• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Make/Release Clipping Mask via Script
Explorer ,
Aug 12, 2017 Aug 12, 2017
Hi, y'all
There is a way to reach the command "Make/Release Clipping Mask" in the Layer window via script?
What I'm trying to achieve is to create a rectangle using the size of my artboard, name it "CLIP", put it on the top of my active Layer and set it as my mask.
Example bellow:
Any help will be appreciated.
TOPICS
Scripting
Views
4.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Enthusiast , Aug 13, 2017 Aug 13, 2017
Hi, check this:
/* to make sure the desired layer(let's say layers[0]) been selected in the layers panel:
app.selection = null;
activeDocument.layers[0].hasSelectedArtwork = true;
var actionStr =
    /name [ 1    73]
    /actionCount 1
    /action-1 {
        /name [ 1    61]
        /eventCount 1
        /event-1 {
            /internalName (ai_plugin_Layer)
            /parameterCount 1
            /parameter-1 {
                /key 1836411236
                /type (integer)
                /value
Votes
Translate
Translate
Adobe
Enthusiast ,
Hi, check this:
var actionStr =
    /name [ 1    73]
    /actionCount 1
    /action-1 {
        /name [ 1    61]
        /eventCount 1
        /event-1 {
            /parameterCount 1
            /parameter-1 {
                /key 1836411236
                /type (integer)
                /value 18
createAction(actionStr, 's');
app.doScript('a', 's');
app.unloadAction('s', '');
function createAction(str, set) {
    var f = File(set + '.aia');
    f.open('w');
    f.write(str);
    f.close();
    app.loadAction(f);
    f.remove();
Votes
Translate
Translate
Report
Report
Explorer ,
thank you very much. that totally solves my problem. ❤️
Votes
Translate
Translate
Report
Report
Explorer ,
just one last question about it... how do you achieved the values in actions? there's a documentation of it? a way to "debug" the steps of actions? it would be very helpful on my learning curve.
Votes
Translate
Translate
Report
Report
Enthusiast ,
Aug 14, 2017 Aug 14, 2017
No documentation an all. Just record the action manually in UI, export the action set, open it with a text editor and you will get it.(Note that my sample code had simplified the contents of the action string, it's not necessary.)
Votes
Translate
Translate
Report
Report
Explorer ,
Great.
Your Script worked just fine in Illustrator running under Windows, but in Mac it didn't.
I will try to follow this steps in order to fix the problem on Mac.
Many thanks.
Votes
Translate
Translate
Report
Report
Explorer ,
Aug 15, 2017 Aug 15, 2017
Sorry for raising this question again, but I can't make it work on mac.
Here my code based on the mac action:
// cria retangulo do tamanho do artboard
var win = new Window ('dialog',"Clip Artboard");
win.alignChildren = 'left';
win.spacing = 2;
var chk = win.add('checkbox',undefined,"Clip content?");
var aviso = win.add('panel');
aviso.alignChildren = 'left';
aviso.add('statictext',undefined,"This will create a rectangle to clip");
aviso.add('statictext',undefined,"the content in this layer based in artboard.");
var btns = win.add('group');
btns.alignChildren = 'center';
btns.margins = [0,10,0,0];
var ok = btns.add('button',undefined,"OK");
var cancel = btns.add('button',undefined,"Cancel");
var actionStr =
    /name [ 1    73]
    /actionCount 1
    /action-1 {
        /name [ 1    61]
        /eventCount 1
        /event-1 {
            /parameterCount 1
            /parameter-1 {
                /key 1836411236
                /type (integer)
                /value 18
cancel.onClick = function(){
    win.close();
ok.onClick = function(){
    draw(0,"CLIP");
    if(chk.value == true){
     win.close();
win.show();
function draw(bleed,name){
// create rectangle
var docRef = app.activeDocument;
var artboardRef = docRef.artboards;
for(i=0;i<artboardRef.length;i++){
     var top=artboardRef.artboardRect[1];
     var left=artboardRef.artboardRect[0];
     var width=artboardRef.artboardRect[2]-artboardRef.artboardRect[0];
     var height=artboardRef.artboardRect[1]-artboardRef.artboardRect[3];
     var rect = docRef.pathItems.rectangle (top, left, width, height);
     rect.fillColor = rect.strokeColor = new NoColor();
     rect.name = name;
     docRef.activeLayer.clipping = true;
//create action to clip content
    f.open('w');
    f.write(str);
    f.close();
    app.loadAction(f);
    f.remove();
Votes
Translate
Translate
Report
Report
Enthusiast ,
So what's the error info?
Votes
Translate
Translate
Report
Report
Valorous Hero ,
I bet it's not letting him write the file! Let's see.
Votes
Translate
Translate
Report
Report
Explorer ,
I'm not in front of the mac right now, but the Error is something like "Wrong Version".
The script creates the rectangle named "CLIP", but it can't create the action that would clip the layer.
Silly-V : you suspect the problem could be about permissions?
Thanks in advance.
Votes
Translate
Translate
Report
Report
Valorous Hero ,
Oh , no I don't think that's the case - I just recorded my own action which does this and the very first line says "/version 3"
Maybe it's really necessary for Macs?
Votes
Translate
Translate
Report
Report
Explorer ,
Aug 16, 2017 Aug 16, 2017
Even beggining with "/version 3" on top of the script it didn't worked.
Votes
Translate
Translate
Report
Report
Valorous Hero ,
So what is the exact text of the .aia you export manually from the Actions panel, for study?
Votes
Translate
Translate
Report
Report
Explorer ,
/version 3
/name [ 4
    6d696e65
/isOpen 1
/actionCount 1
/action-1 {
    /name [ 4
        434c4950
    /keyIndex 0
    /colorIndex 0
    /isOpen 0
    /eventCount 1
    /event-1 {
        /useRulersIn1stQuadrant 0
        /localizedName [ 5
            4c61796572
        /isOpen 1
        /isOn 1
        /hasDialog 0
        /parameterCount 2
        /parameter-1 {
            /key 1836411236
            /showInPalette 4294967295
            /type (integer)
            /value 18
        /parameter-2 {
            /key 1851878757
            /type (ustring)
            /value [ 26
                4d616b652f52656c6561736520436c697070696e67204d61736b
Votes
Translate
Translate
Report
Report
Valorous Hero ,
Aug 30, 2017 Aug 30, 2017
LATEST
So when you save this file manually, then load it in later, it works? If it works with manual usage, the same should work through a script as well.
Votes
Translate
Translate
Report
Report
