i created a psd file with multiple layers. Each. Layer had a different color. This w as done wth CC6. When I open this file in the latest Photoshop version, I can no longer open the color options for the layer. However, I can access the blending options for that layer. Can someone explain what might be causing this problem? Many thanks.
I cannot reproduce this issue. I saved a Photoshop CS6 file with layers, opened it in Photoshop CC. The layers retained their colors and I am able to right click on a layer to change its color.
If the problem happens with more than one file, you may need to reset your preferences. Preferences in Photoshop and if that doesn't work you may need to use the CC Cleaner tool. Use the Creative Cloud Cleaner Tool to solve installation problems
It should work just fine.
Reset Photoshop
1. Go to PS General Preferences and click on the button: Reset Preferences on Quit
2. The new preferences files are created the next time you start the application.
