2 Replies Latest reply on Aug 10, 2017 5:35 PM by Scott Falkner
    Text keeps disappearing when it is moved around the page
    henryVI666
      I'm having a very frustrating problem where text inside my text boxes disappears or becomes overset text when I move them around on the page. Keep in mind that I'm not scaling the text boxes- I just move them up or down and they become overset. I'm also having a sister issue where the vertical margins on text boxes keep shifting when I move them to where I see double text. Regardless of the double text, the vertical margin keeps shifting when I move the text box. I believe that there must be something that I'm not accounting for on the page that is causing these things to shift. Screen Shot 2017-08-10 at 4.54.08 PM.png Screen Shot 2017-08-10 at 4.54.16 PM.png
        • 1. Re: Text keeps disappearing when it is moved around the page
          BobLevine MVP & Adobe Community Professional
          Do you have the text set to align to a baseline grid?
          • 2. Re: Text keeps disappearing when it is moved around the page
            Scott Falkner Level 5
            First check to see if the text frames are overlapping an object with text wrap applied. One easy way to test this is to turn on Ignore Text Wrap in the frame options dialogue. If this makes the problem go away then a text wrap was your culprit You can either accept that the problem is solved or explore further to see what objects have the text wrap and either remove it or ensure it is appropriate for your layout.
            I do not think this is the problem. I think your text is set to snap to a baseline grid. As the frame moves about the page the baseline grid is staying fixed to the page. This makes the first line of text always align to the next baseline grid it can find, which makes the first line shift up or down a bit relative to the frame. In some cases there is not enough rom for all the text.
            In the attached image, the text in the frame on the left is aligned to the baseline grid. Since the grid does not match the leading the grid defines the leading. This also makes the text start at the next grid line available, instead of at the top of the frame.
            Baseline grid can be turned on and off in the Control panel or the paragraph panel. It is a paragraph level text attribute, not an attribute of the text frame.
