• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
1
Batch Processing a Find Font in Document
Explorer ,
Aug 11, 2017 Aug 11, 2017
I am wanting to have a script that will look in a folder/directory and...
- Open each .pdf file in that directory one at a time and do the following
     - Find Font in Document
          - Arial
     - Replace With Font From System
          - Courier New
- Save the file with default Illustrator PDF save settings in same location (in other words I don't need it to be saved as another file)
I would love to do this with minimal or no interaction from the user.
Any ideas if this is possible? Keeping in mind that each file will have 1,000's of text frames with the Arial font that need to be changed to Courier New.
Any help would be greatly appreciated!
TOPICS
Scripting
Views
1.4K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
Community Expert ,
If you familiar to JavaScript, You can use ExtendScript do that.
Votes
Translate
Translate
Report
Report
Explorer ,
Aug 15, 2017 Aug 15, 2017
I am familiar with JavaScript and ExtendScript....but this is beyond my abilities.
Votes
Translate
Translate
Report
Report
Valorous Hero ,
I'm not sure how to do this in AI, because I don't think there's any way to replicate the function of the Find Font dialog. Going through all the 1000s of text frames to check each character's font family name would most certainly be too slow on even a single file.
How can one accomplish this?
Votes
Translate
Translate
Report
Report
Community Expert ,
I always use mm:font properties in XMP meta data.
You can reference below link to help reading metadata.
Extend_Script_experimentals/XMPtool.jsx at master · ten-A/Extend_Script_experimentals · GitHub
Votes
Translate
Translate
Report
Report
Community Expert ,
Are the PDF files created in Illustrator with “preserve Illustrator editing capabilities” checked when saving? If not, opening a generic PDF into Illustrator may be problematic (Illustrator is not a general purpose PDF editor).
Prepression: The Ten Commandments of PDF
I would recommend Enfocus PitStop Pro for Adobe Acrobat Pro or the stand alone hot folder based Enfocus PitStop Server for this task.
EDIT: Do you have some random sample files? Depending on how the text is composed, changing the font (in any software) could lead to unexpected results…
Votes
Translate
Translate
Report
Report
Explorer ,
Aug 25, 2017 Aug 25, 2017
LATEST
Here is the code I am working with.... can anyone offer any suggestions/help?
#target illustrator
var arialText = app.textFonts.getByName("ArialMT")
var arialBold = app.textFonts.getByName("Arial-BoldMT")
//Set up vairaibles
var sourceDoc, sourceFolder;
var count = 0;
// Select the source folder.
sourceFolder = Folder.selectDialog('Select the folder with Illustrator files...', '~');
destDoc = app.documents.add();
// If a valid folder is selected
if (sourceFolder != null) {
    files = new Array();
    // Get all files matching the pattern
    files = sourceFolder.getFiles();
    if (files.length > 0) {
        // Get the destination to save the files
        for (xx = 0; xx < files.length; xx++) {
sourceDoc = app.open(files[xx]); // returns the document object
            var allText = sourceDoc.textFrames; // Select All layers in Active Document
for (i = 0; i < allText.length; i++) {
var textFieldRange = allText.textRange;
var textProps = textFieldRange.characterAttributes;
var textFrameFont = textProps.textFont;
if (textFrameFont == "[TextFont ArialMT]" || textFrameFont == "[TextFont Arial-BoldMT]" || textFrameFont == "[TextFont Arial-BoldItalicMT]" || textFrameFont == "[TextFont Arial-ItalicMT]" || textFrameFont == "[TextFont ArialNarrow]" || textFrameFont == "[TextFont Arial-Black]"){
// font is correct
else if (textFrameFont == "[TextFont MonospaceBT]"){
// change the font to ArialMT which is Arial Regular
textFieldRange.characterAttributes.textFont = arialText;
count++
else{
// change the font to Arial Bold
textFieldRange.characterAttributes.textFont = arialBold;
count++;
sourceDoc.close(SaveOptions.SAVECHANGES);
// Alerts based on count
if (count == 0){
alert("YOU'RE GOOD TO GO!\nAll text in this document are a form of Arial!");
else {
alert("Complete!\n" + count + " textFrames were not a form of Arial.");
Votes
Translate
Translate
Report
Report
