Stopped Microsoft Storage Spaces SMP
                        Stopped Microsoft Windows SMS Router Service.
                        Stopped Natural Authentication
                        Stopped Net.Tcp Port Sharing Service
                        Stopped Netlogon
                        Stopped Network Connections
                        Stopped Network Connectivity Assistant
                        Stopped Network Setup Service
                        Stopped NVIDIA NetworkService Container
                        Stopped Office 64 Source Engine
                        Stopped Offline Files
                        Stopped Optimize drives
                        Stopped Payments and NFC/SE Manager
                        Stopped Peer Networking Grouping
                        Stopped Performance Counter DLL Host
                        Stopped Performance Logs & Alerts
                        Stopped Phone Service
                        Stopped PNRP Machine Name Publication Service
                        Stopped Portable Device Enumerator Service
                        Stopped Printer Extensions and Notifications
                        Stopped Problem Reports and Solutions Control Panel Support
                        Stopped Quality Windows Audio Video Experience
                        Stopped Remote Access Auto Connection Manager
                        Stopped Remote Access Connection Manager
                        Stopped Remote Desktop Configuration
                        Stopped Remote Desktop Services
                        Stopped Remote Desktop Services UserMode Port Redirector
                        Stopped Remote Procedure Call (RPC) Locator
                        Stopped Remote Registry
                        Stopped Retail Demo Service
                        Stopped Routing and Remote Access
                        Stopped Secure Socket Tunneling Protocol Service
                        Stopped Sensor Data Service
                        Stopped Sensor Monitoring Service
                        Stopped Sensor Service
                        Stopped Shared PC Account Manager
                        Stopped Smart Card
                        Stopped Smart Card Device Enumeration Service
                        Stopped Smart Card Removal Policy
                        Stopped SNMP Trap
                        Stopped Software Protection
                        Stopped Spot Verifier
                        Stopped Still Image Acquisition Events
                        Stopped Storage Tiers Management
                        Stopped Telephony
                        Stopped Touch Keyboard and Handwriting Panel Service
                        Stopped Update Orchestrator Service
                        Stopped UPnP Device Host
                        Stopped User Experience Virtualization Service
                        Stopped Virtual Disk
                        Stopped Volume Shadow Copy
                        Stopped WalletService
                        Stopped WebClient
                        Stopped Wi-Fi Direct Services Connection Manager Service
                        Stopped Windows Backup
                        Stopped Windows Biometric Service
                        Stopped Windows Camera Frame Server
                        Stopped Windows Connect Now - Config Registrar
                        Stopped Windows Defender Advanced Threat Protection Service
                        Stopped Windows Encryption Provider Host Service
                        Stopped Windows Error Reporting Service
                        Stopped Windows Event Collector
                        Stopped Windows Insider Service
                        Stopped Windows Installer
                        Stopped Windows Media Player Network Sharing Service
                        Stopped Windows Mobile Hotspot Service
                        Stopped Windows Modules Installer
                        Stopped Windows Perception Service
                        Stopped Windows Presentation Foundation Font Cache 3.0.0.0
                        Stopped Windows Remote Management (WS-Management)
                        Stopped Wired AutoConfig
                        Stopped Work Folders
                        Stopped WWAN AutoConfig
                        Stopped Xbox Accessory Management Service
                        Stopped Xbox Game Monitoring
                        Stopped Xbox Live Auth Manager
                        Stopped Xbox Live Game Save
                        Stopped Xbox Live Networking Service
                        TimeZone
                        TimeZone GMT +5:30 Hours
                        Language English (United States)
                        Location India
                        Format English (India)
                        Currency ?
                        Date Format dd-MM-yyyy
                        Time Format HH:mm:ss
                        Scheduler
                        17-08-2017 16:31; HPLJCustParticipation
                        17-08-2017 16:35; GoogleUpdateTaskMachineUA
                        17-08-2017 23:59; AutoPico Daily Restart
                        18-08-2017 01:35; GoogleUpdateTaskMachineCore
                        18-08-2017 02:00; AdobeAAMUpdater-1.0-ANDMEDIATWO-AndMediaTwo
                        18-08-2017 02:00; AdobeAAMUpdater-1.0-DESKTOP-85H45GO-AndMediaTwo
                        18-08-2017 08:00; X-Rite Device Services Software Updater
                        18-08-2017 09:57; OneDrive Standalone Update Task-S-1-5-21-94733980-1370256720-2831819212-1001
                        18-08-2017 14:00; Adobe Acrobat Update Task
                        22-08-2017 02:22; Red Giant Link
                        CCleanerSkipUAC
                        Connect
                        HFS+ Activator
                        HFS+ Updater
                        Hotfixes
                        Installed
                        17-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.1154.0)
                        Install this update to revise the definition files that are used
                        to detect viruses, spyware, and other potentially unwanted software.
                        Once you have installed this item, it cannot be removed.
                        16-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.1124.0)
                        16-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.1077.0)
                        14-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.1026.0)
                        14-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.1023.0)
                        14-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.1022.0)
                        14-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.1005.0)
                        13-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.999.0)
                        12-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.984.0)
                        12-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.979.0)
                        11-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.955.0)
                        11-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.944.0)
                        10-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.902.0)
                        09-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.872.0)
                        09-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.871.0)
                        09-08-2017  2017-08 Cumulative Update for Windows 10 Version 1703 for x64-based Systems (KB4034674)
                        A security issue has been identified in a Microsoft software
                        product that could affect your system. You can help protect your
                        system by installing this update from Microsoft. For a complete
                        listing of the issues that are included in this update, see the
                        associated Microsoft Knowledge Base article. After you install
                        this update, you may have to restart your system.
                        09-08-2017  Windows Malicious Software Removal Tool for Windows 8, 8.1, 10 and Windows Server 2012, 2012 R2, 2016 x64 Edition - August 2017 (KB890830)
                        After the download, this tool runs one time to check your computer
                        for infection by specific, prevalent malicious software (including
                        Blaster, Sasser, and Mydoom) and helps remove any infection that
                        is found. If an infection is found, the tool will display a status
                        report the next time that you start your computer. A new version
                        of the tool will be offered every month. If you want to manually
                        run the tool on your computer, you can download a copy from the
                        Microsoft Download Center, or you can run an online version from
                        microsoft.com. This tool is not a replacement for an antivirus
                        product. To help protect your computer, you should use an antivirus
                        product.
                        09-08-2017  2017-08 Security Update for Adobe Flash Player for Windows 10 Version 1703 for x64-based Systems (KB4034662)
                        09-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.847.0)
                        09-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.842.0)
                        08-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.807.0)
                        08-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.805.0)
                        08-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.799.0)
                        08-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.787.0)
                        07-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.745.0)
                        06-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.724.0)
                        06-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.723.0)
                        05-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.711.0)
                        05-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.707.0)
                        04-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.670.0)
                        04-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.665.0)
                        03-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.608.0)
                        03-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.603.0)
                        03-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.600.0)
                        02-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.543.0)
                        31-07-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.456.0)
                        31-07-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.450.0)
                        30-07-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.418.0)
                        29-07-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.380.0)
                        28-07-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.342.0)
                        26-07-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.262.0)
                        25-07-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.211.0)
                        24-07-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.136.0)
                        22-07-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.100.0)
                        22-07-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.96.0)
                        22-07-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.95.0)
                        12-07-2017  2017-07 Security Update for Adobe Flash Player for Windows 10 Version 1703 for x64-based Systems (KB4025376)
                        12-07-2017  2017-07 Cumulative Update for Windows 10 Version 1703 for x64-based Systems (KB4025342)
                        12-07-2017  Windows Malicious Software Removal Tool for Windows 8, 8.1, 10 and Windows Server 2012, 2012 R2, 2016 x64 Edition - July 2017 (KB890830)
                        product.
                        30-06-2017  SAMSUNG Electronics Co., Ltd. - Other hardware - SAMSUNG Mobile MTP Device
                        SAMSUNG Electronics Co., Ltd. Other hardware software update
                        released in February, 2012
                        30-06-2017  SAMSUNG Electronics Co., Ltd.  - Modem - 5/15/2017 12:00:00 AM - 2.12.5.0
                        SAMSUNG Electronics Co., Ltd. Modem driver update released in
                        May 2017
                        30-06-2017  SAMSUNG Electronics Co., Ltd.  - USB - 5/15/2017 12:00:00 AM - 2.12.5.0
                        SAMSUNG Electronics Co., Ltd. USB driver update released in May
                        2017
                        13-06-2017  Windows Malicious Software Removal Tool for Windows 8, 8.1, 10 and Windows Server 2012, 2012 R2, 2016 x64 Edition - June 2017 (KB890830)
                        product.
                        13-06-2017  2017-06 Cumulative Update for Windows 10 Version 1703 for x64-based Systems (KB4022725)
                        13-06-2017  2017-06 Security Update for Adobe Flash Player for Windows 10 Version 1703 for x64-based Systems (KB4022730)
                        13-06-2017  2017-06 Update for Windows 10 Version 1703 for x64-based Systems (KB4022405)
                        Install this update to resolve issues in Windows. For a complete
                        associated Microsoft Knowledge Base article for more information.
                        After you install this item, you may have to restart your computer.
                        23-05-2017  Windows Malicious Software Removal Tool for Windows 8, 8.1, 10 and Windows Server 2012, 2012 R2, 2016 x64 Edition - May 2017 (KB890830)
                        product.
                        21-05-2017  2017-05 Security Update for Adobe Flash Player for Windows 10 Version 1703 for x64-based Systems (KB4020821)
                        21-05-2017  Windows Malicious Software Removal Tool for Windows 8, 8.1, 10 and Windows Server 2012, 2012 R2, 2016 x64 Edition - May 2017 (KB890830)
                        product.
                        21-05-2017  2017-05 Cumulative Update for Windows 10 Version 1703 for x64-based Systems (KB4016871)
                        20-05-2017  Hewlett Packard - Printers - HP LaserJet Pro MFP M125-M126 PCLmS
                        Hewlett Packard Printers software update released in May, 2013
                        20-05-2017  PXI - Pointing Drawing - HID-compliand device
                        PXI Pointing Drawing software update released in December, 2012
                        20-05-2017  Western Digital Technologies - Other hardware - WD SES Device
                        Western Digital Technologies Other hardware software update released
                        in October, 2015
                        20-05-2017  Intel - Other hardware - Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D Memory Controller 0 - Channel 3 Thermal Control - 6FB5
                        Intel Other hardware software update released in January, 2016
                        Not Installed
                        04-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.682.0)
                        Installation Status Failed
                        01-08-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.249.493.0)
                        13-06-2017  2017-05 Cumulative Update for Windows 10 Version 1703 for x64-based Systems (KB4020102)
                        03-06-2017  2017-05 Cumulative Update for Windows 10 Version 1703 for x64-based Systems (KB4020102)
                        22-05-2017  Windows Malicious Software Removal Tool for Windows 8, 8.1, 10 and Windows Server 2012, 2012 R2, 2016 x64 Edition - May 2017 (KB890830)
                        product.
                        20-05-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.243.846.0)
                        20-05-2017  Definition Update for Windows Defender - KB2267602 (Definition 1.243.842.0)
                        System Folders
                        Application Data C:\ProgramData
                        Cookies C:\Users\AndMediaTwo\AppData\Local\Microsoft\Windows\INetCookies
                        Desktop C:\Users\AndMediaTwo\Desktop
                        Documents C:\Users\Public\Documents
                        Fonts C:\Windows\Fonts
                        Global Favorites C:\Users\AndMediaTwo\Favorites
                        Internet History C:\Users\AndMediaTwo\AppData\Local\Microsoft\Windows\History
                        Local Application Data C:\Users\AndMediaTwo\AppData\Local
                        Music C:\Users\Public\Music
                        Path for burning CD C:\Users\AndMediaTwo\AppData\Local\Microsoft\Windows\Burn\Burn
                        Physical Desktop C:\Users\AndMediaTwo\Desktop
                        Pictures C:\Users\Public\Pictures
                        Program Files C:\Program Files
                        Public Desktop C:\Users\Public\Desktop
                        Start Menu C:\ProgramData\Microsoft\Windows\Start Menu
                        Start Menu Programs C:\ProgramData\Microsoft\Windows\Start Menu\Programs
                        Startup C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
                        Templates C:\ProgramData\Microsoft\Windows\Templates
                        Temporary Internet Files C:\Users\AndMediaTwo\AppData\Local\Microsoft\Windows\INetCache
                        User Favorites C:\Users\AndMediaTwo\Favorites
                        Videos C:\Users\Public\Videos
                        Windows Directory C:\Windows
                        Windows/System C:\Windows\system32
                        Process List
                        aaHMSvc.exe
                        Process ID 4192
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files (x86)\ASUS\AAHM\1.00.23\aaHMSvc.exe
                        Memory Usage 8.91 MB
                        Peak Memory Usage 9.84 MB
                        acrotray.exe
                        Process ID 18884
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\Adobe\Acrobat DC\Acrobat\acrotray.exe
                        Memory Usage 8.11 MB
                        Peak Memory Usage 8.15 MB
                        Adobe CEF Helper.exe
                        Process ID 19576
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\HEX\Adobe CEF Helper.exe
                        Memory Usage 84 MB
                        Peak Memory Usage 95 MB
                        Adobe Desktop Service.exe
                        Process ID 19536
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\ADS\Adobe Desktop Service.exe
                        Memory Usage 113 MB
                        Peak Memory Usage 146 MB
                        AdobeIPCBroker.exe
                        Process ID 19096
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\IPC\AdobeIPCBroker.exe
                        Memory Usage 12 MB
                        Peak Memory Usage 14 MB
                        AdobeUpdateService.exe
                        Process ID 4256
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\ElevationManager\AdobeUpdateService.exe
                        Memory Usage 7.89 MB
                        Peak Memory Usage 8.38 MB
                        AGSService.exe
                        Process ID 4268
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files (x86)\Common Files\Adobe\AdobeGCClient\AGSService.exe
                        Memory Usage 16 MB
                        Peak Memory Usage 19 MB
                        AiChargerPlus.exe
                        Process ID 18488
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\InstallShield Installation Information\{E6931688-DA2B-4E16-8539-3D323D69C677}\AiChargerPlus.exe
                        Memory Usage 8.49 MB
                        Peak Memory Usage 8.59 MB
                        AISuite3.exe
                        Process ID 7976
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\ASUS\AI Suite III\AISuite3.exe
                        Memory Usage 3.57 MB
                        Peak Memory Usage 90 MB
                        apmwinsrv.exe
                        Process ID 4176
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files (x86)\Paragon Software\HFS+ for Windows\apmwinsrv.exe
                        Memory Usage 5.35 MB
                        Peak Memory Usage 6.93 MB
                        ApplicationFrameHost.exe
                        Process ID 21208
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Windows\System32\ApplicationFrameHost.exe
                        Memory Usage 24 MB
                        Peak Memory Usage 33 MB
                        armsvc.exe
                        Process ID 4184
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\armsvc.exe
                        Memory Usage 5.75 MB
                        Peak Memory Usage 6.59 MB
                        AsSysCtrlService.exe
                        Process ID 4208
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files (x86)\ASUS\AsSysCtrlService\1.00.22\AsSysCtrlService.exe
                        Memory Usage 5.48 MB
                        Peak Memory Usage 6.32 MB
                        AsusFanControlService.exe
                        Process ID 4216
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files (x86)\ASUS\AsusFanControlService\1.08.14\AsusFanControlService.exe
                        Memory Usage 9.09 MB
                        Peak Memory Usage 9.70 MB
                        atkexComSvc.exe
                        Process ID 4168
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files (x86)\ASUS\AXSP\1.02.03\atkexComSvc.exe
                        Memory Usage 12 MB
                        Peak Memory Usage 13 MB
                        backgroundTaskHost.exe
                        Process ID 13568
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Windows\System32\backgroundTaskHost.exe
                        Memory Usage 44 MB
                        Peak Memory Usage 59 MB
                        BMDStreamingServer.exe
                        Process ID 17380
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\Blackmagic Design\Blackmagic Desktop Video\BMDStreamingServer.exe
                        Memory Usage 6.86 MB
                        CCLibrary.exe
                        Process ID 18308
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCLibrary\CCLibrary.exe
                        Memory Usage 2.46 MB
                        Peak Memory Usage 2.67 MB
                        CCXProcess.exe
                        Process ID 20292
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCXProcess\CCXProcess.exe
                        Memory Usage 2.09 MB
                        Peak Memory Usage 2.61 MB
                        CheckVersionPCI.exe
                        Process ID 13492
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\Blackmagic Design\Blackmagic Desktop Video\CheckVersionPCI.exe
                        Memory Usage 12 MB
                        chrome.exe
                        Process ID 15660
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\Google\Chrome\Application\chrome.exe
                        Memory Usage 89 MB
                        Peak Memory Usage 92 MB
                        chrome.exe
                        Process ID 9160
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 169 MB
                        Peak Memory Usage 200 MB
                        chrome.exe
                        Process ID 17292
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 215 MB
                        Peak Memory Usage 311 MB
                        chrome.exe
                        Process ID 12708
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 75 MB
                        Peak Memory Usage 77 MB
                        chrome.exe
                        Process ID 5688
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 74 MB
                        chrome.exe
                        Process ID 17424
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 151 MB
                        Peak Memory Usage 305 MB
                        chrome.exe
                        Process ID 6980
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 67 MB
                        Peak Memory Usage 70 MB
                        chrome.exe
                        Process ID 9236
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 85 MB
                        Peak Memory Usage 109 MB
                        chrome.exe
                        Process ID 17372
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 68 MB
                        Peak Memory Usage 72 MB
                        chrome.exe
                        Process ID 1172
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 100 MB
                        Peak Memory Usage 100 MB
                        chrome.exe
                        Process ID 10560
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 73 MB
                        Peak Memory Usage 75 MB
                        chrome.exe
                        Process ID 11108
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 91 MB
                        Peak Memory Usage 91 MB
                        chrome.exe
                        Process ID 5864
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 178 MB
                        Peak Memory Usage 272 MB
                        chrome.exe
                        Process ID 12488
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 82 MB
                        Peak Memory Usage 84 MB
                        chrome.exe
                        Process ID 14740
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 308 MB
                        Peak Memory Usage 317 MB
                        chrome.exe
                        Process ID 6752
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 90 MB
                        Peak Memory Usage 101 MB
                        chrome.exe
                        Process ID 19224
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 9.77 MB
                        Peak Memory Usage 10 MB
                        chrome.exe
                        Process ID 13048
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 82 MB
                        Peak Memory Usage 99 MB
                        chrome.exe
                        Process ID 10328
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 9.28 MB
                        Peak Memory Usage 9.64 MB
                        chrome.exe
                        Process ID 11364
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 207 MB
                        Peak Memory Usage 608 MB
                        chrome.exe
                        Process ID 21344
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 70 MB
                        conhost.exe
                        Process ID 8364
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Windows\System32\conhost.exe
                        Memory Usage 9.67 MB
                        Peak Memory Usage 9.93 MB
                        conhost.exe
                        Process ID 4672
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 9.44 MB
                        Peak Memory Usage 9.74 MB
                        conhost.exe
                        Process ID 16976
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 9.25 MB
                        Peak Memory Usage 9.98 MB
                        conhost.exe
                        Process ID 6348
                        User postgres
                        Domain ANDMEDIATWO
                        Memory Usage 10 MB
                        Peak Memory Usage 11 MB
                        CoreSync.exe
                        Process ID 20340
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\Adobe\Adobe Sync\CoreSync\CoreSync.exe
                        Memory Usage 44 MB
                        Peak Memory Usage 46 MB
                        Creative Cloud.exe
                        Process ID 18984
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\Adobe\Adobe Creative Cloud\ACC\Creative Cloud.exe
                        Memory Usage 78 MB
                        Peak Memory Usage 94 MB
                        csrss.exe
                        Process ID 880
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Windows\System32\csrss.exe
                        Memory Usage 7.67 MB
                        Peak Memory Usage 26 MB
                        csrss.exe
                        Process ID 760
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 4.52 MB
                        Peak Memory Usage 5.21 MB
                        dasHost.exe
                        Process ID 2492
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Path C:\Windows\System32\dasHost.exe
                        Memory Usage 16 MB
                        Peak Memory Usage 16 MB
                        DesktopVideoHelper.exe
                        Process ID 4504
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files (x86)\Blackmagic Design\Blackmagic Desktop Video\DesktopVideoHelper.exe
                        Memory Usage 6.37 MB
                        Peak Memory Usage 7.39 MB
                        DipAwayMode.exe
                        Process ID 7880
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\ASUS\AI Suite III\DIP4\DIPAwayMode\DipAwayMode.exe
                        Memory Usage 240 KB
                        Peak Memory Usage 17 MB
                        dllhost.exe
                        Process ID 4980
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Windows\System32\dllhost.exe
                        Memory Usage 11 MB
                        DTSU2PAuSrv64.exe
                        Process ID 4452
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files\Realtek\Audio\HDA\DTSU2PAuSrv64.exe
                        Memory Usage 7.11 MB
                        Peak Memory Usage 7.74 MB
                        dwm.exe
                        Process ID 1216
                        User DWM-1
                        Domain Window Manager
                        Path C:\Windows\System32\dwm.exe
                        Memory Usage 93 MB
                        Peak Memory Usage 244 MB
                        egui.exe
                        Process ID 9408
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files\ESET\ESET Security\egui.exe
                        Memory Usage 39 MB
                        Peak Memory Usage 42 MB
                        ekrn.exe
                        Process ID 1928
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files\ESET\ESET Security\ekrn.exe
                        Memory Usage 177 MB
                        Peak Memory Usage 191 MB
                        explorer.exe
                        Process ID 6840
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Windows\explorer.exe
                        Memory Usage 158 MB
                        Peak Memory Usage 228 MB
                        EzUpdt.exe
                        Process ID 7816
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\ASUS\AI Suite III\EZ Update\EzUpdt.exe
                        Memory Usage KB
                        FABS.exe
                        Process ID 2096
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files (x86)\Common Files\MAGIX Services\Database\bin\FABS.exe
                        Memory Usage 7.60 MB
                        Peak Memory Usage 8.03 MB
                        fontdrvhost.exe
                        Process ID 696
                        User UMFD-0
                        Domain Font Driver Host
                        Path C:\Windows\System32\fontdrvhost.exe
                        Memory Usage 13 MB
                        fontdrvhost.exe
                        Process ID 884
                        User UMFD-1
                        Memory Usage 36 MB
                        Peak Memory Usage 48 MB
                        GoogleCrashHandler.exe
                        Process ID 13436
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files (x86)\Google\Update\1.3.33.5\GoogleCrashHandler.exe
                        Memory Usage 428 KB
                        Peak Memory Usage 6.53 MB
                        GoogleCrashHandler64.exe
                        Process ID 13500
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files (x86)\Google\Update\1.3.33.5\GoogleCrashHandler64.exe
                        Memory Usage 100 KB
                        Peak Memory Usage 6.16 MB
                        googledrivesync.exe
                        Process ID 18200
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\Google\Drive\googledrivesync.exe
                        Memory Usage 110 MB
                        Peak Memory Usage 111 MB
                        googledrivesync.exe
                        Process ID 7240
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 3.69 MB
                        hasplms.exe
                        Process ID 5784
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Windows\System32\hasplms.exe
                        Memory Usage 19 MB
                        Peak Memory Usage 20 MB
                        HelpPane.exe
                        Process ID 10592
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Windows\HelpPane.exe
                        Memory Usage 23 MB
                        Peak Memory Usage 24 MB
                        HPLaserJetService.exe
                        Process ID 4468
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files (x86)\HP\HPLaserJetService\HPLaserJetService.exe
                        Memory Usage 4.01 MB
                        HPStatusAlerts.exe
                        Process ID 19292
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\HP\StatusAlerts\bin\HPStatusAlerts.exe
                        Memory Usage 11 MB
                        Peak Memory Usage 28 MB
                        hpwuschd2.exe
                        Process ID 19192
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\HP\HP Software Update\hpwuschd2.exe
                        Memory Usage 6.97 MB
                        Peak Memory Usage 7.02 MB
                        IAStorDataMgrSvc.exe
                        Process ID 16352
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files\Intel\Intel Rapid Storage Technology\IAStorDataMgrSvc.exe
                        Memory Usage 54 MB
                        Peak Memory Usage 55 MB
                        IAStorIcon.exe
                        Process ID 12764
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files\Intel\Intel Rapid Storage Technology\IAStorIcon.exe
                        Memory Usage 40 MB
                        Peak Memory Usage 44 MB
                        ICCProxy.exe
                        Process ID 17300
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files (x86)\Intel\Intel Integrated Clock Controller Service\ICCProxy.exe
                        Memory Usage 6.46 MB
                        Peak Memory Usage 7.48 MB
                        IPROSetMonitor.exe
                        Process ID 4444
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Windows\System32\IPROSetMonitor.exe
                        Memory Usage 4.75 MB
                        Peak Memory Usage 5.61 MB
                        isa.exe
                        Process ID 4956
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files (x86)\Intel\Intel Security Assist\isa.exe
                        Memory Usage 13 MB
                        jhi_service.exe
                        Process ID 2276
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files (x86)\Intel\Intel Management Engine Components\DAL\jhi_service.exe
                        Memory Usage 5.86 MB
                        Peak Memory Usage 6.37 MB
                        LMS.exe
                        Process ID 1560
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files (x86)\Intel\Intel Management Engine Components\LMS\LMS.exe
                        Memory Usage 11 MB
                        lsass.exe
                        Process ID 960
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Windows\System32\lsass.exe
                        Memory Usage 16 MB
                        Memory Compression
                        Process ID 5220
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 4.00 KB
                        Peak Memory Usage 4.00 KB
                        MSASCuiL.exe
                        Process ID 16512
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files\Windows Defender\MSASCuiL.exe
                        Memory Usage 9.37 MB
                        Peak Memory Usage 9.42 MB
                        MsMpEng.exe
                        Process ID 20936
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files\Windows Defender\MsMpEng.exe
                        Memory Usage 143 MB
                        Peak Memory Usage 588 MB
                        NisSrv.exe
                        Process ID 5124
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Path C:\Program Files\Windows Defender\NisSrv.exe
                        Memory Usage 18 MB
                        Peak Memory Usage 38 MB
                        node.exe
                        Process ID 4588
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCXProcess\libs\node.exe
                        Memory Usage 67 MB
                        Peak Memory Usage 83 MB
                        node.exe
                        Process ID 19092
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCLibrary\libs\node.exe
                        Memory Usage 67 MB
                        Peak Memory Usage 80 MB
                        nvcontainer.exe
                        Process ID 4512
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files\NVIDIA Corporation\NvContainer\nvcontainer.exe
                        Memory Usage 25 MB
                        Peak Memory Usage 25 MB
                        nvcontainer.exe
                        Process ID 7208
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\NVIDIA Corporation\NvContainer\nvcontainer.exe
                        Memory Usage 27 MB
                        Peak Memory Usage 47 MB
                        NVDisplay.Container.exe
                        Process ID 2572
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files\NVIDIA Corporation\Display.NvContainer\NVDisplay.Container.exe
                        Memory Usage 34 MB
                        Peak Memory Usage 57 MB
                        Process ID 2072
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 13 MB
                        NVIDIA Share.exe
                        Process ID 17240
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\NVIDIA Corporation\NVIDIA GeForce Experience\NVIDIA Share.exe
                        Memory Usage 79 MB
                        Peak Memory Usage 98 MB
                        NVIDIA Share.exe
                        Process ID 7660
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 58 MB
                        Peak Memory Usage 60 MB
                        NVIDIA Web Helper.exe
                        Process ID 16836
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\NVIDIA Corporation\NvNode\NVIDIA Web Helper.exe
                        Memory Usage 48 MB
                        Peak Memory Usage 54 MB
                        nvspcaps64.exe
                        Process ID 16912
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files\NVIDIA Corporation\ShadowPlay\nvspcaps64.exe
                        Memory Usage 42 MB
                        nvsphelper64.exe
                        Process ID 17200
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files\NVIDIA Corporation\ShadowPlay\nvsphelper64.exe
                        Memory Usage 12 MB
                        Peak Memory Usage 12 MB
                        NvTelemetryContainer.exe
                        Process ID 4708
                        User NETWORK SERVICE
                        Domain NT AUTHORITY
                        Path C:\Program Files (x86)\NVIDIA Corporation\NvTelemetry\NvTelemetryContainer.exe
                        Memory Usage 16 MB
                        nvtray.exe
                        Process ID 13020
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files\NVIDIA Corporation\Display\nvtray.exe
                        Memory Usage 12 MB
                        nvwmi64.exe
                        Process ID 7180
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Windows\System32\nvwmi64.exe
                        Memory Usage 15 MB
                        Peak Memory Usage 40 MB
                        nvwmi64.exe
                        Process ID 2064
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 6.04 MB
                        Peak Memory Usage 6.77 MB
                        OneDrive.exe
                        Process ID 16812
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Users\AndMediaTwo\AppData\Local\Microsoft\OneDrive\OneDrive.exe
                        Memory Usage 31 MB
                        Peak Memory Usage 31 MB
                        pg_ctl.exe
                        Process ID 6160
                        User postgres
                        Domain ANDMEDIATWO
                        Path C:\Program Files\PostgreSQL\9.5\bin\pg_ctl.exe
                        Memory Usage 6.71 MB
                        Peak Memory Usage 7.79 MB
                        postgres.exe
                        Process ID 8308
                        User postgres
                        Domain ANDMEDIATWO
                        Path C:\Program Files\PostgreSQL\9.5\bin\postgres.exe
                        Memory Usage 4.83 MB
                        Peak Memory Usage 5.97 MB
                        postgres.exe
                        Process ID 6856
                        User postgres
                        Domain ANDMEDIATWO
                        Memory Usage 5.46 MB
                        Peak Memory Usage 6.54 MB
                        postgres.exe
                        Process ID 6340
                        User postgres
                        Domain ANDMEDIATWO
                        Memory Usage 17 MB
                        Peak Memory Usage 18 MB
                        postgres.exe
                        Process ID 8288
                        User postgres
                        Domain ANDMEDIATWO
                        Memory Usage 6.07 MB
                        Peak Memory Usage 7.23 MB
                        postgres.exe
                        Process ID 8240
                        User postgres
                        Domain ANDMEDIATWO
                        Memory Usage 5.38 MB
                        Peak Memory Usage 6.60 MB
                        postgres.exe
                        Process ID 8216
                        User postgres
                        Domain ANDMEDIATWO
                        Memory Usage 6.30 MB
                        Peak Memory Usage 6.57 MB
                        postgres.exe
                        Process ID 6776
                        User postgres
                        Domain ANDMEDIATWO
                        Memory Usage 4.73 MB
                        ProductUpdater.exe
                        Process ID 19948
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\Common Files\Freemake Shared\ProductUpdater\ProductUpdater.exe
                        Memory Usage 40 MB
                        PushNoticeMonitor.exe
                        Process ID 7936
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\ASUS\AI Suite III\Push Notice\PushNoticeMonitor.exe
                        Memory Usage 740 KB
                        Peak Memory Usage 15 MB
                        PushNotify_PCCtrl.exe
                        Process ID 16412
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\ASUS\AI Suite III\Push Notice\PushNotify_PCCtrl.exe
                        Memory Usage 208 KB
                        Peak Memory Usage 27 MB
                        PushNotifyServer.exe
                        Process ID 7800
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\ASUS\AI Suite III\Push Notice\PushNotifyServer.exe
                        Memory Usage 456 KB
                        RAVBg64.exe
                        Process ID 16660
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files\Realtek\Audio\HDA\RAVBg64.exe
                        Memory Usage 14 MB
                        remoting_host.exe
                        Process ID 4160
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files (x86)\Google\Chrome Remote Desktop\60.0.3112.25\remoting_host.exe
                        Memory Usage 8.88 MB
                        Peak Memory Usage 9.82 MB
                        remoting_host.exe
                        Process ID 5944
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 14 MB
                        RtkNGUI64.exe
                        Process ID 16564
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe
                        Memory Usage 15 MB
                        RuntimeBroker.exe
                        Process ID 10932
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Windows\System32\RuntimeBroker.exe
                        Memory Usage 50 MB
                        Peak Memory Usage 144 MB
                        SearchFilterHost.exe
                        Process ID 10728
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Windows\System32\SearchFilterHost.exe
                        Memory Usage 12 MB
                        SearchIndexer.exe
                        Process ID 12044
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Windows\System32\SearchIndexer.exe
                        Memory Usage 45 MB
                        SearchProtocolHost.exe
                        Process ID 12744
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Windows\System32\SearchProtocolHost.exe
                        Memory Usage 19 MB
                        SearchUI.exe
                        Process ID 9372
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Windows\SystemApps\Microsoft.Windows.Cortana_cw5n1h2txyewy\SearchUI.exe
                        Memory Usage 156 MB
                        Peak Memory Usage 173 MB
                        SecurityHealthService.exe
                        Process ID 4644
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Windows\System32\SecurityHealthService.exe
                        Memory Usage 14 MB
                        Service_KMS.exe
                        Process ID 4572
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files\KMSpico\Service_KMS.exe
                        Memory Usage 40 MB
                        Peak Memory Usage 45 MB
                        services.exe
                        Process ID 952
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Windows\System32\services.exe
                        Memory Usage 9.73 MB
                        ShellExperienceHost.exe
                        Process ID 9264
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Windows\SystemApps\ShellExperienceHost_cw5n1h2txyewy\ShellExperienceHost.exe
                        Memory Usage 111 MB
                        Peak Memory Usage 121 MB
                        sihost.exe
                        Process ID 7296
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Windows\System32\sihost.exe
                        Memory Usage 27 MB
                        smss.exe
                        Process ID 516
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Windows\System32\smss.exe
                        Memory Usage 488 KB
                        Peak Memory Usage 1.16 MB
                        Speccy64.exe
                        Process ID 12920
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files\Speccy\Speccy64.exe
                        Memory Usage 39 MB
                        spoolsv.exe
                        Process ID 3128
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Windows\System32\spoolsv.exe
                        Memory Usage 25 MB
                        svchost.exe
                        Process ID 1976
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Path C:\Windows\System32\svchost.exe
                        Memory Usage 19 MB
                        svchost.exe
                        Process ID 17020
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 14 MB
                        svchost.exe
                        Process ID 2016
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 7.88 MB
                        Peak Memory Usage 8.00 MB
                        svchost.exe
                        Process ID 2024
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 9.49 MB
                        Peak Memory Usage 9.60 MB
                        svchost.exe
                        Process ID 1148
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Peak Memory Usage 7.89 MB
                        svchost.exe
                        Process ID 2132
                        Domain NT AUTHORITY
                        Memory Usage 10 MB
                        svchost.exe
                        Process ID 2156
                        Domain NT AUTHORITY
                        Memory Usage 7.91 MB
                        svchost.exe
                        Process ID 2220
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 5.05 MB
                        svchost.exe
                        Process ID 2240
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 6.80 MB
                        Peak Memory Usage 7.82 MB
                        svchost.exe
                        Process ID 2328
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 8.78 MB
                        Peak Memory Usage 9.46 MB
                        svchost.exe
                        Process ID 2404
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 7.14 MB
                        svchost.exe
                        Process ID 2484
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 7.57 MB
                        Peak Memory Usage 8.36 MB
                        svchost.exe
                        Process ID 2500
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 6.38 MB
                        svchost.exe
                        Process ID 2696
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 11 MB
                        svchost.exe
                        Process ID 2764
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 11 MB
                        svchost.exe
                        Process ID 2772
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 5.67 MB
                        Peak Memory Usage 6.50 MB
                        svchost.exe
                        Process ID 2780
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 11 MB
                        svchost.exe
                        Process ID 2916
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 12 MB
                        svchost.exe
                        Process ID 2984
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Peak Memory Usage 9.40 MB
                        svchost.exe
                        Process ID 3032
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 13 MB
                        svchost.exe
                        Process ID 3056
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 7.26 MB
                        Peak Memory Usage 8.57 MB
                        svchost.exe
                        Process ID 1192
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 12 MB
                        svchost.exe
                        Process ID 3196
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 19 MB
                        svchost.exe
                        Process ID 3220
                        Domain NT AUTHORITY
                        Memory Usage 6.99 MB
                        Peak Memory Usage 7.88 MB
                        svchost.exe
                        Process ID 3384
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 11 MB
                        svchost.exe
                        Process ID 3960
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 7.09 MB
                        Peak Memory Usage 8.48 MB
                        svchost.exe
                        Process ID 3988
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 6.14 MB
                        svchost.exe
                        Process ID 4024
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 11 MB
                        svchost.exe
                        Process ID 2480
                        User SYSTEM
                        Domain NT AUTHORITY
                        Peak Memory Usage 7.95 MB
                        svchost.exe
                        Process ID 3248
                        Domain NT AUTHORITY
                        Memory Usage 6.17 MB
                        Peak Memory Usage 8.73 MB
                        svchost.exe
                        Process ID 4144
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 27 MB
                        Peak Memory Usage 56 MB
                        svchost.exe
                        Process ID 21308
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 9.36 MB
                        svchost.exe
                        Process ID 21152
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 31 MB
                        svchost.exe
                        Process ID 4152
                        Domain NT AUTHORITY
                        Memory Usage 12 MB
                        Peak Memory Usage 22 MB
                        svchost.exe
                        Process ID 4436
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 25 MB
                        svchost.exe
                        Process ID 15952
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 36 MB
                        Peak Memory Usage 142 MB
                        svchost.exe
                        Process ID 5968
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 11 MB
                        svchost.exe
                        Process ID 21272
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 11 MB
                        svchost.exe
                        Process ID 15456
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 17 MB
                        svchost.exe
                        Process ID 4492
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 9.15 MB
                        svchost.exe
                        Process ID 5060
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 5.96 MB
                        Peak Memory Usage 6.26 MB
                        svchost.exe
                        Process ID 19928
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 6.87 MB
                        Peak Memory Usage 7.11 MB
                        svchost.exe
                        Process ID 4520
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 11 MB
                        svchost.exe
                        Process ID 4636
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 13 MB
                        svchost.exe
                        Process ID 17568
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 5.30 MB
                        Peak Memory Usage 5.57 MB
                        svchost.exe
                        Process ID 1068
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 8.04 MB
                        Peak Memory Usage 8.56 MB
                        svchost.exe
                        Process ID 8684
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 11 MB
                        svchost.exe
                        Process ID 1268
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 5.73 MB
                        Peak Memory Usage 6.13 MB
                        svchost.exe
                        Process ID 4660
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 5.20 MB
                        Peak Memory Usage 5.82 MB
                        svchost.exe
                        Process ID 4852
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 18 MB
                        svchost.exe
                        Process ID 4616
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 18 MB
                        Peak Memory Usage 21 MB
                        svchost.exe
                        Process ID 5204
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 4.64 MB
                        svchost.exe
                        Process ID 4500
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 16 MB
                        svchost.exe
                        Process ID 7356
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 12 MB
                        svchost.exe
                        Process ID 7384
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Memory Usage 27 MB
                        Peak Memory Usage 30 MB
                        svchost.exe
                        Process ID 7504
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 14 MB
                        svchost.exe
                        Process ID 2556
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 8.93 MB
                        svchost.exe
                        Process ID 1900
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 14 MB
                        svchost.exe
                        Process ID 496
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 3.00 MB
                        Peak Memory Usage 3.88 MB
                        svchost.exe
                        Process ID 11068
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 5.39 MB
                        Peak Memory Usage 6.33 MB
                        svchost.exe
                        Process ID 2188
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 17 MB
                        svchost.exe
                        Process ID 672
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 23 MB
                        svchost.exe
                        Process ID 1088
                        Domain NT AUTHORITY
                        Memory Usage 13 MB
                        svchost.exe
                        Process ID 1132
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 7.37 MB
                        svchost.exe
                        Process ID 1248
                        User SYSTEM
                        Domain NT AUTHORITY
                        Peak Memory Usage 6.24 MB
                        svchost.exe
                        Process ID 1348
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 9.91 MB
                        svchost.exe
                        Process ID 1356
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 6.31 MB
                        Peak Memory Usage 6.61 MB
                        svchost.exe
                        Process ID 1444
                        User SYSTEM
                        Domain NT AUTHORITY
                        Peak Memory Usage 9.49 MB
                        svchost.exe
                        Process ID 12492
                        User SYSTEM
                        Domain NT AUTHORITY
                        Peak Memory Usage 6.79 MB
                        svchost.exe
                        Process ID 1460
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 9.55 MB
                        svchost.exe
                        Process ID 1468
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 9.96 MB
                        svchost.exe
                        Process ID 1500
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 15 MB
                        svchost.exe
                        Process ID 4536
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 15 MB
                        svchost.exe
                        Process ID 1620
                        User SYSTEM
                        Domain NT AUTHORITY
                        svchost.exe
                        Process ID 10600
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Peak Memory Usage 6.31 MB
                        svchost.exe
                        Process ID 1288
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 5.34 MB
                        Peak Memory Usage 5.44 MB
                        svchost.exe
                        Process ID 1708
                        User SYSTEM
                        Domain NT AUTHORITY
                        Peak Memory Usage 7.98 MB
                        System
                        Process ID 4
                        Memory Usage 1.18 MB
                        Peak Memory Usage 6.36 MB
                        System Idle Process
                        Process ID 0
                        SystemSettingsBroker.exe
                        Process ID 16544
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Windows\System32\SystemSettingsBroker.exe
                        Memory Usage 18 MB
                        taskhostw.exe
                        Process ID 7892
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Windows\System32\taskhostw.exe
                        Memory Usage 22 MB
                        Peak Memory Usage 37 MB
                        TeamViewer_Service.exe
                        Process ID 4840
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files (x86)\TeamViewer\TeamViewer_Service.exe
                        Memory Usage 17 MB
                        TiltWheelMouse.exe
                        Process ID 16740
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Windows\System32\TiltWheelMouse.exe
                        Memory Usage 8.68 MB
                        Peak Memory Usage 8.91 MB
                        U3BoostSvr64.exe
                        Process ID 13464
                        User AndMediaTwo
                        Domain ANDMEDIATWO
                        Path C:\Program Files (x86)\ASUS\AI Suite III\USB 3.0 Boost\U3BoostSvr64.exe
                        Memory Usage 76 KB
                        Peak Memory Usage 8.50 MB
                        wininit.exe
                        Process ID 872
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Windows\System32\wininit.exe
                        Memory Usage 5.62 MB
                        Peak Memory Usage 6.68 MB
                        winlogon.exe
                        Process ID 796
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Windows\System32\winlogon.exe
                        Memory Usage 11 MB
                        Peak Memory Usage 29 MB
                        WmiApSrv.exe
                        Process ID 11032
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Windows\System32\wbem\WmiApSrv.exe
                        Memory Usage 7.73 MB
                        Peak Memory Usage 7.73 MB
                        WmiPrvSE.exe
                        Process ID 7304
                        Domain NT AUTHORITY
                        Path C:\Windows\System32\wbem\WmiPrvSE.exe
                        Memory Usage 30 MB
                        WmiPrvSE.exe
                        Process ID 19004
                        User SYSTEM
                        Domain NT AUTHORITY
                        Memory Usage 38 MB
                        Peak Memory Usage 39 MB
                        WmiPrvSE.exe
                        Process ID 20044
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 14 MB
                        WUDFHost.exe
                        Process ID 1888
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Path C:\Windows\System32\WUDFHost.exe
                        Memory Usage 7.66 MB
                        Peak Memory Usage 8.16 MB
                        WUDFHost.exe
                        Process ID 1540
                        User LOCAL SERVICE
                        Domain NT AUTHORITY
                        Memory Usage 5.01 MB
                        Peak Memory Usage 6.15 MB
                        xrdd.exe
                        Process ID 4928
                        User SYSTEM
                        Domain NT AUTHORITY
                        Path C:\Program Files (x86)\X-Rite\Devices\Services\xrdd.exe
                        Memory Usage 16 MB
                        Security Options
                        Accounts: Administrator account status Disabled
                        Accounts: Block Microsoft accounts Not Defined
                        Accounts: Guest account status Enabled
                        Accounts: Limit local account use of blank passwords to console logon only Enabled
                        Accounts: Rename administrator account Administrator
                        Accounts: Rename guest account Guest
                        Audit: Audit the access of global system objects Disabled
                        Audit: Audit the use of Backup and Restore privilege Disabled
                        Audit: Force audit policy subcategory settings (Windows Vista or later) to override audit policy category settings Not Defined
                        Audit: Shut down system immediately if unable to log security audits Disabled
                        DCOM: Machine Access Restrictions in Security Descriptor Definition Language (SDDL) syntax Not Defined
                        DCOM: Machine Launch Restrictions in Security Descriptor Definition Language (SDDL) syntax Not Defined
                        Devices: Allow undock without having to log on Enabled
                        Devices: Allowed to format and eject removable media Not Defined
                        Devices: Prevent users from installing printer drivers Disabled
                        Devices: Restrict CD-ROM access to locally logged-on user only Not Defined
                        Devices: Restrict floppy access to locally logged-on user only Not Defined
                        Domain controller: Allow server operators to schedule tasks Not Defined
                        Domain controller: LDAP server signing requirements Not Defined
                        Domain controller: Refuse machine account password changes Not Defined
                        Domain member: Digitally encrypt or sign secure channel data (always) Enabled
                        Domain member: Digitally encrypt secure channel data (when possible) Enabled
                        Domain member: Digitally sign secure channel data (when possible) Enabled
                        Domain member: Disable machine account password changes Disabled
                        Domain member: Maximum machine account password age 30 days
                        Domain member: Require strong (Windows 2000 or later) session key Enabled
                        Interactive logon: Display user information when the session is locked Not Defined
                        Interactive logon: Do not require CTRL+ALT+DEL Not Defined
                        Interactive logon: Don't display last signed-in Disabled
                        Interactive logon: Don't display username at sign-in Not Defined
                        Interactive logon: Machine account lockout threshold Not Defined
                        Interactive logon: Machine inactivity limit Not Defined
                        Interactive logon: Message text for users attempting to log on
                        Interactive logon: Message title for users attempting to log on
                        Interactive logon: Number of previous logons to cache (in case domain controller is not available) 10 logons
                        Interactive logon: Prompt user to change password before expiration 5 days
                        Interactive logon: Require Domain Controller authentication to unlock workstation Disabled
                        Interactive logon: Require Windows Hello for Business or smart card Disabled
                        Interactive logon: Smart card removal behavior No Action
                        Microsoft network client: Digitally sign communications (always) Disabled
                        Microsoft network client: Digitally sign communications (if server agrees) Enabled
                        Microsoft network client: Send unencrypted password to third-party SMB servers Disabled
                        Microsoft network server: Amount of idle time required before suspending session 15 minutes
                        Microsoft network server: Attempt S4U2Self to obtain claim information Not Defined
                        Microsoft network server: Digitally sign communications (always) Disabled
                        Microsoft network server: Digitally sign communications (if client agrees) Disabled
                        Microsoft network server: Disconnect clients when logon hours expire Enabled
                        Microsoft network server: Server SPN target name validation level Not Defined
                        Network access: Allow anonymous SID/Name translation Disabled
                        Network access: Do not allow anonymous enumeration of SAM accounts Enabled
                        Network access: Do not allow anonymous enumeration of SAM accounts and shares Disabled
                        Network access: Do not allow storage of passwords and credentials for network authentication Disabled
                        Network access: Let Everyone permissions apply to anonymous users Disabled
                        Network access: Named Pipes that can be accessed anonymously
                        Network access: Remotely accessible registry paths System\CurrentControlSet\Control\ProductOptions,System\CurrentControlSet\Control\Server Applications,Software\Microsoft\Windows NT\CurrentVersion
                        Network access: Remotely accessible registry paths and sub-paths System\CurrentControlSet\Control\Print\Printers,System\CurrentControlSet\Services\Eventlo g,Software\Microsoft\OLAP Server,Software\Microsoft\Windows NT\CurrentVersion\Print,Software\Microsoft\Windows NT\CurrentVersion\Windows,System\CurrentControlSet\Control\ContentIndex,System\CurrentCon trolSet\Control\Terminal Server,System\CurrentControlSet\Control\Terminal Server\UserConfig,System\CurrentControlSet\Control\Terminal Server\DefaultUserConfiguration,Software\Microsoft\Windows NT\CurrentVersion\Perflib,System\CurrentControlSet\Services\SysmonLog
                        Network access: Restrict anonymous access to Named Pipes and Shares Enabled
                        Network access: Restrict clients allowed to make remote calls to SAM
                        Network access: Shares that can be accessed anonymously Not Defined
                        Network access: Sharing and security model for local accounts Classic - local users authenticate as themselves
                        Network security: Allow Local System to use computer identity for NTLM Not Defined
                        Network security: Allow LocalSystem NULL session fallback Not Defined
                        Network security: Allow PKU2U authentication requests to this computer to use online identities.
                        Not Defined
                        Network security: Configure encryption types allowed for Kerberos Not Defined
                        Network security: Do not store LAN Manager hash value on next password change Enabled
                        Network security: Force logoff when logon hours expire Disabled
                        Network security: LAN Manager authentication level Not Defined
                        Network security: LDAP client signing requirements Negotiate signing
                        Network security: Minimum session security for NTLM SSP based (including secure RPC) clients Require 128-bit encryption
                        Network security: Minimum session security for NTLM SSP based (including secure RPC) servers Require 128-bit encryption
                        Network security: Restrict NTLM: Add remote server exceptions for NTLM authentication Not Defined
                        Network security: Restrict NTLM: Add server exceptions in this domain Not Defined
                        Network security: Restrict NTLM: Audit Incoming NTLM Traffic Not Defined
                        Network security: Restrict NTLM: Audit NTLM authentication in this domain Not Defined
                        Network security: Restrict NTLM: Incoming NTLM traffic Not Defined
                        Network security: Restrict NTLM: NTLM authentication in this domain Not Defined
                        Network security: Restrict NTLM: Outgoing NTLM traffic to remote servers Not Defined
                        Recovery console: Allow automatic administrative logon Disabled
                        Recovery console: Allow floppy copy and access to all drives and all folders Disabled
                        Shutdown: Allow system to be shut down without having to log on Enabled
                        Shutdown: Clear virtual memory pagefile Disabled
                        System cryptography: Force strong key protection for user keys stored on the computer Not Defined
                        System cryptography: Use FIPS compliant algorithms for encryption, hashing, and signing Disabled
                        System objects: Require case insensitivity for non-Windows subsystems Enabled
                        System objects: Strengthen default permissions of internal system objects (e.g. Symbolic Links) Enabled
                        System settings: Optional subsystems
                        System settings: Use Certificate Rules on Windows Executables for Software Restriction Policies Disabled
                        User Account Control: Admin Approval Mode for the Built-in Administrator account Not Defined
                        User Account Control: Allow UIAccess applications to prompt for elevation without using the secure desktop Disabled
                        User Account Control: Behavior of the elevation prompt for administrators in Admin Approval Mode Prompt for consent for non-Windows binaries
                        User Account Control: Behavior of the elevation prompt for standard users Prompt for credentials
                        User Account Control: Detect application installations and prompt for elevation Enabled
                        User Account Control: Only elevate executables that are signed and validated Disabled
                        User Account Control: Only elevate UIAccess applications that are installed in secure locations Enabled
                        User Account Control: Run all administrators in Admin Approval Mode Enabled
                        User Account Control: Switch to the secure desktop when prompting for elevation Disabled
                        User Account Control: Virtualize file and registry write failures to per-user locations Enabled
                        Device Tree
                        ACPI x64-based PC
                        Microsoft ACPI-Compliant System
                        ACPI Fixed Feature Button
                        ACPI Power Button
                        AMDA00 Interface
                        Generic Bus
                        Intel Turbo Boost Max Technology 3.0 Driver
                        Microsoft Windows Management Interface for ACPI
                        PCI Bus
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FE0
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FE1
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FE2
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FE3
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FE4
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FE5
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FE6
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FE7
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FF8
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FF9
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FFC
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FFD
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Caching Agent - 6FFE
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 0/1 Broadcast - 6FAE
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 0/1 Interface - 6FBC
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 0/1 Interface - 6FBD
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 0/1 Interface - 6FBE
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 0/1 Interface - 6FBF
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 2/3 Broadcast - 6F6E
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 2/3 Interface - 6FB8
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 2/3 Interface - 6FB9
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 2/3 Interface - 6FBA
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Channel 2/3 Interface - 6FBB
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Global Broadcast - 6F6F
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D DDRIO Global Broadcast - 6FAF
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Home Agent 0 - 6F30
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Home Agent 0 - 6FA0
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 0 Error - 6FB2
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 0 Thermal Control - 6FB0
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 1 Error - 6FB3
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 1 Thermal Control - 6FB1
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 2 Error - 6FB6
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 2 Thermal Control - 6FB4
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 3 Error - 6FB7
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel 3 Thermal Control - 6FB5
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel Target Address Decoder - 6FAA
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel Target Address Decoder - 6FAB
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel Target Address Decoder - 6FAC
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Channel Target Address Decoder - 6FAD
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Target Address/Thermal/RAS - 6F71
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 0 - Target Address/Thermal/RAS - 6FA8
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Memory Controller 1 - Channel 0 Thermal Control - 6FD0
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Power Control Unit - 6F88
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Power Control Unit - 6F8A
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Power Control Unit - 6F98
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Power Control Unit - 6F99
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Power Control Unit - 6F9A
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Power Control Unit - 6F9C
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Power Control Unit - 6FC0
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R2PCIe Agent - 6F1D
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R2PCIe Agent - 6F34
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R3 QPI Link 0/1 - 6F36
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R3 QPI Link 0/1 - 6F37
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R3 QPI Link 0/1 - 6F81
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D R3 QPI Link Debug - 6F76
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Target Address/Thermal/RAS - 6F68
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Ubox - 6F1E
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Ubox - 6F1F
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Ubox - 6F7D
                        ACPI Module Device
                        Intel Core i7-6900K CPU @ 3.20GHz
                        PCI Express Root Complex
                        Advanced programmable interrupt controller
                        Intel C610 series/X99 chipset PCI Express Root Port #1 - 8D10
                        Intel C610 series/X99 chipset SMBus Controller - 8D22
                        Intel C610 series/X99 chipset SPSR - 8D7C
                        Intel Ethernet Connection (2) I218-LM
                        Intel Management Engine Interface
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D Address Map/VTd_Misc/System Management - 6F28
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D I/O APIC - 6F2C
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D IIO Hot Plug - 6F29
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D IIO RAS/Control Status/Global Errors - 6F2A
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D PCI Express Root Port 1 - 6F02
                        Intel Xeon E7 v4/Xeon E5 v4/Xeon E3 v4/Xeon D PCI Express Root Port 1 - 6F03
                        PCI standard host CPU bridge
                        Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D PCI Express Root Port 2 - 6F04
                        PCI-to-PCI Bridge
                        PCI-to-PCI Bridge
                        PCI-to-PCI Bridge
                        PCI-to-PCI Bridge
                        Blackmagic DeckLink Mini Monitor 4K
                        Blackmagic DeckLink Mini Monitor 4K AVStream
                        Blackmagic DeckLink Mini Monitor 4K Audio
                        Speakers (Blackmagic DeckLink Mini Monitor 4K Audio)
                        Intel(R) Xeon(R) E7 v4/Xeon(R) E5 v4/Xeon(R) E3 v4/Xeon(R) D PCI Express Root Port 3 - 6F08
                        PCI-to-PCI Bridge
                        PCI-to-PCI Bridge
                        PCI-to-PCI Bridge
                        NVIDIA Quadro P4000
                        Generic PnP Monitor
                        Generic PnP Monitor
                        High Definition Audio Controller
                        NVIDIA High Definition Audio
                        LG TV-C (NVIDIA High Definition Audio)
                        LG ULTRAWIDE-8 (NVIDIA High Definition Audio)
                        Standard SATA AHCI Controller
                        Samsung SSD 850 PRO 1TB
                        ST2000DX002-2DV164
                        ST2000DX002-2DV164
                        ST4000DX001-1CE168
                        Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft)
                        USB Root Hub (USB 3.0)
                        Generic SuperSpeed USB Hub
                        Generic USB Hub
                        USB Input Device
                        HID-compliant vendor-defined device
                        Generic Bluetooth Radio
                        Bluetooth Device (Personal Area Network) #5
                        Bluetooth Device (RFCOMM Protocol TDI) #5
                        Microsoft Bluetooth LE Enumerator
                        Microsoft Bluetooth Enumerator
                        Apple Wireless Mouse
                        Device Identification Service
                        usi’s Mouse
                        Generic USB Hub
                        HID-compliant mouse
                        USB Composite Device
                        USB Input Device
                        HID Keyboard Device
                        USB Input Device
                        HID-compliant consumer control device
                        HID-compliant system controller
                        USB Mass Storage Device
                        WD Elements 107C USB Device
                        WD My Book 111D USB Device
                        WD SES Device
                        Intel(R) C610 series/X99 chipset USB Enhanced Host Controller #2 - 8D2D
                        USB Root Hub
                        Generic USB Hub
                        Realtek High Definition Audio
                        Realtek Digital Output (Realtek High Definition Audio)
                        Realtek Digital Output(Optical) (Realtek High Definition Audio)
                        Speakers (Realtek High Definition Audio)
                        Intel(R) C610 series/X99 chipset PCI Express Root Port #4 - 8D16
                        PCI-to-PCI Bridge
                        PCI-to-PCI Bridge
                        Intel I210 Gigabit Network Connection
                        PCI-to-PCI Bridge
                        Asmedia 106x SATA Controller
                        Intel(R) C610 series/X99 chipset PCI Express Root Port #5 - 8D18
                        ST33000651AS
                        Intel(R) C610 series/X99 chipset PCI Express Root Port #7 - 8D1C
                        ASMedia USB3.0 eXtensible Host Controller
                        ASMedia USB Root Hub
                        Seagate FA GoFlex Desk USB Device
                        Intel(R) C610 series/X99 chipset USB Enhanced Host Controller #1 - 8D26
                        USB Root Hub
                        Generic USB Hub
                        Intel(R) C610 series/X99 chipset LPC Controller - 8D47
                        Communications Port (COM1)
                        Direct memory access controller
                        High precision event timer
                        Microsoft ACPI-Compliant Embedded Controller
                        Motherboard resources
                        Numeric data processor
                        Programmable interrupt controller
                        System CMOS/real time clock
                        System speaker
                        System timer
                        Intel(R) Desktop/Workstation/Server Express Chipset SATA RAID Controller
                        Intel Raid 0 Volume
                        ST2000DX001-1NS164
                        CPU
                        Intel Core i7 6900K
                        Cores 8
                        Threads 16
                        Name Intel Core i7 6900K
                        Code Name Broadwell-E/EP
                        Package Socket 2011 LGA
                        Technology 14nm
                        Specification Intel Core i7-6900K CPU @ 3.20GHz
                        Family 6
                        Extended Family 6
                        Model F
                        Extended Model 4F
                        Stepping 1
                        Revision M0
                        Instructions MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, Intel 64, NX, VMX, AES, AVX, AVX2, FMA3
                        Virtualization Supported, Disabled
                        Hyperthreading Supported, Enabled
                        Fan Speed 815 RPM
                        Bus Speed 100.0 MHz
                        Stock Core Speed 3200 MHz
                        Stock Bus Speed 100 MHz
                        Average Temperature 37 °C
                        Caches
                        L1 Data Cache Size 8 x 32 KBytes
                        L1 Instructions Cache Size 8 x 32 KBytes
                        L2 Unified Cache Size 8 x 256 KBytes
                        L3 Unified Cache Size 20480 KBytes
                        Cores
                        Core 0
                        Core Speed 3199.3 MHz
                        Multiplier x 32.0
                        Bus Speed 100.0 MHz
                        Temperature 37 °C
                        Threads APIC ID: 0, 1
                        Core 1
                        Core Speed 1899.6 MHz
                        Multiplier x 19.0
                        Bus Speed 100.0 MHz
                        Temperature 38 °C
                        Threads APIC ID: 2, 3
                        Core 2
                        Core Speed 1799.6 MHz
                        Multiplier x 18.0
                        Bus Speed 100.0 MHz
                        Temperature 37 °C
                        Threads APIC ID: 4, 5
                        Core 3
                        Core Speed 2899.3 MHz
                        Multiplier x 29.0
                        Bus Speed 100.0 MHz
                        Temperature 37 °C
                        Threads APIC ID: 6, 7
                        Core 4
                        Multiplier x 18.0
                        Bus Speed 100.0 MHz
                        Temperature 36 °C
                        Threads APIC ID: 8, 9
                        Core 5
                        Multiplier x 29.0
                        Bus Speed 100.0 MHz
                        Temperature 36 °C
                        Threads APIC ID: 10, 11
                        Core 6
                        Multiplier x 18.0
                        Bus Speed 100.0 MHz
                        Temperature 36 °C
                        Threads APIC ID: 12, 13
                        Core 7
                        Multiplier x 29.0
                        Bus Speed 100.0 MHz
                        Temperature 37 °C
                        Threads APIC ID: 14, 15
                        RAM
                        Memory slots
                        Total memory slots 8
                        Used memory slots 4
                        Free memory slots 4
                        Memory
                        Type Unknown
                        Size 65536 MBytes
                        DRAM Frequency 1199.8 MHz
                        CAS# Latency (CL) 15 clocks
                        RAS# to CAS# Delay (tRCD) 17 clocks
                        RAS# Precharge (tRP) 17 clocks
                        Cycle Time (tRAS) 35 clocks
                        Command Rate (CR) 2T
                        Physical Memory
                        Memory Usage 9 %
                        Total Physical 64 GB
                        Available Physical 58 GB
                        Total Virtual 73 GB
                        Available Virtual 66 GB
                        SPD
                        Number Of SPD Modules 4
                        Slot #1
                        Type Unknown
                        Size 16384 MBytes
                        Manufacturer Corsair
                        Max Bandwidth DDR4-2132 (1066 MHz)
                        Part Number CMK16GX4M1B3000C15
                        SPD Ext. XMP
                        Timing table
                        JEDEC #1
                        Frequency 666.7 MHz
                        CAS# Latency 9.0
                        RAS# To CAS# 9
                        RAS# Precharge 9
                        tRAS 22
                        tRC 31
                        Voltage 1.200 V
                        JEDEC #2
                        Frequency 740.7 MHz
                        CAS# Latency 10.0
                        RAS# To CAS# 10
                        RAS# Precharge 10
                        tRAS 25
                        tRC 35
                        Voltage 1.200 V
                        JEDEC #3
                        Frequency 814.8 MHz
                        CAS# Latency 11.0
                        RAS# To CAS# 11
                        RAS# Precharge 11
                        tRAS 27
                        tRC 38
                        Voltage 1.200 V
                        JEDEC #4
                        Frequency 888.9 MHz
                        CAS# Latency 12.0
                        RAS# To CAS# 12
                        RAS# Precharge 12
                        tRAS 30
                        tRC 42
                        Voltage 1.200 V
                        JEDEC #5
                        Frequency 963.0 MHz
                        CAS# Latency 13.0
                        RAS# To CAS# 13
                        RAS# Precharge 13
                        tRAS 32
                        tRC 45
                        Voltage 1.200 V
                        JEDEC #6
                        Frequency 1037.0 MHz
                        CAS# Latency 14.0
                        RAS# To CAS# 14
                        RAS# Precharge 14
                        tRAS 35
                        tRC 49
                        Voltage 1.200 V
                        JEDEC #7
                        Frequency 1066.1 MHz
                        CAS# Latency 15.0
                        RAS# To CAS# 15
                        RAS# Precharge 15
                        tRAS 36
                        tRC 50
                        Voltage 1.200 V
                        JEDEC #8
                        CAS# Latency 16.0
                        RAS# To CAS# 15
                        RAS# Precharge 15
                        tRAS 36
                        tRC 50
                        Voltage 1.200 V
                        XMP-2998
                        Frequency 1499 MHz
                        CAS# Latency 15.0
                        RAS# To CAS# 17
                        RAS# Precharge 17
                        tRAS 35
                        Voltage 1.350 V
                        Slot #2
                        Type Unknown
                        Size 16384 MBytes
                        SPD Ext. XMP
                        Timing table
                        JEDEC #1
                        Frequency 666.7 MHz
                        CAS# Latency 9.0
                        RAS# To CAS# 9
                        RAS# Precharge 9
                        tRAS 22
                        tRC 31
                        Voltage 1.200 V
                        JEDEC #2
                        Frequency 740.7 MHz
                        CAS# Latency 10.0
                        RAS# To CAS# 10
                        RAS# Precharge 10
                        tRAS 25
                        tRC 35
                        Voltage 1.200 V
                        JEDEC #3
                        Frequency 814.8 MHz
                        CAS# Latency 11.0
                        RAS# To CAS# 11
                        RAS# Precharge 11
                        tRAS 27
                        tRC 38
                        Voltage 1.200 V
                        JEDEC #4
                        Frequency 888.9 MHz
                        CAS# Latency 12.0
                        RAS# To CAS# 12
                        RAS# Precharge 12
                        tRAS 30
                        tRC 42
                        Voltage 1.200 V
                        JEDEC #5
                        Frequency 963.0 MHz
                        CAS# Latency 13.0
                        RAS# To CAS# 13
                        RAS# Precharge 13
                        tRAS 32
                        tRC 45
                        Voltage 1.200 V
                        JEDEC #6
                        CAS# Latency 14.0
                        RAS# To CAS# 14
                        RAS# Precharge 14
                        tRAS 35
                        tRC 49
                        Voltage 1.200 V
                        JEDEC #7
                        CAS# Latency 15.0
                        RAS# To CAS# 15
                        RAS# Precharge 15
                        tRAS 36
                        tRC 50
                        Voltage 1.200 V
                        JEDEC #8
                        CAS# Latency 16.0
                        RAS# To CAS# 15
                        RAS# Precharge 15
                        tRAS 36
                        tRC 50
                        Voltage 1.200 V
                        XMP-2998
                        Frequency 1499 MHz
                        CAS# Latency 15.0
                        RAS# To CAS# 17
                        RAS# Precharge 17
                        tRAS 35
                        Voltage 1.350 V
                        Slot #3
                        Type Unknown
                        Size 16384 MBytes
                        SPD Ext. XMP
                        Timing table
                        JEDEC #1
                        Frequency 666.7 MHz
                        CAS# Latency 9.0
                        RAS# To CAS# 9
                        RAS# Precharge 9
                        tRAS 22
                        tRC 31
                        Voltage 1.200 V
                        JEDEC #2
                        Frequency 740.7 MHz
                        CAS# Latency 10.0
                        RAS# To CAS# 10
                        RAS# Precharge 10
                        tRAS 25
                        tRC 35
                        Voltage 1.200 V
                        JEDEC #3
                        Frequency 814.8 MHz
                        CAS# Latency 11.0
                        RAS# To CAS# 11
                        RAS# Precharge 11
                        tRAS 27
                        tRC 38
                        Voltage 1.200 V
                        JEDEC #4
                        Frequency 888.9 MHz
                        CAS# Latency 12.0
                        RAS# To CAS# 12
                        RAS# Precharge 12
                        tRAS 30
                        tRC 42
                        Voltage 1.200 V
                        JEDEC #5
                        Frequency 963.0 MHz
                        CAS# Latency 13.0
                        RAS# To CAS# 13
                        RAS# Precharge 13
                        tRAS 32
                        tRC 45
                        Voltage 1.200 V
                        JEDEC #6
                        CAS# Latency 14.0
                        RAS# To CAS# 14
                        RAS# Precharge 14
                        tRAS 35
                        tRC 49
                        Voltage 1.200 V
                        JEDEC #7
                        CAS# Latency 15.0
                        RAS# To CAS# 15
                        RAS# Precharge 15
                        tRAS 36
                        tRC 50
                        Voltage 1.200 V
                        JEDEC #8
                        CAS# Latency 16.0
                        RAS# To CAS# 15
                        RAS# Precharge 15
                        tRAS 36
                        tRC 50
                        Voltage 1.200 V
                        XMP-2998
                        Frequency 1499 MHz
                        CAS# Latency 15.0
                        RAS# To CAS# 17
                        RAS# Precharge 17
                        tRAS 35
                        Voltage 1.350 V
                        Slot #4
                        Type Unknown
                        Size 16384 MBytes
                        SPD Ext. XMP
                        Timing table
                        JEDEC #1
                        Frequency 666.7 MHz
                        CAS# Latency 9.0
                        RAS# To CAS# 9
                        RAS# Precharge 9
                        tRAS 22
                        tRC 31
                        Voltage 1.200 V
                        JEDEC #2
                        Frequency 740.7 MHz
                        CAS# Latency 10.0
                        RAS# To CAS# 10
                        RAS# Precharge 10
                        tRAS 25
                        tRC 35
                        Voltage 1.200 V
                        JEDEC #3
                        Frequency 814.8 MHz
                        CAS# Latency 11.0
                        RAS# To CAS# 11
                        RAS# Precharge 11
                        tRAS 27
                        tRC 38
                        Voltage 1.200 V
                        JEDEC #4
                        Frequency 888.9 MHz
                        CAS# Latency 12.0
                        RAS# To CAS# 12
                        RAS# Precharge 12
                        tRAS 30
                        tRC 42
                        Voltage 1.200 V
                        JEDEC #5
                        Frequency 963.0 MHz
                        CAS# Latency 13.0
                        RAS# To CAS# 13
                        RAS# Precharge 13
                        tRAS 32
                        tRC 45
                        Voltage 1.200 V
                        JEDEC #6
                        CAS# Latency 14.0
                        RAS# To CAS# 14
                        RAS# Precharge 14
                        tRAS 35
                        tRC 49
                        Voltage 1.200 V
                        JEDEC #7
                        CAS# Latency 15.0
                        RAS# To CAS# 15
                        RAS# Precharge 15
                        tRAS 36
                        tRC 50
                        Voltage 1.200 V
                        JEDEC #8
                        CAS# Latency 16.0
                        RAS# To CAS# 15
                        RAS# Precharge 15
                        tRAS 36
                        tRC 50
                        Voltage 1.200 V
                        XMP-2998
                        Frequency 1499 MHz
                        CAS# Latency 15.0
                        RAS# To CAS# 17
                        RAS# Precharge 17
                        tRAS 35
                        Voltage 1.350 V
                        Motherboard
                        Manufacturer ASUSTeK COMPUTER INC.
                        Model X99-E WS (SOCKET 2011)
                        Version Rev 1.xx
                        Chipset Vendor Intel
                        Chipset Model Broadwell-E
                        Chipset Revision 01
                        Southbridge Vendor Intel
                        Southbridge Model X99
                        Southbridge Revision 05
                        System Temperature 46 °C
                        BIOS
                        Brand American Megatrends Inc.
                        Version 3402
                        Date 14-11-2016
                        Voltage
                        +5V 5.000 V
                        +3.3V 3.264 V
                        +12V 12.000 V
                        VIN3 1.024 V
                        VIN4 0.864 V
                        VCORE 0.944 V
                        PCI Data
                        Slot PCI-E
                        Slot Type PCI-E
                        Slot Usage In Use
                        Data lanes x16
                        Slot Designation PCIEX16_1
                        Characteristics 3.3V, Shared, PME
                        Slot Number 0
                        Slot PCI-E
                        Slot Type PCI-E
                        Slot Usage Available
                        Data lanes x16
                        Slot Designation PCIEX16_2
                        Slot Number 1
                        Slot PCI-E
                        Slot Type PCI-E
                        Data lanes x16
                        Slot Designation PCIEX16_3
                        Slot Number 2
                        Slot PCI-E
                        Slot Type PCI-E
                        Slot Usage In Use
                        Data lanes x16
                        Slot Designation PCIEX16_4
                        Slot Number 3
                        Slot PCI-E
                        Slot Type PCI-E
                        Data lanes x16
                        Slot Designation PCIEX16_5
                        Slot Number 4
                        Slot PCI-E
                        Slot Type PCI-E
                        Data lanes x16
                        Slot Designation PCIEX16_6
                        Slot Number 5
                        Slot PCI-E
                        Slot Type PCI-E
                        Data lanes x16
                        Slot Designation PCIEX16_7
                        Slot Number 6
                        Graphics
                        Monitor 1
                        Name LG ULTRAWIDE on NVIDIA Quadro P4000
                        Current Resolution 3440x1440 pixels
                        Work Resolution 3440x1410 pixels
                        State Enabled
                        Multiple displays Extended, Primary, Enabled
                        Monitor Width 3440
                        Monitor Height 1440
                        Monitor BPP 32 bits per pixel
                        Monitor Frequency 60 Hz
                        Device \\.\DISPLAY1\Monitor0
                        Monitor 2
                        Name LG TV on NVIDIA Quadro P4000
                        Current Resolution 3072x1728 pixels
                        Work Resolution 3072x1698 pixels
                        State Enabled
                        Multiple displays Extended, Secondary, Enabled
                        Monitor Width 3840
                        Monitor Height 2160
                        Device \\.\DISPLAY2\Monitor0
                        NVIDIA Quadro P4000
                        Manufacturer NVIDIA
                        Model Quadro P4000
                        Device ID 10DE-1BB1
                        Revision A2
                        Subvendor NVIDIA (10DE)
                        Current Performance Level Level 0
                        Bus Interface PCI Express x16
                        Temperature 55 °C
                        Driver version 22.21.13.8205
                        BIOS Version 86.04.56.00.0b
                        Memory 4095 MB
                        Count of performance levels : 1
                        Level 1 - "Perf Level 0"
                        Storage
                        Hard drives
                        Intel Raid 0 Volume
                        Manufacturer Intel
                        Interface RAID
                        Capacity 7452 GB
                        Real size 8,001,569,161,216 bytes
                        RAID Type Software RAID
                        S.M.A.R.T
                        S.M.A.R.T not supported
                        Partition 0
                        Partition ID Disk #0, Partition #0
                        Disk Letter X:
                        File System NTFS
                        Volume Serial Number D8EDA6C1
                        Size 7451 GB
                        Used Space 4416 GB (59%)
                        Free Space 3035 GB (41%)
                        ST2000DX001-1NS164
                        Manufacturer Seagate
                        Heads 16
                        Cylinders 243,201
                        Tracks 62,016,255
                        Sectors 3,907,024,065
                        SATA type SATA-III 6.0Gb/s
                        Device type Fixed
                        ATA Standard ACS2
                        Serial Number Z4Z39F1G
                        Firmware Version Number CC41
                        LBA Size 48-bit LBA
                        Power On Count 1334 times
                        Power On Time 270.1 days
                        Speed 7200 RPM
                        Features S.M.A.R.T., APM, NCQ
                        Max. Transfer Mode SATA III 6.0Gb/s
                        Used Transfer Mode SATA III 6.0Gb/s
                        Interface SATA
                        Capacity 1863 GB
                        Real size 2,000,398,934,016 bytes
                        RAID Type None
                        S.M.A.R.T
                        Status Good
                        Temperature 31 °C
                        Temperature Range OK (less than 50 °C)
                        S.M.A.R.T attributes
                        01
                        Attribute name Read Error Rate
                        Real value 0
                        Current 114
                        Worst 99
                        Threshold 6
                        Raw Value 0004CBFB40
                        Status Good
                        03
                        Attribute name Spin-Up Time
                        Real value 0 ms
                        Current 96
                        Worst 94
                        Threshold 0
                        Raw Value 0000000000
                        Status Good
                        04
                        Attribute name Start/Stop Count
                        Real value 1,409
                        Current 99
                        Worst 99
                        Threshold 20
                        Raw Value 0000000581
                        Status Good
                        05
                        Attribute name Reallocated Sectors Count
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 10
                        Status Good
                        07
                        Attribute name Seek Error Rate
                        Real value 0
                        Current 77
                        Worst 60
                        Threshold 30
                        Raw Value 0003089347
                        Status Good
                        09
                        Attribute name Power-On Hours (POH)
                        Real value 270d 2h
                        Current 93
                        Worst 93
                        Threshold 0
                        Raw Value 0000001952
                        Status Good
                        0A
                        Attribute name Spin Retry Count
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 97
                        Status Good
                        0C
                        Attribute name Device Power Cycle Count
                        Real value 1,334
                        Current 99
                        Worst 99
                        Threshold 20
                        Raw Value 0000000536
                        Status Good
                        B7
                        Attribute name SATA Downshift Error Count
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        B8
                        Attribute name End-to-End error / IOEDC
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 99
                        Status Good
                        BB
                        Attribute name Reported Uncorrectable Errors
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        BC
                        Attribute name Command Timeout
                        Real value 4,295,098,371
                        Current 100
                        Worst 99
                        Threshold 0
                        Raw Value 0000020003
                        Status Good
                        BD
                        Attribute name High Fly Writes (WDC)
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        BE
                        Attribute name Airflow Temperature
                        Real value 31 °C
                        Current 69
                        Worst 56
                        Threshold 45
                        Raw Value 00221A001F
                        Status Good
                        BF
                        Attribute name G-sense error rate
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        C0
                        Attribute name Power-off Retract Count
                        Real value 114
                        Current 100
                        Worst 100
                        Threshold 0
                        Raw Value 0000000072
                        Status Good
                        C1
                        Attribute name Load/Unload Cycle Count
                        Real value 20,671
                        Current 90
                        Worst 90
                        Threshold 0
                        Raw Value 00000050BF
                        Status Good
                        C2
                        Attribute name Temperature
                        Real value 31 °C
                        Current 31
                        Worst 44
                        Threshold 0
                        Raw Value 000000001F
                        Status Good
                        C5
                        Attribute name Current Pending Sector Count
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        C6
                        Attribute name Uncorrectable Sector Count
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        C7
                        Attribute name UltraDMA CRC Error Count
                        Real value 1
                        Current 200
                        Worst 200
                        Threshold 0
                        Raw Value 0000000001
                        Status Good
                        F0
                        Attribute name Head Flying Hours
                        Real value 241d 16h
                        Current 100
                        Worst 253
                        Threshold 0
                        Raw Value 00000016A8
                        Status Good
                        F1
                        Attribute name Total LBAs Written
                        Real value 21,133,677,431
                        Current 100
                        Worst 253
                        Threshold 0
                        Raw Value 00EBAA5377
                        Status Good
                        F2
                        Attribute name Total LBAs Read
                        Real value 75,601,275,345
                        Current 100
                        Worst 253
                        Threshold 0
                        Raw Value 009A2FE9D1
                        Status Good
                        Partition 0
                        Partition ID Disk #1, Partition #0
                        Disk Letter D:
                        File System NTFS
                        Volume Serial Number 20B88602
                        Size 1862 GB
                        Used Space 1848 GB (99%)
                        Free Space 13.9 GB (1%)
                        Heads 16
                        Cylinders 45,600
                        Tracks 11,628,000
                        Sectors 732,564,000
                        Device type Fixed
                        ATA Standard ATA8-ACS
                        Serial Number Z1F02FE0
                        Firmware Version Number CC94
                        LBA Size 48-bit LBA
                        Power On Count Unknown
                        Power On Time Unknown
                        Speed 7200 RPM
                        Used Transfer Mode SATA II 3.0Gb/s
                        Interface USB (SATA)
                        Capacity 2794 GB
                        Real size 3,000,592,965,632 bytes
                        RAID Type None
                        S.M.A.R.T
                        Status Unknown
                        Partition 0
                        Partition ID Disk #10, Partition #0
                        Size 200 MB
                        Partition 1
                        Partition ID Disk #10, Partition #1
                        Disk Letter F:
                        File System HFS Plus
                        Volume Serial Number 546BDC25
                        Size 2794 GB
                        Used Space 2332 GB (83%)
                        Free Space 462 GB (17%)
                        Manufacturer SAMSUNG
                        Heads 16
                        Cylinders 124,519
                        Tracks 31,752,345
                        Sectors 2,000,397,735
                        Device type Fixed
                        ATA Standard ACS2
                        Serial Number S3D2NX0HB00871J
                        Firmware Version Number EXM03B6Q
                        LBA Size 48-bit LBA
                        Power On Count 657 times
                        Power On Time 96.3 days
                        Speed Not used (SSD Drive)
                        Features S.M.A.R.T., NCQ, TRIM, SSD
                        Interface SATA
                        Capacity 953 GB
                        Real size 1,024,209,543,168 bytes
                        RAID Type None
                        S.M.A.R.T
                        Status Good
                        Temperature 37 °C
                        05
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 10
                        Status Good
                        09
                        Real value 96d 6h
                        Current 99
                        Worst 99
                        Threshold 0
                        Raw Value 0000000906
                        Status Good
                        0C
                        Real value 657
                        Current 99
                        Worst 99
                        Threshold 0
                        Raw Value 0000000291
                        Status Good
                        B1
                        Attribute name Wear Leveling Count
                        Real value 20
                        Current 99
                        Worst 99
                        Threshold 0
                        Raw Value 0000000014
                        Status Good
                        B3
                        Attribute name Used Reserved Block Count (Total)
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 10
                        Status Good
                        B5
                        Attribute name Program Fail Count (Total)
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 10
                        Status Good
                        B6
                        Attribute name Erase Fail Count (Total)
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 10
                        Status Good
                        B7
                        Attribute name Runtime Bad Block (Total)
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 10
                        Status Good
                        BB
                        Attribute name Uncorrectable Error Count
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        BE
                        Attribute name Temperature Exceed Count
                        Real value 37
                        Current 63
                        Worst 49
                        Threshold 0
                        Raw Value 0000000025
                        Status Good
                        C3
                        Attribute name ECC Rate
                        Real value 0
                        Current 200
                        Worst 200
                        Threshold 0
                        Status Good
                        C7
                        Attribute name CRC Error Count
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        EB
                        Attribute name Power Recovery Count
                        Real value 170
                        Current 99
                        Worst 99
                        Threshold 0
                        Raw Value 00000000AA
                        Status Good
                        F1
                        Real value 24,694,645,353
                        Current 99
                        Worst 99
                        Threshold 0
                        Raw Value 00BFEA6269
                        Status Good
                        Partition 0
                        Partition ID Disk #2, Partition #0
                        File System NTFS
                        Volume Serial Number A8B40D1E
                        Size 499 MB
                        Used Space 376 MB (75%)
                        Free Space 123 MB (25%)
                        Partition 1
                        Partition ID Disk #2, Partition #1
                        Disk Letter C:
                        File System NTFS
                        Volume Serial Number F24DA06A
                        Size 953 GB
                        Used Space 833 GB (87%)
                        Free Space 119 GB (13%)
                        ST4000DX001-1CE168
                        Heads 16
                        Cylinders 486,401
                        Tracks 124,032,255
                        Sectors 7,814,032,065
                        Device type Fixed
                        ATA Standard ACS2
                        Serial Number Z306W58A
                        Firmware Version Number CC45
                        LBA Size 48-bit LBA
                        Power On Count 505 times
                        Power On Time 75.6 days
                        Speed 5900 RPM
                        Interface SATA
                        Capacity 3726 GB
                        Real size 4,000,787,030,016 bytes
                        RAID Type None
                        S.M.A.R.T
                        Status Good
                        Temperature 32 °C
                        01
                        Real value 0
                        Current 114
                        Worst 99
                        Threshold 6
                        Raw Value 00039C36C0
                        Status Good
                        03
                        Real value 0 ms
                        Current 93
                        Worst 91
                        Threshold 0
                        Status Good
                        04
                        Real value 698
                        Current 100
                        Worst 100
                        Threshold 20
                        Raw Value 00000002BA
                        Status Good
                        05
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 10
                        Status Good
                        07
                        Real value 0
                        Current 69
                        Worst 60
                        Threshold 30
                        Raw Value 000074D537
                        Status Good
                        09
                        Real value 75d 14h
                        Current 98
                        Worst 98
                        Threshold 0
                        Raw Value 0000000716
                        Status Good
                        0A
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 97
                        Status Good
                        0C
                        Real value 505
                        Current 100
                        Worst 100
                        Threshold 20
                        Raw Value 00000001F9
                        Status Good
                        B7
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        B8
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 99
                        Status Good
                        BB
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        BC
                        Real value 34,360,262,666
                        Current 100
                        Worst 98
                        Threshold 0
                        Raw Value 000008000A
                        Status Good
                        BD
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        BE
                        Real value 32 °C
                        Current 68
                        Worst 57
                        Threshold 45
                        Raw Value 00221A0020
                        Status Good
                        BF
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        C0
                        Real value 26
                        Current 100
                        Worst 100
                        Threshold 0
                        Raw Value 000000001A
                        Status Good
                        C1
                        Real value 6,362
                        Current 97
                        Worst 97
                        Threshold 0
                        Raw Value 00000018DA
                        Status Good
                        C2
                        Real value 32 °C
                        Current 32
                        Worst 43
                        Threshold 0
                        Raw Value 0000000020
                        Status Good
                        C5
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        C6
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        C7
                        Real value 0
                        Current 200
                        Worst 200
                        Threshold 0
                        Status Good
                        F0
                        Real value 87d 19h
                        Current 100
                        Worst 253
                        Threshold 0
                        Raw Value 000000083B
                        Status Good
                        F1
                        Real value 15,953,396,694
                        Current 100
                        Worst 253
                        Threshold 0
                        Raw Value 00B6E583D6
                        Status Good
                        F2
                        Real value 72,874,141,369
                        Current 100
                        Worst 253
                        Threshold 0
                        Raw Value 00F7A326B9
                        Status Good
                        Partition 0
                        Partition ID Disk #3, Partition #0
                        Disk Letter Y:
                        File System NTFS
                        Volume Serial Number D2BCA63A
                        Size 2047 GB
                        Used Space 2022 GB (98%)
                        Free Space 25.8 GB (2%)
                        Partition 1
                        Partition ID Disk #3, Partition #1
                        Disk Letter Z:
                        File System NTFS
                        Volume Serial Number 30D230EF
                        Size 1677 GB
                        Used Space 1305 GB (77%)
                        Free Space 372 GB (23%)
                        ST2000DX002-2DV164
                        Heads 16
                        Cylinders 243,201
                        Tracks 62,016,255
                        Device type Fixed
                        ATA Standard ACS2
                        Serial Number Z4Z56QDJ
                        LBA Size 48-bit LBA
                        Power On Count 702 times
                        Power On Time 102.3 days
                        Speed 7200 RPM
                        Interface SATA
                        Capacity 1863 GB
                        RAID Type None
                        S.M.A.R.T
                        Status Good
                        Temperature 33 °C
                        01
                        Real value 0
                        Current 116
                        Worst 99
                        Threshold 6
                        Raw Value 00067338A0
                        Status Good
                        03
                        Real value 0 ms
                        Current 96
                        Worst 95
                        Threshold 0
                        Status Good
                        04
                        Real value 954
                        Current 100
                        Worst 100
                        Threshold 20
                        Raw Value 00000003BA
                        Status Good
                        05
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 10
                        Status Good
                        07
                        Real value 0
                        Current 67
                        Worst 60
                        Threshold 30
                        Raw Value 00005B3136
                        Status Good
                        09
                        Real value 102d 8h
                        Current 98
                        Worst 98
                        Threshold 0
                        Raw Value 0000000998
                        Status Good
                        0A
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 97
                        Status Good
                        0C
                        Real value 702
                        Current 100
                        Worst 100
                        Threshold 20
                        Raw Value 00000002BE
                        Status Good
                        B7
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        B8
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 99
                        Status Good
                        BB
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        BC
                        Real value 1
                        Current 100
                        Worst 99
                        Threshold 0
                        Status Good
                        BD
                        Real value 1
                        Current 99
                        Worst 99
                        Threshold 0
                        Status Good
                        BE
                        Real value 33 °C
                        Current 67
                        Worst 56
                        Threshold 45
                        Raw Value 00231A0021
                        Status Good
                        BF
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        C0
                        Real value 84
                        Current 100
                        Worst 100
                        Threshold 0
                        Raw Value 0000000054
                        Status Good
                        C1
                        Real value 4,379
                        Current 98
                        Worst 98
                        Threshold 0
                        Raw Value 000000111B
                        Status Good
                        C2
                        Real value 33 °C
                        Current 33
                        Worst 44
                        Threshold 0
                        Raw Value 0000000021
                        Status Good
                        C5
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        C6
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        C7
                        Real value 0
                        Current 200
                        Worst 200
                        Threshold 0
                        Status Good
                        F0
                        Real value 122d 8h
                        Current 100
                        Worst 253
                        Threshold 0
                        Raw Value 0000000B78
                        Status Good
                        F1
                        Real value 9,484,575,358
                        Current 100
                        Worst 253
                        Threshold 0
                        Raw Value 003553227E
                        Status Good
                        F2
                        Real value 44,148,658,407
                        Current 100
                        Worst 253
                        Threshold 0
                        Raw Value 00477710E7
                        Status Good
                        Partition 0
                        Partition ID Disk #4, Partition #0
                        Size 1.81 TB
                        ST2000DX002-2DV164
                        Heads 16
                        Cylinders 243,201
                        Tracks 62,016,255
                        Device type Fixed
                        ATA Standard ACS2
                        Serial Number Z4Z652V8
                        LBA Size 48-bit LBA
                        Power On Count 695 times
                        Power On Time 108.5 days
                        Speed 7200 RPM
                        Interface SATA
                        Capacity 1863 GB
                        RAID Type None
                        S.M.A.R.T
                        Status Good
                        Temperature 33 °C
                        01
                        Real value 0
                        Current 117
                        Worst 99
                        Threshold 6
                        Raw Value 00077147F8
                        Status Good
                        03
                        Real value 0 ms
                        Current 96
                        Worst 94
                        Threshold 0
                        Status Good
                        04
                        Real value 740
                        Current 100
                        Worst 100
                        Threshold 20
                        Raw Value 00000002E4
                        Status Good
                        05
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 10
                        Status Good
                        07
                        Real value 0
                        Current 69
                        Worst 60
                        Threshold 30
                        Raw Value 00008E83FB
                        Status Good
                        09
                        Real value 108d 11h
                        Current 98
                        Worst 98
                        Threshold 0
                        Raw Value 0000000A2B
                        Status Good
                        0A
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 97
                        Status Good
                        0C
                        Real value 695
                        Current 100
                        Worst 100
                        Threshold 20
                        Raw Value 00000002B7
                        Status Good
                        B7
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        B8
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 99
                        Status Good
                        BB
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        BC
                        Real value 1
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        BD
                        Real value 3
                        Current 97
                        Worst 97
                        Threshold 0
                        Raw Value 0000000003
                        Status Good
                        BE
                        Real value 33 °C
                        Current 67
                        Worst 57
                        Threshold 45
                        Status Good
                        BF
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        C0
                        Real value 65
                        Current 100
                        Worst 100
                        Threshold 0
                        Raw Value 0000000041
                        Status Good
                        C1
                        Real value 7,049
                        Current 97
                        Worst 97
                        Threshold 0
                        Raw Value 0000001B89
                        Status Good
                        C2
                        Real value 33 °C
                        Current 33
                        Worst 43
                        Threshold 0
                        Status Good
                        C5
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        C6
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        C7
                        Real value 0
                        Current 200
                        Worst 200
                        Threshold 0
                        Status Good
                        F0
                        Real value 111d 8h
                        Current 100
                        Worst 253
                        Threshold 0
                        Raw Value 0000000A70
                        Status Good
                        F1
                        Real value 9,982,350,435
                        Current 100
                        Worst 253
                        Threshold 0
                        Raw Value 0052FE9463
                        Status Good
                        F2
                        Real value 56,083,348,467
                        Current 100
                        Worst 253
                        Threshold 0
                        Raw Value 000ED3FBF3
                        Status Good
                        Partition 0
                        Partition ID Disk #5, Partition #0
                        Disk Letter E:
                        File System NTFS
                        Volume Serial Number 040F4A3F
                        Size 1863 GB
                        Used Space 1713 GB (91%)
                        Free Space 149 GB (9%)
                        ST33000651AS
                        Form Factor 3.5"
                        Heads 16
                        Cylinders 364,801
                        Tracks 93,024,255
                        Sectors 5,860,528,065
                        Device type Fixed
                        Serial Number Z2930SZ8
                        LBA Size 48-bit LBA
                        Power On Count 1948 times
                        Power On Time 392.2 days
                        Speed 7200 RPM
                        Features S.M.A.R.T., AAM, NCQ
                        Interface SATA
                        Capacity 2794 GB
                        Real size 3,000,592,982,016 bytes
                        RAID Type None
                        S.M.A.R.T
                        Status Warning
                        Temperature 38 °C
                        01
                        Real value 0
                        Current 117
                        Worst 99
                        Threshold 6
                        Raw Value 00094A4CAC
                        Status Good
                        03
                        Real value 0 ms
                        Current 90
                        Worst 89
                        Threshold 0
                        Status Good
                        04
                        Real value 2,773
                        Current 98
                        Worst 98
                        Threshold 20
                        Raw Value 0000000AD5
                        Status Good
                        05
                        Real value 160
                        Current 99
                        Worst 99
                        Threshold 36
                        Raw Value 00000000A0
                        Status Good
                        07
                        Real value 0
                        Current 76
                        Worst 60
                        Threshold 30
                        Raw Value 0002FD728E
                        Status Good
                        09
                        Real value 392d 4h
                        Current 90
                        Worst 90
                        Threshold 0
                        Raw Value 00000024C4
                        Status Good
                        0A
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 97
                        Status Good
                        0C
                        Real value 1,948
                        Current 99
                        Worst 99
                        Threshold 20
                        Raw Value 000000079C
                        Status Good
                        B7
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        B8
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 99
                        Status Good
                        BB
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        BC
                        Real value 30,065,229,831
                        Current 100
                        Worst 99
                        Threshold 0
                        Raw Value 0000070007
                        Status Good
                        BD
                        Real value 1
                        Current 99
                        Worst 99
                        Threshold 0
                        Status Good
                        BE
                        Real value 38 °C
                        Current 62
                        Worst 47
                        Threshold 45
                        Raw Value 00281C0026
                        Status Good
                        BF
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        C0
                        Real value 438
                        Current 100
                        Worst 100
                        Threshold 0
                        Raw Value 00000001B6
                        Status Good
                        C1
                        Real value 2,849
                        Current 99
                        Worst 99
                        Threshold 0
                        Raw Value 0000000B21
                        Status Good
                        C2
                        Real value 38 °C
                        Current 38
                        Worst 53
                        Threshold 0
                        Raw Value 0000000026
                        Status Good
                        C3
                        Attribute name Hardware ECC Recovered
                        Real value 0
                        Current 21
                        Worst 4
                        Threshold 0
                        Status Good
                        C5
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        C6
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        C7
                        Real value 0
                        Current 200
                        Worst 200
                        Threshold 0
                        Status Good
                        F0
                        Real value 376d 15h
                        Current 100
                        Worst 253
                        Threshold 0
                        Raw Value 000000234F
                        Status Good
                        F1
                        Real value 4,029,443,756
                        Current 100
                        Worst 253
                        Threshold 0
                        Raw Value 00F02C6EAC
                        Status Good
                        F2
                        Real value 1,852,017,317
                        Current 100
                        Worst 253
                        Threshold 0
                        Raw Value 006E638AA5
                        Status Good
                        Partition 0
                        Partition ID Disk #6, Partition #0
                        Size 1.00 MB
                        Partition 1
                        Partition ID Disk #6, Partition #1
                        Size 2.72 TB
                        Manufacturer Western Digital
                        Heads 16
                        Cylinders 45,599
                        Tracks 11,627,745
                        Sectors 732,547,935
                        Device type Fixed
                        ATA Standard ACS2
                        Serial Number WD-WCC4N6TPSCNC
                        Firmware Version Number 80.00A80
                        LBA Size 48-bit LBA
                        Power On Count 538 times
                        Power On Time 35.5 days
                        Speed 5400 RPM
                        Capacity 2794 GB
                        Real size 3,000,558,944,256 bytes
                        RAID Type None
                        S.M.A.R.T
                        Status Good
                        Temperature 30 °C
                        01
                        Real value 0
                        Current 200
                        Worst 200
                        Threshold 51
                        Status Good
                        03
                        Real value 6375 ms
                        Current 172
                        Worst 171
                        Threshold 21
                        Raw Value 00000018E7
                        Status Good
                        04
                        Real value 541
                        Current 100
                        Worst 100
                        Threshold 0
                        Raw Value 000000021D
                        Status Good
                        05
                        Real value 0
                        Current 200
                        Worst 200
                        Threshold 140
                        Status Good
                        07
                        Real value 0
                        Current 100
                        Worst 253
                        Threshold 0
                        Status Good
                        09
                        Real value 35d 12h
                        Current 99
                        Worst 99
                        Threshold 0
                        Raw Value 0000000354
                        Status Good
                        0A
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        0B
                        Attribute name Recalibration Retries
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        0C
                        Real value 538
                        Current 100
                        Worst 100
                        Threshold 0
                        Raw Value 000000021A
                        Status Good
                        C0
                        Real value 324
                        Current 200
                        Worst 200
                        Threshold 0
                        Raw Value 0000000144
                        Status Good
                        C1
                        Real value 13,038
                        Current 196
                        Worst 196
                        Threshold 0
                        Raw Value 00000032EE
                        Status Good
                        C2
                        Real value 30 °C
                        Current 120
                        Worst 101
                        Threshold 0
                        Raw Value 000000001E
                        Status Good
                        C4
                        Attribute name Reallocation Event Count
                        Real value 0
                        Current 200
                        Worst 200
                        Threshold 0
                        Status Good
                        C5
                        Real value 0
                        Current 200
                        Worst 200
                        Threshold 0
                        Status Good
                        C6
                        Real value 0
                        Current 200
                        Worst 200
                        Threshold 0
                        Status Good
                        C7
                        Real value 0
                        Current 200
                        Worst 200
                        Threshold 0
                        Status Good
                        C8
                        Attribute name Write Error Rate / Multi-Zone Error Rate
                        Real value 0
                        Current 200
                        Worst 200
                        Threshold 0
                        Status Good
                        Partition 0
                        Partition ID Disk #7, Partition #0
                        Size 300 MB
                        Partition 1
                        Partition ID Disk #7, Partition #1
                        Disk Letter H:
                        Volume Serial Number C5B5F8F5
                        Size 2794 GB
                        Used Space 2548 GB (91%)
                        Free Space 245 GB (9%)
                        Heads 16
                        Cylinders 45,599
                        Tracks 11,627,745
                        Sectors 732,547,935
                        Device type Fixed
                        ATA Standard ACS2
                        Serial Number WD-WCC4E2FAER0T
                        LBA Size 48-bit LBA
                        Power On Count 1742 times
                        Power On Time 72.6 days
                        Speed 5400 RPM
                        Capacity 2794 GB
                        RAID Type None
                        S.M.A.R.T
                        Status Good
                        Temperature 32 °C
                        01
                        Real value 0
                        Current 200
                        Worst 200
                        Threshold 51
                        Raw Value 000000002C
                        Status Good
                        03
                        Real value 8066 ms
                        Current 178
                        Worst 175
                        Threshold 21
                        Raw Value 0000001F82
                        Status Good
                        04
                        Real value 1,760
                        Current 99
                        Worst 99
                        Threshold 0
                        Raw Value 00000006E0
                        Status Good
                        05
                        Real value 0
                        Current 200
                        Worst 200
                        Threshold 140
                        Status Good
                        07
                        Real value 0
                        Current 100
                        Worst 253
                        Threshold 0
                        Status Good
                        09
                        Real value 72d 15h
                        Current 98
                        Worst 98
                        Threshold 0
                        Raw Value 00000006CF
                        Status Good
                        0A
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        0B
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        0C
                        Real value 1,742
                        Current 99
                        Worst 99
                        Threshold 0
                        Raw Value 00000006CE
                        Status Good
                        C0
                        Real value 1,057
                        Current 199
                        Worst 199
                        Threshold 0
                        Raw Value 0000000421
                        Status Good
                        C1
                        Real value 38,346
                        Current 188
                        Worst 188
                        Threshold 0
                        Raw Value 00000095CA
                        Status Good
                        C2
                        Real value 32 °C
                        Current 120
                        Worst 97
                        Threshold 0
                        Status Good
                        C4
                        Real value 0
                        Current 200
                        Worst 200
                        Threshold 0
                        Status Good
                        C5
                        Real value 0
                        Current 200
                        Worst 200
                        Threshold 0
                        Status Good
                        C6
                        Real value 1
                        Current 200
                        Worst 200
                        Threshold 0
                        Status Good
                        C7
                        Real value 0
                        Current 200
                        Worst 200
                        Threshold 0
                        Status Good
                        C8
                        Real value 2
                        Current 200
                        Worst 200
                        Threshold 0
                        Raw Value 0000000002
                        Status Good
                        Partition 0
                        Partition ID Disk #8, Partition #0
                        Size 300 MB
                        Partition 1
                        Partition ID Disk #8, Partition #1
                        Disk Letter G:
                        Volume Serial Number 61C22F79
                        Size 2794 GB
                        Used Space 2138 GB (76%)
                        Free Space 655 GB (24%)
                        Form Factor GB/2.5-inch
                        Heads 16
                        Cylinders 243,197
                        Tracks 62,015,235
                        Sectors 3,906,959,805
                        Device type Fixed
                        ATA Standard ACS2
                        Serial Number WD-WCC4M0442261
                        LBA Size 48-bit LBA
                        Power On Count 393 times
                        Power On Time 132.4 days
                        Speed 5400 RPM
                        Capacity 1862 GB
                        Real size 2,000,365,289,472 bytes
                        RAID Type None
                        S.M.A.R.T
                        Status Good
                        Temperature 37 °C
                        01
                        Real value 0
                        Current 200
                        Worst 200
                        Threshold 51
                        Status Good
                        03
                        Real value 4091 ms
                        Current 178
                        Worst 169
                        Threshold 21
                        Raw Value 0000000FFB
                        Status Good
                        04
                        Real value 1,504
                        Current 99
                        Worst 99
                        Threshold 0
                        Raw Value 00000005E0
                        Status Good
                        05
                        Real value 0
                        Current 200
                        Worst 200
                        Threshold 140
                        Status Good
                        07
                        Real value 0
                        Current 100
                        Worst 253
                        Threshold 0
                        Status Good
                        09
                        Real value 132d 9h
                        Current 96
                        Worst 96
                        Threshold 0
                        Raw Value 0000000C69
                        Status Good
                        0A
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        0B
                        Real value 0
                        Current 100
                        Worst 100
                        Threshold 0
                        Status Good
                        0C
                        Real value 393
                        Current 100
                        Worst 100
                        Threshold 0
                        Raw Value 0000000189
                        Status Good
                        C0
                        Real value 71
                        Current 200
                        Worst 200
                        Threshold 0
                        Raw Value 0000000047
                        Status Good
                        C1
                        Real value 1,432
                        Current 200
                        Worst 200
                        Threshold 0
                        Raw Value 0000000598
                        Status Good
                        C2
                        Real value 37 °C
                        Current 110
                        Worst 98
                        Threshold 0
                        Status Good
                        C4
                        Real value 0
                        Current 200
                        Worst 200
                        Threshold 0
                        Status Good
                        C5
                        Real value 0
                        Current 200
                        Worst 200
                        Threshold 0
                        Status Good
                        C6
                        Real value 0
                        Current 100
                        Worst 253
                        Threshold 0
                        Status Good
                        C7
                        Real value 0
                        Current 200
                        Worst 200
                        Threshold 0
                        Status Good
                        C8
                        Real value 0
                        Current 100
                        Worst 253
                        Threshold 0
                        Status Good
                        Partition 0
                        Partition ID Disk #9, Partition #0
                        Size 200 MB
                        Partition 1
                        Partition ID Disk #9, Partition #1
                        Disk Letter I:
                        Volume Serial Number 94DE0C25
                        Size 1862 GB
                        Used Space 1437 GB (77%)
                        Free Space 425 GB (23%)
                        Optical Drives
                        No optical disk drives detected
                        Audio
                        Sound Cards
                        Blackmagic Audio
                        NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
                        Playback Devices
                        Speakers (Realtek High Definition Audio) (default)
                        Peripherals
                        HID Keyboard Device
                        Device Kind Keyboard
                        Device Name HID Keyboard Device
                        Vendor Unknown
                        Location USB Input Device
                        Driver
                        Date 6-21-2006
                        Version 10.0.15063.0
                        File C:\Windows\system32\DRIVERS\kbdhid.sys
                        File C:\Windows\system32\DRIVERS\kbdclass.sys
                        HID-compliant mouse
                        Device Kind Mouse
                        Device Name HID-compliant mouse
                        Vendor PixArt Imaging
                        Location HID-compliand device
                        Driver
                        Date 6-21-2006
                        File C:\Windows\system32\DRIVERS\mouhid.sys
                        File C:\Windows\system32\DRIVERS\mouclass.sys
                        HP LaserJet Pro MFP M125-M126 PCLmS
                        Device Kind Printer
                        Device Name HP LaserJet Pro MFP M125-M126 PCLmS
                        Vendor Hewlett Packard
                        Location DEVFB58FE (HP LaserJet Pro MFP M126nw)
                        Driver
                        Date 9-6-2013
                        Version 11.21.0.2679
                        File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\hppclms_125- 128.gpd
                        File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\hptps-pipeli neconfig.xml
                        File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\hpbxpsrender .dll
                        File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\UNIDRV.DLL
                        File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\UNIRES.DLL
                        File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\UNIDRVUI.DLL
                        File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\STDNAMES.GPD
                        File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\STDDTYPE.GDL
                        File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\STDSCHEM.GDL
                        File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\STDSCHMX.GDL
                        File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\UNIDRV.HLP
                        File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\LOCALE.GPD
                        File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\mxdwdrv.dll
                        File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\xpssvcs.dll
                        File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\hpmacronames f8.gpd
                        File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\hpxtpsdrvf8. dll
                        File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\hpxtpsUIf8.d ll
                        File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\hpxtpsresf8. dll
                        File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\hpxtpsUIDial ogf8.dll
                        File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\MSXPSINC.GPD
                        File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\hpcm125126.i ni
                        File C:\Windows\system32\spool\DRIVERS\x64\{8C470F0C-011C-4994-BBF9-3E7E897489D3}\MXDWDRV.DLL
                        HP LJ M125126 Scan Drv
                        Device Kind Camera/scanner
                        Device Name HP LJ M125126 Scan Drv
                        Vendor Hewlett-Packard
                        Driver
                        Date 4-29-2015
                        Version 36.0.75.24896
                        File C:\Windows\system32\hpwia2_lj125126.dll
                        File C:\Windows\system32\hppscancoins64.dll
                        File C:\Windows\system32\hpptsplj125126_x64.dll
                        File C:\Windows\system32\hpzjcd01scan.dll
                        File C:\Windows\SysWOW64\hpptsplj125126.dll
                        File C:\Windows\system32\drivers\usbscan.sys
                        WSD Scan Device
                        Device Name WSD Scan Device
                        Comment DEVFB58FE (HP LaserJet Pro MFP M126nw)
                        Location http://192.168.1.70:3911/c995a693-2120-739f-7245-b9b0055dede2
                        Driver
                        Date 6-21-2006
                        File C:\Windows\system32\DRIVERS\WSDScan.sys
                        My Book 111D
                        Device Kind Portable Device
                        Device Name My Book 111D
                        Vendor WD
                        Comment I:\
                        Location Volume
                        Driver
                        Date 6-21-2006
                        Version 10.0.15063.502
                        File C:\Windows\System32\drivers\WUDFRd.sys
                        Elements 107C
                        Device Name Elements 107C
                        Vendor WD
                        Comment H:\
                        Location Volume
                        Driver
                        Date 6-21-2006
                        Elements 107C
                        Vendor WD
                        Comment G:\
                        Location Volume
                        Driver
                        Date 6-21-2006
                        FA GoFlex Desk
                        Device Name FA GoFlex Desk
                        Vendor Seagate
                        Comment K2 Unlimited
                        Location Volume
                        Driver
                        Date 6-21-2006
                        Printers
                        Adobe PDF
                        Printer Port Documents\*.pdf
                        Print Processor winprint
                        Availability Always
                        Priority 1
                        Duplex None
                        Print Quality 1200 * 1200 dpi Color
                        Status Unknown
                        Driver
                        Driver Name Adobe PDF Converter (v6.03)
                        Driver Path C:\Windows\system32\spool\DRIVERS\x64\3\PSCRIPT5.DLL
                        Fax
                        Printer Port SHRFAX:
                        Availability Always
                        Priority 1
                        Duplex None
                        Print Quality 200 * 200 dpi Monochrome
                        Status Unknown
                        Driver
                        Driver Name Microsoft Shared Fax Driver (v4.00)
                        Driver Path C:\Windows\system32\spool\DRIVERS\x64\3\FXSDRV.DLL
                        Final Draft PDF Converter 4
                        Printer Port NUL:
                        Availability Always
                        Priority 1
                        Duplex None
                        Print Quality 600 dpi Color
                        Status Unknown
                        Driver
                        Driver Name Amyuni Document Converter 400 (v0.64)
                        Driver Path C:\Windows\system32\spool\DRIVERS\x64\3\acpdf400.dll
                        HP LaserJet Pro MFP M126nw (Default Printer)
                        Printer Port WSD-6cc21a8a-3ec9-4ac3-a4b4-20161a2efca9.0035
                        Availability Always
                        Priority 1
                        Duplex None
                        Print Quality 600 * 600 dpi Monochrome
                        Status Unknown
                        Driver
                        Driver Name HP LaserJet Pro MFP M125-M126 PCLmS (v6.03)
                        Driver Path C:\Windows\system32\spool\DRIVERS\x64\3\mxdwdrv.dll
                        Microsoft Print to PDF
                        Printer Port PORTPROMPT:
                        Availability Always
                        Priority 1
                        Duplex None
                        Print Quality 600 * 600 dpi Color
                        Status Unknown
                        Driver
                        Driver Name Microsoft Print To PDF (v6.03)
                        Driver Path C:\Windows\System32\DriverStore\FileRepository\ntprint.inf_amd64_8c30031d8d0a5589\Amd64\m xdwdrv.dll
                        Microsoft XPS Document Writer
                        Availability Always
                        Priority 1
                        Duplex None
                        Status Unknown
                        Driver
                        Driver Name Microsoft XPS Document Writer v4 (v6.03)
                        Send To OneNote 16
                        Printer Port NUL:
                        Availability Always
                        Priority 1
                        Duplex None
                        Status Unknown
                        Driver
                        Driver Name Send to Microsoft OneNote 16 Driver (v6.03)
                        Network
                        You are connected to the internet
                        Connected through Intel I210 Gigabit Network Connection
                        IP Address 192.168.1.140
                        Subnet mask 255.255.255.0
                        Gateway server 192.168.1.1
                        Preferred DNS server 192.168.1.1
                        DHCP Enabled
                        DHCP server 192.168.1.1
                        External IP Address 103.57.254.22
                        Adapter Type Ethernet
                        NetBIOS over TCP/IP Enabled via DHCP
                        NETBIOS Node Type Hybrid node
                        Link Speed 269.9 KBps
                        Computer Name
                        NetBIOS Name ANDMEDIATWO
                        DNS Name AndMediaTwo
                        Membership Part of workgroup
                        Workgroup ANDMEDIA
                        Remote Desktop
                        Disabled
                        Console
                        State Active
                        Domain ANDMEDIATWO
                        WinInet Info
                        LAN Connection
                        Local system uses a local area network to connect to the Internet
                        Local system has RAS to connect to the Internet
                        Wi-Fi Info
                        Wi-Fi not enabled
                        WinHTTPInfo
                        WinHTTPSessionProxyType No proxy
                        Session Proxy
                        Session Proxy Bypass
                        Connect Retries 5
                        Connect Timeout (ms) 60,000
                        HTTP Version HTTP 1.1
                        Max Connects Per 1.0 Servers INFINITE
                        Max Connects Per Servers INFINITE
                        Max HTTP automatic redirects 10
                        Max HTTP status continue 10
                        Send Timeout (ms) 30,000
                        IEProxy Auto Detect Yes
                        IEProxy Auto Config
                        IEProxy
                        IEProxy Bypass
                        Default Proxy Config Access Type No proxy
                        Default Config Proxy
                        Default Config Proxy Bypass
                        Sharing and Discovery
                        Network Discovery Enabled
                        File and Printer Sharing Enabled
                        File and printer sharing service Enabled
                        Simple File Sharing Enabled
                        Administrative Shares Enabled
                        Adapters List
                        Enabled
                        Connection Name Bluetooth Network Connection 5
                        DHCP enabled Yes
                        MAC Address 00-1A-7D-DA-71-11
                        Intel(R) Ethernet Connection (2) I218-LM
                        Connection Name Ethernet 2
                        DHCP enabled Yes
                        MAC Address 34-97-F6-00-99-F3
                        Intel(R) I210 Gigabit Network Connection
                        NetBIOS over TCPIP Yes
                        DHCP enabled Yes
                        MAC Address 34-97-F6-00-99-F4
                        DHCP 192.168.1.1
                        DNS Server 192.168.1.1
                        TeamViewer VPN Adapter
                        Connection Name Ethernet 3
                        DHCP enabled Yes
                        MAC Address 00-FF-84-C3-8F-20
                        Network Shares
                        Users C:\Users
                        Share C:\Users\Public\Share
                        Current TCP Connections
                        C:\Program Files (x86)\Adobe\Adobe Creative Cloud\ACC\Creative Cloud.exe (18984)
                        Local 192.168.1.140:50140 ESTABLISHED Remote 162.247.242.20:443 (Querying... ) (HTTPS)
                        C:\Program Files (x86)\Adobe\Adobe Creative Cloud\CCLibrary\libs\node.exe (19092)
                        Local 127.0.0.1:50159 LISTEN
                        C:\Program Files (x86)\Adobe\Adobe Sync\CoreSync\CoreSync.exe (20340)
                        Local 192.168.1.140:61461 ESTABLISHED Remote 54.235.95.139:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61895 ESTABLISHED Remote 54.250.233.211:443 (Querying... ) (HTTPS)
                        C:\Program Files (x86)\ASUS\AI Suite III\Push Notice\PushNotifyServer.exe (7800)
                        Local 0.0.0.0:8050 LISTEN
                        C:\Program Files (x86)\Blackmagic Design\Blackmagic Desktop Video\BMDStreamingServer.exe (17380)
                        Local 127.0.0.1:13823 LISTEN
                        Local 127.0.0.1:13823 ESTABLISHED Remote 127.0.0.1:49799 (Querying... )
                        C:\Program Files (x86)\Blackmagic Design\Blackmagic Desktop Video\CheckVersionPCI.exe (13492)
                        Local 127.0.0.1:49799 ESTABLISHED Remote 127.0.0.1:13823 (Querying... )
                        C:\Program Files (x86)\Common Files\Adobe\Adobe Desktop Common\ADS\Adobe Desktop Service.exe (19536)
                        Local 127.0.0.1:15292 LISTEN
                        Local 192.168.1.140:50118 ESTABLISHED Remote 54.174.15.225:443 (Querying... ) (HTTPS)
                        C:\Program Files (x86)\Google\Chrome\Application\chrome.exe (14740)
                        Local 192.168.1.140:61568 ESTABLISHED Remote 104.16.89.20:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61470 ESTABLISHED Remote 204.93.89.33:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61876 CLOSE-WAIT Remote 52.38.131.240:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61877 ESTABLISHED Remote 104.16.80.166:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61878 ESTABLISHED Remote 172.217.26.232:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61879 ESTABLISHED Remote 151.101.24.134:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61880 ESTABLISHED Remote 151.101.24.134:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61469 ESTABLISHED Remote 204.93.89.33:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61882 ESTABLISHED Remote 74.125.200.93:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61885 ESTABLISHED Remote 216.58.199.162:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61886 ESTABLISHED Remote 216.58.199.162:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61889 ESTABLISHED Remote 216.58.203.194:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61890 ESTABLISHED Remote 216.58.203.194:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61067 ESTABLISHED Remote 74.125.130.188:5228 (Querying... )
                        Local 192.168.1.140:61284 ESTABLISHED Remote 204.93.89.33:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61291 ESTABLISHED Remote 204.93.89.33:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61312 ESTABLISHED Remote 204.93.89.33:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61407 ESTABLISHED Remote 204.93.89.33:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61439 ESTABLISHED Remote 74.208.215.59:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61720 ESTABLISHED Remote 216.58.203.142:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61721 CLOSE-WAIT Remote 161.202.1.7:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61722 CLOSE-WAIT Remote 161.202.1.7:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61723 ESTABLISHED Remote 52.222.136.24:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61718 ESTABLISHED Remote 104.122.122.131:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61728 ESTABLISHED Remote 74.125.68.154:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61716 ESTABLISHED Remote 108.177.97.103:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61714 ESTABLISHED Remote 216.58.203.131:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61732 ESTABLISHED Remote 202.134.152.202:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61733 ESTABLISHED Remote 52.222.135.131:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61734 ESTABLISHED Remote 216.58.203.131:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61739 ESTABLISHED Remote 151.101.64.196:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61749 ESTABLISHED Remote 74.125.68.95:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61750 ESTABLISHED Remote 74.125.68.95:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61751 CLOSE-WAIT Remote 104.19.193.102:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61712 ESTABLISHED Remote 216.58.203.131:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61705 ESTABLISHED Remote 216.58.203.138:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61754 ESTABLISHED Remote 120.138.127.81:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61755 ESTABLISHED Remote 52.222.135.252:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61756 ESTABLISHED Remote 216.58.199.162:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61757 ESTABLISHED Remote 210.176.156.21:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61758 ESTABLISHED Remote 210.176.156.21:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61759 ESTABLISHED Remote 210.176.156.21:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61760 ESTABLISHED Remote 52.222.136.244:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61704 ESTABLISHED Remote 74.125.68.95:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61763 ESTABLISHED Remote 216.58.203.142:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61764 ESTABLISHED Remote 31.13.78.17:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61703 ESTABLISHED Remote 151.101.8.64:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61769 ESTABLISHED Remote 151.101.8.166:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61774 CLOSE-WAIT Remote 34.202.239.120:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61702 ESTABLISHED Remote 151.101.8.64:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61777 ESTABLISHED Remote 151.101.8.166:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61778 ESTABLISHED Remote 151.101.8.166:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61779 ESTABLISHED Remote 151.101.8.166:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61780 ESTABLISHED Remote 216.58.203.130:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61701 ESTABLISHED Remote 151.101.8.64:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61783 ESTABLISHED Remote 151.101.9.108:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61784 CLOSE-WAIT Remote 34.202.239.120:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61700 ESTABLISHED Remote 151.101.8.64:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61788 ESTABLISHED Remote 202.134.152.201:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61790 CLOSE-WAIT Remote 199.96.57.6:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61699 ESTABLISHED Remote 151.101.8.64:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61673 ESTABLISHED Remote 151.101.8.64:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61798 ESTABLISHED Remote 151.101.10.2:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61799 ESTABLISHED Remote 151.101.40.134:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61800 ESTABLISHED Remote 216.58.203.141:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61801 ESTABLISHED Remote 151.101.40.134:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61802 ESTABLISHED Remote 216.58.203.131:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61672 ESTABLISHED Remote 151.101.8.64:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61671 ESTABLISHED Remote 151.101.8.64:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61805 ESTABLISHED Remote 216.58.203.129:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61670 ESTABLISHED Remote 151.101.8.64:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61669 ESTABLISHED Remote 151.101.8.64:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61808 ESTABLISHED Remote 31.13.78.35:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61810 ESTABLISHED Remote 148.69.64.76:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61812 ESTABLISHED Remote 216.58.203.194:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61817 ESTABLISHED Remote 120.138.127.81:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61820 ESTABLISHED Remote 120.138.127.81:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61821 ESTABLISHED Remote 120.138.127.81:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61668 ESTABLISHED Remote 66.235.159.165:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61823 CLOSE-WAIT Remote 52.11.253.14:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61824 ESTABLISHED Remote 216.58.220.162:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61825 CLOSE-WAIT Remote 54.254.201.68:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61827 ESTABLISHED Remote 161.170.238.122:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61830 ESTABLISHED Remote 54.206.87.167:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61649 ESTABLISHED Remote 66.235.159.165:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61834 ESTABLISHED Remote 216.58.203.142:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61835 ESTABLISHED Remote 31.13.78.35:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61616 ESTABLISHED Remote 120.138.106.206:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61837 ESTABLISHED Remote 107.178.242.198:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61838 ESTABLISHED Remote 52.222.135.55:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61613 ESTABLISHED Remote 66.235.159.165:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61840 ESTABLISHED Remote 210.176.156.45:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61842 ESTABLISHED Remote 103.229.206.182:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61609 ESTABLISHED Remote 103.51.152.69:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61844 CLOSE-WAIT Remote 104.244.43.209:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61845 ESTABLISHED Remote 216.58.199.162:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61608 ESTABLISHED Remote 103.51.152.69:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61848 ESTABLISHED Remote 148.69.64.76:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61849 ESTABLISHED Remote 216.58.203.129:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61850 ESTABLISHED Remote 216.58.220.162:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61607 ESTABLISHED Remote 103.51.152.69:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61852 ESTABLISHED Remote 31.13.78.17:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61853 ESTABLISHED Remote 172.217.24.35:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61606 ESTABLISHED Remote 103.51.152.69:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61858 CLOSE-WAIT Remote 34.194.121.84:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61605 ESTABLISHED Remote 103.51.152.69:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61860 ESTABLISHED Remote 104.244.42.8:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61719 ESTABLISHED Remote 216.58.203.136:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61862 CLOSE-WAIT Remote 34.194.121.84:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61863 ESTABLISHED Remote 54.206.87.167:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61864 ESTABLISHED Remote 104.16.80.166:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61865 ESTABLISHED Remote 104.16.80.166:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61866 ESTABLISHED Remote 104.16.80.166:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61867 ESTABLISHED Remote 151.101.0.134:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61604 ESTABLISHED Remote 103.51.152.69:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61587 ESTABLISHED Remote 104.16.89.20:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61571 ESTABLISHED Remote 104.16.89.20:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61871 CLOSE-WAIT Remote 52.38.131.240:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61872 ESTABLISHED Remote 151.101.0.134:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61873 ESTABLISHED Remote 54.206.87.167:80 (Querying... ) (HTTP)
                        C:\Program Files (x86)\Google\Drive\googledrivesync.exe (18200)
                        Local 192.168.1.140:50012 CLOSE-WAIT Remote 216.58.197.42:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:50014 CLOSE-WAIT Remote 216.58.197.42:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:60282 ESTABLISHED Remote 74.125.68.125:5222 (Querying... )
                        Local 192.168.1.140:61466 CLOSE-WAIT Remote 216.58.197.74:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61113 CLOSE-WAIT Remote 216.58.203.141:443 (Querying... ) (HTTPS)
                        C:\Program Files (x86)\NVIDIA Corporation\NVIDIA GeForce Experience\NVIDIA Share.exe (17240)
                        Local 127.0.0.1:49923 ESTABLISHED Remote 127.0.0.1:49850 (Querying... )
                        C:\Program Files (x86)\NVIDIA Corporation\NvNode\NVIDIA Web Helper.exe (16836)
                        Local 127.0.0.1:49850 LISTEN
                        Local 127.0.0.1:49850 ESTABLISHED Remote 127.0.0.1:49923 (Querying... )
                        C:\Program Files\Speccy\Speccy64.exe (12920)
                        Local 192.168.1.140:61893 ESTABLISHED Remote 188.121.41.51:80 (Querying... ) (HTTP)
                        C:\Windows\System32\svchost.exe (21152)
                        Local 192.168.1.140:50448 ESTABLISHED Remote 74.125.68.108:993 (Querying... )
                        hasplms.exe (5784)
                        Local 0.0.0.0:1947 LISTEN
                        lsass.exe (960)
                        Local 0.0.0.0:49777 LISTEN
                        nvcontainer.exe (4512)
                        Local 127.0.0.1:65001 ESTABLISHED Remote 127.0.0.1:49844 (Querying... )
                        Local 127.0.0.1:49844 ESTABLISHED Remote 127.0.0.1:65001 (Querying... )
                        Local 127.0.0.1:65001 LISTEN
                        Local 127.0.0.1:65000 LISTEN
                        postgres.exe (6340)
                        Local 0.0.0.0:5432 LISTEN
                        remoting_host.exe (5944)
                        Local 192.168.1.140:49782 ESTABLISHED Remote 74.125.68.125:5222 (Querying... )
                        services.exe (952)
                        Local 0.0.0.0:49674 LISTEN
                        spoolsv.exe (3128)
                        Local 0.0.0.0:49667 LISTEN
                        svchost.exe (1088)
                        Local 0.0.0.0:135 (DCE) LISTEN
                        svchost.exe (1500)
                        Local 0.0.0.0:49665 LISTEN
                        svchost.exe (1900)
                        Local 0.0.0.0:49666 LISTEN
                        svchost.exe (4500)
                        Local 0.0.0.0:7680 LISTEN
                        svchost.exe (4852)
                        Local 192.168.1.140:49728 ESTABLISHED Remote 111.221.29.97:443 (Querying... ) (HTTPS)
                        System Process
                        Local 192.168.1.140:61684 TIME-WAIT Remote 216.58.203.131:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61660 TIME-WAIT Remote 151.101.8.207:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61804 TIME-WAIT Remote 151.101.40.134:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61661 TIME-WAIT Remote 151.101.8.207:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61803 TIME-WAIT Remote 151.101.40.134:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61795 TIME-WAIT Remote 151.101.40.134:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61662 TIME-WAIT Remote 117.18.237.29:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61674 TIME-WAIT Remote 151.101.8.64:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61664 TIME-WAIT Remote 66.235.138.211:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61665 TIME-WAIT Remote 66.235.138.211:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61874 TIME-WAIT Remote 151.101.0.134:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61666 TIME-WAIT Remote 66.235.138.211:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61822 TIME-WAIT Remote 120.138.127.81:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61807 TIME-WAIT Remote 151.101.40.134:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61678 TIME-WAIT Remote 202.134.152.202:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61679 TIME-WAIT Remote 202.134.152.202:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61680 TIME-WAIT Remote 202.134.152.202:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61681 TIME-WAIT Remote 104.122.122.131:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61682 TIME-WAIT Remote 104.122.122.131:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61683 TIME-WAIT Remote 104.122.122.131:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61806 TIME-WAIT Remote 216.58.203.129:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61685 TIME-WAIT Remote 216.58.203.131:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61686 TIME-WAIT Remote 216.58.203.131:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61687 TIME-WAIT Remote 198.232.125.83:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61688 TIME-WAIT Remote 198.232.125.83:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61689 TIME-WAIT Remote 198.232.125.83:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61690 TIME-WAIT Remote 198.232.125.83:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61691 TIME-WAIT Remote 198.232.125.83:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61692 TIME-WAIT Remote 198.232.125.83:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61861 TIME-WAIT Remote 104.244.42.8:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61693 TIME-WAIT Remote 216.58.203.136:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61706 TIME-WAIT Remote 216.58.203.138:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61694 TIME-WAIT Remote 216.58.203.136:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61695 TIME-WAIT Remote 216.58.203.136:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61792 TIME-WAIT Remote 199.96.57.6:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61787 TIME-WAIT Remote 34.202.239.120:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61781 TIME-WAIT Remote 216.58.203.130:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61775 TIME-WAIT Remote 108.161.189.5:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61768 TIME-WAIT Remote 31.13.78.17:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61762 TIME-WAIT Remote 91.228.166.11:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61753 TIME-WAIT Remote 74.125.68.95:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61658 TIME-WAIT Remote 54.255.223.63:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61752 TIME-WAIT Remote 74.125.68.95:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61713 TIME-WAIT Remote 216.58.203.131:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61731 TIME-WAIT Remote 74.125.68.154:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61730 TIME-WAIT Remote 74.125.68.154:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61724 TIME-WAIT Remote 108.177.97.103:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61884 TIME-WAIT Remote 54.250.233.211:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61883 TIME-WAIT Remote 74.125.200.93:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61881 TIME-WAIT Remote 151.101.24.134:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61875 TIME-WAIT Remote 151.101.0.134:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61870 TIME-WAIT Remote 104.16.80.166:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61869 TIME-WAIT Remote 104.16.80.166:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61868 TIME-WAIT Remote 104.16.80.166:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61859 TIME-WAIT Remote 185.33.223.202:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61856 TIME-WAIT Remote 172.217.24.35:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61851 TIME-WAIT Remote 216.58.220.162:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61846 TIME-WAIT Remote 104.244.43.209:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61843 TIME-WAIT Remote 54.206.87.167:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61839 TIME-WAIT Remote 161.170.238.122:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61836 TIME-WAIT Remote 103.243.221.87:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61631 TIME-WAIT Remote 52.193.182.88:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61635 TIME-WAIT Remote 66.235.138.211:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61636 TIME-WAIT Remote 66.235.138.211:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61637 TIME-WAIT Remote 66.235.138.211:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61833 TIME-WAIT Remote 52.11.253.14:80 (Querying... ) (HTTP)
                        Local 192.168.1.140:61650 TIME-WAIT Remote 66.235.159.165:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61654 TIME-WAIT Remote 192.229.232.199:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61655 TIME-WAIT Remote 104.16.21.35:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61656 TIME-WAIT Remote 54.255.223.63:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61657 TIME-WAIT Remote 54.255.223.63:443 (Querying... ) (HTTPS)
                        Local 192.168.1.140:61659 TIME-WAIT Remote 151.101.8.207:443 (Querying... ) (HTTPS)
                        System Process
                        Local 0.0.0.0:445 (Windows shares) LISTEN
                        Local 0.0.0.0:5357 LISTEN
                        Local 192.168.1.140:139 (NetBIOS session service) LISTEN
                        TeamViewer_Service.exe (4840)
                        Local 127.0.0.1:5939 LISTEN
                        wininit.exe (872)
                        Local 0.0.0.0:49664 LISTEN
                        xrdd.exe (4928)
                        Local 0.0.0.0:5454 LISTEN
                        Local 127.0.0.1:5454 ESTABLISHED Remote 127.0.0.1:49774 (Querying... )
                        Local 127.0.0.1:49668 ESTABLISHED Remote 127.0.0.1:49669 (Querying... )
                        Local 127.0.0.1:49669 ESTABLISHED Remote 127.0.0.1:49668 (Querying... )
                        Local 127.0.0.1:49774 ESTABLISHED Remote 127.0.0.1:5454 (Querying... )
                        Generated with Speccy v1.31.732
                        • 9. Re: Unusual response from tech team regarding 4k realtime playback
                          MyerPj Level 3
                          Hey PrashantMac, the 3rd test is in the same timeline as the 2nd, just move the playhead forward a few frames for the new instructions. You can use the default Adobe name for the project when it asks to convert, the exported file names will not change. Just make sure to delete any existing EXPORT files (only) before you run PPBM again, otherwise Adobe will rename the export files for you also.
                          • 10. Re: Unusual response from tech team regarding 4k realtime playback
                            Bill Gehrke Most Valuable Participant
                            The instructions on my web site are to SUBMIT the Speccy results, not to post them on the forum, I hope no one else ever tries this.  Also while the file above is very extensive it is also not complete.
                            I counted 134 processes running.  This is about twice as many as my well tuned dedicated video editing computer has.  It is no wonder that you cannot play a timeline with all those other processes stealing CPU cycles
                            You need to tune this computer
                            1. As a starting point turn off indexing on any drive involved with  Premiere Pro project files.
                            2. Disable every startup process the you can.
                            3. For more on tuning see Harm's tuning guide.  It is a little date but should give you other steps.
