1 Reply Latest reply on Aug 14, 2017 7:35 AM by Preran
    Dreamweaver crashes when opening a site
    jonbass
      Every time I change sites within dreamweaver 17.5 CC for Mac, the application crashes!
      I hope I can receive an answer so I can use my software!
      Thanks!
      Process:               Dreamweaver [946]
      Path:                  /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/MacOS/Dreamweaver
      Identifier:            com.adobe.dreamweaver-17.5
      Version:               17.5.0.9878 (17.5.0.9878)
      Code Type:             X86-64 (Native)
      Parent Process:        ??? [1]
      Responsible:           Dreamweaver [946]
      User ID:               501
      Date/Time:             2017-08-13 11:07:24.589 +1000
      OS Version:            Mac OS X 10.12.6 (16G29)
      Report Version:        12
      Anonymous UUID:        CEAE3CBF-2BBC-0883-7721-6B1D4D39FB98
      Time Awake Since Boot: 1500 seconds
      System Integrity Protection: enabled
      Crashed Thread:        0  CrBrowserMain  Dispatch queue: com.apple.main-thread
      Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
      Exception Codes:       EXC_I386_GPFLT
      Exception Note:        EXC_CORPSE_NOTIFY
      Termination Signal:    Segmentation fault: 11
      Termination Reason:    Namespace SIGNAL, Code 0xb
      Terminating Process:   exc handler [0]
      Thread 0 Crashed:: CrBrowserMain  Dispatch queue: com.apple.main-thread
      0   com.adobe.dvaui.framework     0x00000001087ec1eb dvaui::drawbot::OSSurfaceInterface::SurfaceImageData::~SurfaceImageData() + 43
      1   com.adobe.dvaui.framework     0x00000001087e0c70 dvaui::drawbot::OSSurfaceInterface::~OSSurfaceInterface() + 160
      2   com.adobe.dvaui.framework     0x00000001087e0e45 dvaui::drawbot::OSSurfaceInterface::~OSSurfaceInterface() + 21
      3   com.adobe.dvaui.framework     0x00000001085c6f95 dvaui::controls::UI_DisclosureTriangleButton::~UI_DisclosureTriangleButton() + 213
      4   com.adobe.dreamweaver-17.5     0x00000001050e9d35 DW_SftTree_UI_DisclosureTriangleButton::~DW_SftTree_UI_DisclosureTriangleButton() + 21
      5   com.adobe.dvaui.framework     0x000000010864ed92 std::__1::__tree<std::__1::__value_type<boost::intrusive_ptr<dvaui::controls::UI_MultiCol umnTreeRow>, boost::intrusive_ptr<dvaui::controls::UI_DisclosureTriangleButton> >, std::__1::__map_value_compare<boost::intrusive_ptr<dvaui::controls::UI_MultiColumnTreeRow >, std::__1::__value_type<boost::intrusive_ptr<dvaui::controls::UI_MultiColumnTreeRow>, boost::intrusive_ptr<dvaui::controls::UI_DisclosureTriangleButton> >, std::__1::less<boost::intrusive_ptr<dvaui::controls::UI_MultiColumnTreeRow> >, true>, std::__1::allocator<std::__1::__value_type<boost::intrusive_ptr<dvaui::controls::UI_Multi ColumnTreeRow>, boost::intrusive_ptr<dvaui::controls::UI_DisclosureTriangleButton> > > >::erase(std::__1::__tree_const_iterator<std::__1::__value_type<boost::intrusive_ptr<dvau i::controls::UI_MultiColumnTreeRow>, boost::intrusive_ptr<dvaui::controls::UI_DisclosureTriangleButton> >, std::__1::__tree_node<std::__1::__value_type<boost::intrusive_ptr<dvaui::controls::UI_Mul tiColumnTreeRow>, boost::intrusive_ptr<dvaui::controls::UI_DisclosureTriangleButton> >, void*>*, long>) + 114
      6   com.adobe.dvaui.framework     0x000000010862bc60 dvaui::controls::UI_MultiColumnTreeInnerView::RemoveAllSpinners(bool) + 544
      7   com.adobe.dvaui.framework     0x000000010862b61c dvaui::controls::UI_MultiColumnTree::RemoveAllRows(bool) + 300
      8   com.adobe.dreamweaver-17.5     0x0000000105104d28 CSftTreeImpl::ResetContent() + 24
      9   com.adobe.dreamweaver-17.5     0x000000010478fec0 CSiteFileView::ResetTree() + 16
      10  com.adobe.dreamweaver-17.5     0x00000001044ea51e CFileView::ResetTree() + 14
      11  com.adobe.dreamweaver-17.5     0x0000000104791f52 CSiteFileView::UpdateColumns(int) + 3042
      12  com.adobe.dreamweaver-17.5     0x0000000104b065e2 CSites::SetCurSiteIndex(int, bool&) + 1986
      13  com.adobe.dreamweaver-17.5     0x0000000104b031a5 CSites::SetCurSiteIndex(int) + 21
      14  com.adobe.dreamweaver-17.5     0x00000001045bdaa2 CSiteBar::OnSelectSite() + 1682
      15  com.adobe.dreamweaver-17.5     0x00000001045b9887 CSiteBar::OnSiteCloseUp() + 39
      16  com.adobe.dreamweaver-17.5     0x000000010504dbe2 CCmdTarget::OnCmdMsg(unsigned int, int, void*, AFX_CMDHANDLERINFO*) + 754
      17  com.adobe.dreamweaver-17.5     0x0000000105030b82 CView::OnCmdMsg(unsigned int, int, void*, AFX_CMDHANDLERINFO*) + 34
      18  com.adobe.dreamweaver-17.5     0x000000010502b355 CWnd::OnWndMsg(unsigned int, unsigned long long, long long, long long*) + 69
      19  com.adobe.dreamweaver-17.5     0x000000010502b2e0 CWnd::WindowProc(unsigned int, unsigned long long, long long) + 48
      20  com.adobe.dreamweaver-17.5     0x0000000105029417 CWnd::WinSendMessage(unsigned int, unsigned long long, long long) + 23
      21  com.adobe.dreamweaver-17.5     0x00000001050bfc63 CComboBoxImpl::UI_DoTimerNotify(int) + 67
      22  com.adobe.dvaui.framework     0x0000000108897fb4 dvaui::ui::UI_Node::UI_DispatchPossibleTimer(dvaui::ui::UI_NodeTimerData*) + 484
      23  com.adobe.dvaui.framework     0x0000000108917a73 dvaui::ui::OS_NodeTimerData::CallDispatchPossibleTimer(dvaui::ui::OS_NodeTimerData*, dvaui::ui::UI_NodeTimerData*) + 19
      24  com.adobe.dreamweaver-17.5     0x00000001050660f6 TestErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0<int>) + 38
      25  com.adobe.dvaui.framework     0x00000001089179dd dvaui::ui::OS_NodeTimerData::HandleOSTimerEvent() + 77
      26  com.adobe.dvacore.framework   0x0000000107f977fc int dvacore::config::ErrorManager::ExecuteFunction<void>(boost::function0<void>*, void*) + 28
      27  com.adobe.dreamweaver-17.5     0x00000001050660f6 TestErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0<int>) + 38
      28  com.adobe.dvacore.framework   0x0000000107f978b3 void dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<void>(boost::f unction0<void>, bool*) + 99
      29  com.adobe.dvacore.framework   0x0000000107f98510 void dvacore::config::ExecuteTopLevelFunction<void>(boost::function0<void>, bool*) + 160
      30  com.adobe.dvaui.framework     0x0000000108926231 -[DVAMacNodeTimer fire:] + 113
      31  com.apple.Foundation           0x00007fffcb52fe0f __NSFireTimer + 83
      32  com.apple.CoreFoundation       0x00007fffc9aa5c54 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
      33  com.apple.CoreFoundation       0x00007fffc9aa58df __CFRunLoopDoTimer + 1071
      34  com.apple.CoreFoundation       0x00007fffc9aa543a __CFRunLoopDoTimers + 298
      35  com.apple.CoreFoundation       0x00007fffc9a9cb81 __CFRunLoopRun + 2065
      36  com.apple.CoreFoundation       0x00007fffc9a9c114 CFRunLoopRunSpecific + 420
      37  com.apple.HIToolbox           0x00007fffc8ffcebc RunCurrentEventLoopInMode + 240
      38  com.apple.HIToolbox           0x00007fffc8ffcbf9 ReceiveNextEventCommon + 184
      39  com.apple.HIToolbox           0x00007fffc8ffcb26 _BlockUntilNextEventMatchingListInModeWithFilter + 71
      40  com.apple.AppKit               0x00007fffc7595a54 _DPSNextEvent + 1120
      41  com.apple.AppKit               0x00007fffc7d117ee -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796
      42  com.apple.AppKit               0x00007fffc758a3db -[NSApplication run] + 926
      43  com.adobe.exo.framework       0x00000001096608d8 exo::app::OS_AppBase::RunEventLoop() + 56
      44  com.adobe.dreamweaver-17.5     0x00000001050647e2 CRealApp::Run() + 610
      45  com.adobe.dreamweaver-17.5     0x0000000105032645 main + 261
      46  libdyld.dylib                 0x00007fffdf21c235 start + 1
      Thread 1:
      0   libsystem_kernel.dylib         0x00007fffdf34b44e __workq_kernreturn + 10
      1   libsystem_pthread.dylib       0x00007fffdf435621 _pthread_wqthread + 1426
      2   libsystem_pthread.dylib       0x00007fffdf43507d start_wqthread + 13
      Thread 2:
      Thread 3:
      1   libsystem_pthread.dylib       0x00007fffdf43548e _pthread_wqthread + 1023
      Thread 4:
      Thread 5:: NetworkConfigWatcher
      0   libsystem_kernel.dylib         0x00007fffdf34334a mach_msg_trap + 10
      1   libsystem_kernel.dylib         0x00007fffdf342797 mach_msg + 55
      2   com.apple.CoreFoundation       0x00007fffc9a9d434 __CFRunLoopServiceMachPort + 212
      3   com.apple.CoreFoundation       0x00007fffc9a9c8c1 __CFRunLoopRun + 1361
      4   com.apple.CoreFoundation       0x00007fffc9a9c114 CFRunLoopRunSpecific + 420
      5   com.apple.Foundation           0x00007fffcb4af252 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 277
      6   org.chromium.ContentShell.framework 0x0000000110ce75ae base::MessagePumpNSRunLoop::DoRun(base::MessagePump::Delegate*) + 126
      7   org.chromium.ContentShell.framework 0x0000000110ce6d84 base::MessagePumpCFRunLoopBase::Run(base::MessagePump::Delegate*) + 100
      8   org.chromium.ContentShell.framework 0x0000000110cfefc1 base::RunLoop::Run() + 113
      9   org.chromium.ContentShell.framework 0x0000000110d2214c base::Thread::ThreadMain() + 332
      10  org.chromium.ContentShell.framework 0x0000000110d1e117 base::(anonymous namespace)::ThreadFunc(void*) + 87
      11  libsystem_pthread.dylib       0x00007fffdf43593b _pthread_body + 180
      12  libsystem_pthread.dylib       0x00007fffdf435887 _pthread_start + 286
      13  libsystem_pthread.dylib       0x00007fffdf43508d thread_start + 13
      Thread 6:: DnsConfigService
      0   libsystem_kernel.dylib         0x00007fffdf34bd96 kevent + 10
      1   org.chromium.ContentShell.framework 0x0000000110d577a9 kq_dispatch + 89
      2   org.chromium.ContentShell.framework 0x0000000110d5528d event_base_loop + 701
      3   org.chromium.ContentShell.framework 0x0000000110ce647f base::MessagePumpLibevent::Run(base::MessagePump::Delegate*) + 463
      4   org.chromium.ContentShell.framework 0x0000000110cfefc1 base::RunLoop::Run() + 113
      5   org.chromium.ContentShell.framework 0x0000000110d2214c base::Thread::ThreadMain() + 332
      6   org.chromium.ContentShell.framework 0x0000000110d1e117 base::(anonymous namespace)::ThreadFunc(void*) + 87
      7   libsystem_pthread.dylib       0x00007fffdf43593b _pthread_body + 180
      8   libsystem_pthread.dylib       0x00007fffdf435887 _pthread_start + 286
      9   libsystem_pthread.dylib       0x00007fffdf43508d thread_start + 13
      Thread 7:: WorkerPool/34823
      0   libsystem_kernel.dylib         0x00007fffdf34abf2 __psynch_cvwait + 10
      1   libsystem_pthread.dylib       0x00007fffdf436833 _pthread_cond_wait + 769
      2   org.chromium.ContentShell.framework 0x0000000110d0f92b base::ConditionVariable::TimedWait(base::TimeDelta const&) + 91
      3   org.chromium.ContentShell.framework 0x0000000110d23dfa base::PosixDynamicThreadPool::WaitForTask() + 186
      4   org.chromium.ContentShell.framework 0x0000000110d24364 base::(anonymous namespace)::WorkerThread::ThreadMain() + 788
      5   org.chromium.ContentShell.framework 0x0000000110d1e117 base::(anonymous namespace)::ThreadFunc(void*) + 87
      6   libsystem_pthread.dylib       0x00007fffdf43593b _pthread_body + 180
      7   libsystem_pthread.dylib       0x00007fffdf435887 _pthread_start + 286
      8   libsystem_pthread.dylib       0x00007fffdf43508d thread_start + 13
      Thread 8:: WorkerPool/35075
      Thread 9:: Chrome_DBThread
      5   org.chromium.ContentShell.framework 0x0000000110ce730f base::MessagePumpCFRunLoop::DoRun(base::MessagePump::Delegate*) + 79
      6   org.chromium.ContentShell.framework 0x0000000110ce6d84 base::MessagePumpCFRunLoopBase::Run(base::MessagePump::Delegate*) + 100
      7   org.chromium.ContentShell.framework 0x0000000110cfefc1 base::RunLoop::Run() + 113
      8   org.chromium.ContentShell.framework 0x000000011008cb98 content::BrowserThreadImpl::DBThreadRun(base::RunLoop*) + 24
      9   org.chromium.ContentShell.framework 0x000000011008cf5f content::BrowserThreadImpl::Run(base::RunLoop*) + 223
      10  org.chromium.ContentShell.framework 0x0000000110d2214c base::Thread::ThreadMain() + 332
      11  org.chromium.ContentShell.framework 0x0000000110d1e117 base::(anonymous namespace)::ThreadFunc(void*) + 87
      12  libsystem_pthread.dylib       0x00007fffdf43593b _pthread_body + 180
      13  libsystem_pthread.dylib       0x00007fffdf435887 _pthread_start + 286
      14  libsystem_pthread.dylib       0x00007fffdf43508d thread_start + 13
      Thread 10:: Chrome_FileThread
      3   org.chromium.ContentShell.framework 0x0000000110ce6466 base::MessagePumpLibevent::Run(base::MessagePump::Delegate*) + 438
      5   org.chromium.ContentShell.framework 0x000000011008cc18 content::BrowserThreadImpl::FileThreadRun(base::RunLoop*) + 24
      6   org.chromium.ContentShell.framework 0x000000011008cf6f content::BrowserThreadImpl::Run(base::RunLoop*) + 239
      7   org.chromium.ContentShell.framework 0x0000000110d2214c base::Thread::ThreadMain() + 332
      8   org.chromium.ContentShell.framework 0x0000000110d1e117 base::(anonymous namespace)::ThreadFunc(void*) + 87
      9   libsystem_pthread.dylib       0x00007fffdf43593b _pthread_body + 180
      10  libsystem_pthread.dylib       0x00007fffdf435887 _pthread_start + 286
      11  libsystem_pthread.dylib       0x00007fffdf43508d thread_start + 13
      Thread 11:: Chrome_FileUserBlockingThread
      8   org.chromium.ContentShell.framework 0x000000011008cc98 content::BrowserThreadImpl::FileUserBlockingThreadRun(base::RunLoop*) + 24
      9   org.chromium.ContentShell.framework 0x000000011008cf7f content::BrowserThreadImpl::Run(base::RunLoop*) + 255
      Thread 12:: Chrome_ProcessLauncherThread
      8   org.chromium.ContentShell.framework 0x000000011008cd18 content::BrowserThreadImpl::ProcessLauncherThreadRun(base::RunLoop*) + 24
      9   org.chromium.ContentShell.framework 0x000000011008cf8c content::BrowserThreadImpl::Run(base::RunLoop*) + 268
      Thread 13:: Chrome_CacheThread
      8   org.chromium.ContentShell.framework 0x000000011008cd98 content::BrowserThreadImpl::CacheThreadRun(base::RunLoop*) + 24
      9   org.chromium.ContentShell.framework 0x000000011008cf99 content::BrowserThreadImpl::Run(base::RunLoop*) + 281
      Thread 14:: Chrome_IOThread
      5   org.chromium.ContentShell.framework 0x000000011008ce18 content::BrowserThreadImpl::IOThreadRun(base::RunLoop*) + 24
      6   org.chromium.ContentShell.framework 0x000000011008cfa6 content::BrowserThreadImpl::Run(base::RunLoop*) + 294
      Thread 15:: IndexedDB
      8   org.chromium.ContentShell.framework 0x0000000110d2214c base::Thread::ThreadMain() + 332
      9   org.chromium.ContentShell.framework 0x0000000110d1e117 base::(anonymous namespace)::ThreadFunc(void*) + 87
      10  libsystem_pthread.dylib       0x00007fffdf43593b _pthread_body + 180
      11  libsystem_pthread.dylib       0x00007fffdf435887 _pthread_start + 286
      12  libsystem_pthread.dylib       0x00007fffdf43508d thread_start + 13
      Thread 16:: CompositorTileWorker1/47363
      1   libsystem_pthread.dylib       0x00007fffdf4367fa _pthread_cond_wait + 712
      2   org.chromium.ContentShell.framework 0x0000000110dd9968 non-virtual thunk to cc::SingleThreadTaskGraphRunner::Run() + 56
      3   org.chromium.ContentShell.framework 0x0000000110d2160d base::SimpleThread::ThreadMain() + 125
      4   org.chromium.ContentShell.framework 0x0000000110d1e117 base::(anonymous namespace)::ThreadFunc(void*) + 87
      5   libsystem_pthread.dylib       0x00007fffdf43593b _pthread_body + 180
      6   libsystem_pthread.dylib       0x00007fffdf435887 _pthread_start + 286
      7   libsystem_pthread.dylib       0x00007fffdf43508d thread_start + 13
      Thread 17:: AudioThread
      Thread 18:: BrowserBlockingWorker1/51971
      2   org.chromium.ContentShell.framework 0x0000000110d1eef1 base::SequencedWorkerPool::Inner::ThreadLoop(base::SequencedWorkerPool::Worker*) + 2225
      3   org.chromium.ContentShell.framework 0x0000000110d1e5fd base::SequencedWorkerPool::Worker::Run() + 125
      4   org.chromium.ContentShell.framework 0x0000000110d2160d base::SimpleThread::ThreadMain() + 125
      Thread 19:: NetworkConfigWatcher
      Thread 20:
      2   com.adobe.boost_threads.framework 0x00000001074c6f89 boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 73
      3   com.adobe.boost_threads.framework 0x00000001074c574e boost::this_thread::hiden::sleep_until(timespec const&) + 78
      4   com.adobe.dreamweaver-17.5     0x0000000104023fa6 JSInterp::testForINET() + 326
      5   com.adobe.dvacore.framework   0x0000000108071a7a dvacore::threads::(anonymous namespace)::LaunchThread(std::__1::basic_string<char, std::__1::char_traits<char>, std::__1::allocator<char> > const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 362
      6   com.adobe.boost_threads.framework 0x00000001074c4725 boost::(anonymous namespace)::thread_proxy(void*) + 165
      Thread 21:
      2   com.adobe.dreamweaver-17.5     0x0000000103c3c1cb boost::condition_variable::wait(boost::unique_lock<boost::mutex>&) + 59
      3   com.adobe.dreamweaver-17.5     0x0000000104cc2eff CAutoSaveManager::WinThreadStartupCallback() + 79
      4   com.adobe.boost_threads.framework 0x00000001074c4725 boost::(anonymous namespace)::thread_proxy(void*) + 165
      Thread 22:: VulcanMsgRecv
      0   libsystem_kernel.dylib         0x00007fffdf34adf6 __recvfrom + 10
      1   VulcanMessage5.dylib           0x000000010a37c308 vcfoundation::net::Bsd::Recv(int, void*, int, int) + 16
      2   VulcanMessage5.dylib           0x000000010a37b6cc vcfoundation::io::BSDNamedPipe::Read(void*, unsigned long) + 20
      3   VulcanMessage5.dylib           0x000000010a37a9c4 vcfoundation::io::BufferedReader::InternalRead(char*, long) + 100
      4   VulcanMessage5.dylib           0x000000010a37a888 vcfoundation::io::BufferedReader::Read(void*, unsigned long) + 50
      5   VulcanMessage5.dylib           0x000000010a3754c7 vcfoundation::io::IVCChannel::ReadFully(void*, unsigned long) + 57
      6   VulcanMessage5.dylib           0x000000010a375f56 vcfoundation::io::Serializer::InternalDeserialize() + 30
      7   VulcanMessage5.dylib           0x000000010a3758ef vcfoundation::io::Serializer::Deserialize() + 9
      8   VulcanMessage5.dylib           0x000000010a379974 vcfoundation::ncomm::Connection::ReadIn() + 22
      9   VulcanMessage5.dylib           0x000000010a3793cd vcfoundation::ncomm::NCService::ReadResponse(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&, vcfoundation::ncomm::NCService::ConRef&) + 41
      10  VulcanMessage5.dylib           0x000000010a3790ba vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*, vcfoundation::ncomm::INCListener&) + 166
      11  VulcanMessage5.dylib           0x000000010a37900d vcfoundation::ncomm::NCService::Execute(vcfoundation::ncomm::INCRequest*) + 29
      12  VulcanMessage5.dylib           0x000000010a36c848 adobe::vulcan::servicemgr::CSIRequest::Execute() + 50
      13  VulcanMessage5.dylib           0x000000010a36ba86 adobe::vulcan::servicemgr::RegisterForEventsRequest::Run() + 622
      14  VulcanMessage5.dylib           0x000000010a37a20c vcfoundation::thread::AbstractThread::Run() + 72
      15  VulcanMessage5.dylib           0x000000010a37c109 vcfoundation::thread::Thread::ThreadProc(void*) + 9
      16  libsystem_pthread.dylib       0x00007fffdf43593b _pthread_body + 180
      17  libsystem_pthread.dylib       0x00007fffdf435887 _pthread_start + 286
      18  libsystem_pthread.dylib       0x00007fffdf43508d thread_start + 13
      Thread 23:: com.apple.NSURLConnectionLoader
      5   com.apple.CFNetwork           0x00007fffc8bd9734 +[NSURLConnection(Loader) _resourceLoadLoop:] + 313
      6   com.apple.Foundation           0x00007fffcb4bf8ad __NSThread__start__ + 1243
      Thread 24:: com.apple.CFSocket.private
      0   libsystem_kernel.dylib         0x00007fffdf34aeb6 __select + 10
      1   com.apple.CoreFoundation       0x00007fffc9ad866a __CFSocketManager + 682
      Thread 25:
      5   com.apple.Foundation           0x00007fffcb5c2eed -[NSConnection run] + 144
      Thread 26:: CEPMonitorThread
      5   com.apple.Foundation           0x00007fffcb555051 -[NSConcreteTask waitUntilExit] + 213
      6   com.adobe.PlugPlugOwl         0x000000010bc57c4b -[HtmlEngineMonitor monitorThreadProc] + 160
      7   com.apple.Foundation           0x00007fffcb4bf8ad __NSThread__start__ + 1243
      8   libsystem_pthread.dylib       0x00007fffdf43593b _pthread_body + 180
      9   libsystem_pthread.dylib       0x00007fffdf435887 _pthread_start + 286
      10  libsystem_pthread.dylib       0x00007fffdf43508d thread_start + 13
      Thread 27:
      1   com.adobe.dreamweaver-17.5     0x0000000104f440ec boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue<boost::asio::detail::task_io_service_operation>&) + 268
      2   com.adobe.dreamweaver-17.5     0x0000000104f43d4c boost::asio::detail::task_io_service::do_run_one(boost::asio::detail::scoped_lock<boost:: asio::detail::posix_mutex>&, boost::asio::detail::task_io_service_thread_info&, boost::system::error_code const&) + 380
      3   com.adobe.dreamweaver-17.5     0x0000000104f43995 boost::asio::detail::task_io_service::run(boost::system::error_code&) + 181
      4   com.adobe.dreamweaver-17.5     0x0000000104f3f28e node::toolbox::NodeSocketConnectionServer::HandleConnectionOnThread() + 222
      5   com.adobe.boost_threads.framework 0x00000001074c4725 boost::(anonymous namespace)::thread_proxy(void*) + 165
      Thread 28:
      2   com.adobe.headlights.LogSessionFramework 0x000000010ae3b2dc boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
      3   com.adobe.headlights.LogSessionFramework 0x000000010ae39b9e boost::this_thread::hiden::sleep_until(timespec const&) + 78
      4   com.adobe.headlights.LogSessionFramework 0x000000010ade2911 RealTimeProcessor::Sleep(int) + 243
      5   com.adobe.headlights.LogSessionFramework 0x000000010ade0e72 RealTimeProcessor::WorkerThread() + 2370
      6   com.adobe.headlights.LogSessionFramework 0x000000010ae38bfa boost::(anonymous namespace)::thread_proxy(void*) + 138
      Thread 29:: com.apple.NSEventThread
      5   com.apple.AppKit               0x00007fffc76e2f02 _NSEventThread + 205
      Thread 30:
      0   libsystem_pthread.dylib       0x00007fffdf435070 start_wqthread + 0
      Thread 31:: BrowserBlockingWorker2/100103
      Thread 32:: BrowserBlockingWorker3/100611
      Thread 33:
      2   com.adobe.SynKitLib           0x000000010a5d6969 boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 73
      3   com.adobe.SynKitLib           0x000000010a5d510f boost::this_thread::hiden::sleep_for(timespec const&) + 191
      4   com.adobe.SynKitLib           0x000000010a589343 void boost::this_thread::sleep_for<long long, boost::ratio<1l, 1l> >(boost::chrono::duration<long long, boost::ratio<1l, 1l> > const&) + 107
      5   com.adobe.SynKitLib           0x000000010a582df5 adobe_synkit::SynKit_Manager::KeepAliveImpl(void*) + 163
      6   com.adobe.SynKitLib           0x000000010a5d41da boost::(anonymous namespace)::thread_proxy(void*) + 186
      Thread 34:: CachePoolWorker1/107023
      Thread 35:
      0   libChar16.dylib               0x000000010abfeef7 char16_wmemchr + 23
      1   com.apple.carbonbundletemplate 0x000000014e1418f9 CMacrUnicodeConverter::ConvertScriptTextToUTF16(unsigned int, char const*, unsigned int, char16_t*, unsigned int, int&) + 1113
      2   com.apple.carbonbundletemplate 0x000000014e141491 CMacrUnicodeConverter::ConvertScriptTextToUTF16(unsigned int, char const*, unsigned int, char16_t*, unsigned int) + 17
      3   com.apple.carbonbundletemplate 0x000000014e077f72 PHP_KE::ConvertUTF8ToUTF16(char const*, int) + 98
      4   com.apple.carbonbundletemplate 0x000000014e080bf4 convert_stmt(_zend_ast*) + 20036
      5   com.apple.carbonbundletemplate 0x000000014e079c20 convert_list(_zend_ast*) + 4384
      6   com.apple.carbonbundletemplate 0x000000014e078bf1 convert_list(_zend_ast*) + 241
      7   com.apple.carbonbundletemplate 0x000000014e0895b6 convert_stmt(_zend_ast*) + 55302
      8   com.apple.carbonbundletemplate 0x000000014e079c20 convert_list(_zend_ast*) + 4384
      9   com.apple.carbonbundletemplate 0x000000014e07882c convert_top_stmt(_zend_ast*, boost::shared_ptr<PHP_KE::ASTNode>) + 828
      10  com.apple.carbonbundletemplate 0x000000014e0a689a convert_AST + 138
      11  com.apple.carbonbundletemplate 0x000000014e1707b0 zend_compile + 320
      12  com.apple.carbonbundletemplate 0x000000014e170610 compile_file + 304
      13  com.apple.carbonbundletemplate 0x000000014e052e05 zend_execute_scripts + 261
      14  com.apple.carbonbundletemplate 0x000000014e0a6c80 ParsePHP + 528
      15  com.apple.carbonbundletemplate 0x000000014df59dff CodeHints::PHP_LangParser::Parse() + 367
      16  com.adobe.dreamweaver-17.5     0x0000000104a04d6f CodeHints::LanguageCodeViewParserJob::Execute() + 255
      17  com.adobe.dreamweaver-17.5     0x0000000104a04855 CodeHints::LanguageCodeViewParserJob::tramp(void*) + 293
      18  libsystem_pthread.dylib       0x00007fffdf43593b _pthread_body + 180
      19  libsystem_pthread.dylib       0x00007fffdf435887 _pthread_start + 286
      20  libsystem_pthread.dylib       0x00007fffdf43508d thread_start + 13
      Thread 36:
      0   libsystem_kernel.dylib         0x00007fffdf34ac22 __psynch_mutexwait + 10
      1   libsystem_pthread.dylib       0x00007fffdf435dfa _pthread_mutex_lock_wait + 100
      2   com.adobe.dreamweaver-17.5     0x0000000103c3bfc2 boost::unique_lock<boost::mutex>::lock() + 50
      3   com.adobe.dreamweaver-17.5     0x0000000104a04d5f CodeHints::LanguageCodeViewParserJob::Execute() + 239
      4   com.adobe.dreamweaver-17.5     0x0000000104a04855 CodeHints::LanguageCodeViewParserJob::tramp(void*) + 293
      Thread 37:
      Thread 38:
      Thread 39:
      Thread 0 crashed with X86 Thread State (64-bit):
        rax: 0x0000610000830180  rbx: 0x0000610000850f20  rcx: 0x0063002e0073006f  rdx: 0x0000000000071954
        rdi: 0x0063612e00f601ef  rsi: 0x0000000000000008  rbp: 0x00007fff5c321910  rsp: 0x00007fff5c321900
         r8: 0x00007fffe4b10700   r9: 0x0000610000373980  r10: 0x00007fffe4b10708  r11: 0xffffffff00000000
        r12: 0x00007fe1f195fc00  r13: 0x00007fe1f1960190  r14: 0x0000000108c9a1d0  r15: 0x00007fe1f195fc10
        rip: 0x00000001087ec1eb  rfl: 0x0000000000010202  cr2: 0x0000610000c6cfc8
      Logical CPU:     1
      Error Code:      0x00000000
      Trap Number:     13
      Binary Images:
             0x1038db000 -        0x105720ff7 +com.adobe.dreamweaver-17.5 (17.5.0.9878 - 17.5.0.9878) <AE2FF76F-36AA-31A0-AC0F-CAB310784A07> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/MacOS/Dreamweaver
             0x10739e000 -        0x1073a2fff +libdwlog.dylib (0) <14FFC1E4-12C0-34AA-8B0E-6251F4E9E58B> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/MacOS/libdwlog.dylib
             0x1073b6000 -        0x107448ff7 +com.adobe.boost_regex.framework (11.0.0 - 11.0.0.0) <A9C0F91C-67EC-3882-9E51-7125EADEE3FA> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
             0x1074c3000 -        0x1074d0fff +com.adobe.boost_threads.framework (11.0.0 - 11.0.0.0) <AFF71B07-9D59-3170-BAA4-0BF990EEEE59> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
             0x1074f1000 -        0x1074fdff7 +com.adobe.boost_signals.framework (11.0.0 - 11.0.0.0) <5531D1BD-A2C4-3A58-87D5-8AF6E7DEDA72> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
             0x107515000 -        0x107519fff +com.adobe.boost_date_time.framework (11.0.0 - 11.0.0.0) <21159CD0-0F5C-321C-8FDD-CC335EEB9175> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
             0x10752b000 -        0x10752cffb +com.adobe.boost_system.framework (11.0.0 - 11.0.0.0) <0757ABD6-9A9A-3C8A-A95F-2F3A4FF1CDC3> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
             0x107539000 -        0x107884ff7 +com.adobe.dvaadameve.framework (11.0.0 - 11.0.0.0) <613CC2FE-4761-36A9-98D5-03A4088B436E> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
             0x107f39000 -        0x107f46ff7 +com.adobe.boost_filesystem.framework (11.0.0 - 11.0.0.0) <35FBA259-3FB4-37E6-B2D3-BA589352C780> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
             0x107f5e000 -        0x108263ff7 +com.adobe.dvacore.framework (11.0.0 - 11.0.0.0) <E8E1583E-16FD-38CC-BBBE-D1F1BD9FAE36> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
             0x10850f000 -        0x108b83ff7 +com.adobe.dvaui.framework (11.0.0 - 11.0.0.0) <5638EAD8-2B51-3681-AE71-0B25920F8E97> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
             0x109658000 -        0x10970cfff +com.adobe.exo.framework (11.0.0 - 11.0.0.0) <9CB7CB64-B223-3C5C-B832-6241DB4D6B5F> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/exo.framework/Versions/A/exo
             0x1098ab000 -        0x1099e3fff +com.adobe.dvaworkspace.framework (11.0.0 - 11.0.0.0) <400E7E44-34A9-314F-8BBD-F9EAA173F29E> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
             0x109c50000 -        0x109dd8ff3 +com.adobe.owl (AdobeOwl version 5.2.9 - 5.2.9) <F315097F-C605-3FBF-BDFA-79B3376A9F00> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
             0x109e25000 -        0x10a0acfff +libxerces-c-3.1.dylib (0) <C87CACB0-9183-3B3F-9E89-02A695A474E7> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/MacOS/libxerces-c-3.1.dylib
             0x10a253000 -        0x10a34dfff +com.adobe.adobe_caps (adobe_caps 10.0.0.5 - 10.0.0.5) <E029224F-4AD9-3054-87A7-AB5FAAD7CD1F> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
             0x10a35e000 -        0x10a399ff7 +VulcanMessage5.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <4B054DF8-614C-39A7-AC19-CBBA847B9014> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/VulcanMessage5.dylib
             0x10a3e2000 -        0x10a406fff +VulcanControl.dylib (5.3.0.16 - 5.3.0.16 Copyright 2016, Adobe Systems Incorporated. All rights reserved.) <32AA6861-E0A7-37F8-8CE9-FCE97E3BFD07> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/VulcanControl.dylib
             0x10a432000 -        0x10a461fff +SynKitInterface.dylib (0) <E5FAE0B1-C8D4-3643-BCC6-8231EFE8613A> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/MacOS/SynKitInterface.dylib
             0x10a4b1000 -        0x10a618fff +com.adobe.SynKitLib (1.0.0.581 - 1.0.0.581) <228E1E2E-4C2F-3DB0-88AF-4426A5249C6E> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/SynKitLib.framework/Versions/A/SynKitLib
             0x10a750000 -        0x10a794ff7 +libssl.1.0.0.dylib (0) <BAC1D0B4-B520-32DB-9BC5-9D451567A48D> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/MacOS/libssl.1.0.0.dylib
             0x10a7b3000 -        0x10a93678f +libcrypto.1.0.0.dylib (0) <200FEB83-AB5C-392D-B056-A86DA24593C3> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/MacOS/libcrypto.1.0.0.dylib
             0x10a9b0000 -        0x10a9e5fff +AgoraLib.dylib (1.0.0.0) <57963005-8C78-3570-BD1D-DD790A334E2D> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/AgoraLib.dylib
             0x10aa88000 -        0x10ab53ff7 +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.37744 - 3.8.0.37744) <C5D28001-9CBC-374F-AF58-B0BC979D16C6> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
             0x10abf8000 -        0x10ac14fff +libChar16.dylib (0) <C48E2734-238C-377A-9AC8-7F83DBA9C48E> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/MacOS/libChar16.dylib
             0x10ac2e000 -        0x10ac5bff7 +libCoreTypes.dylib (0) <C4C8D1D8-0E73-38E5-812F-B16D9655B7B3> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/MacOS/libCoreTypes.dylib
             0x10ac7f000 -        0x10acd0ff3 +libCurl.dylib (0) <3E8A9F2B-2AA2-3910-A184-2BF2620A71BE> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/MacOS/libCurl.dylib
             0x10acf3000 -        0x10acf7ffb +libCocoa.dylib (0) <9CA3837D-05FC-39A9-ADE5-64DCB41DC2E1> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/MacOS/libCocoa.dylib
             0x10ad02000 -        0x10ad0bff7  com.apple.carbonframeworktemplate (1.0 - 1.0) <C90E7843-03CD-3B0F-B525-ED1E663C31DC> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/NetIO.framework/Versions/A/NetIO
             0x10ad1c000 -        0x10ad3afff +com.adobe.ahclientframework (2.2.0.1 - 2.2.0.1) <78C9396E-DBAE-3C68-9B67-95B28F2BEC76> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
             0x10ad4d000 -        0x10ad50fff +com.adobe.AdobeCrashReporter (7.1 - 7.1.4) <A33546D9-3E26-38A2-88FE-C7C46B4CD989> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
             0x10ad57000 -        0x10ae93fff +com.adobe.headlights.LogSessionFramework (7.3.1.61) <D633CDB7-C235-328A-98E5-11FE46B3D179> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
             0x10af45000 -        0x10b048fff +com.adobe.amtlib (10.0.0.47 - 10.0.0.47) <AD7B1E56-04A5-355A-AD70-DA2464879FC3> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
             0x10b05c000 -        0x10b075ffb  libexpat.1.dylib (15) <F48F1B7B-BEB4-32EE-8C5D-0370096F3864> /usr/lib/libexpat.1.dylib
             0x10b07f000 -        0x10b0ebff3 +com.adobe.linguistic.LinguisticManager (10.1.0 - 22175) <297EFB0E-1933-355E-AE28-94DDCAE8A327> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
             0x10b164000 -        0x10b7ceff7 +com.adobe.dw.imageoptimization.engine (Dreamweaver Image Optimization CS6 Library version "12.0.0.043" - "12.0.0.043") <DA798E40-E7F1-3C29-9924-F6804038625A> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/ImageOptimization.framework/Versions/A/ImageOptimization
             0x10bb5f000 -        0x10bba2ff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 10.0.0.1 - 10.0.0.1) <624E6E8F-ACC9-3802-83A3-51970E64F769> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotificatio ns
             0x10bbbe000 -        0x10be34ff3 +com.adobe.PlugPlugOwl (7.0.0.67 - 7.0.0.67) <255982DC-96E4-3C40-AF5A-B46F23B5D372> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/PlugPlugOwl.framework/Versions/A/PlugPlugOwl
             0x10c103000 -        0x10c24fff7 +com.adobe.ACE (AdobeACE 2.20.02.37848 - 2.20.02.37848) <2AEECE94-07F6-3B31-A3B8-E33EC22ACB62> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
             0x10c266000 -        0x10c287ff7 +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.37744 - 3.8.0.37744) <FB677BF8-301F-342B-BAB5-B9282C4FDB7F> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExp at
             0x10c2ab000 -        0x10c7bdff3 +com.adobe.AGM (AdobeAGM 4.30.87.37848 - 4.30.87.37848) <FF2BA7F0-2253-33BD-9310-F9CB48E4D3A3> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
             0x10c85f000 -        0x10c878ff3 +com.adobe.BIB (AdobeBIB 1.2.03.37848 - 1.2.03.37848) <468E9459-7231-37B6-8587-7EBD3A7909C8> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
             0x10c881000 -        0x10c8a4ffb +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <6FDFDB79-CE33-30EE-8056-D76B4D52B6EF> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
             0x10c8ad000 -        0x10cba1ffb +com.adobe.CoolType (AdobeCoolType 5.15.00.37848 - 5.15.00.37848) <8E5432D6-36B6-3242-B020-6DBF54CFF3FD> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
             0x10cbed000 -        0x10ccadff7 +com.adobe.JP2K (1.2.2 - 1.2.2.37797) <5CFB76F4-2E9A-31E2-A544-5B80774DA89A> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
             0x10ccf3000 -        0x10ce06ff7 +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 140 - 79.160172) <A1D8AA57-79A7-387A-8897-55C5EBF0AE9C> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
             0x10cf5d000 -        0x10d087ff7 +com.winsoft.wrservices (WRServices 12.1.0 - 12.1.0) <75B95734-75E4-3E7E-B8E3-DB51C053E4DC> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
             0x10d0da000 -        0x10d252fff +com.adobe.ICUData (4.0 - 3.61) <E9E96DC5-1148-3BB8-9C14-8F9B7FFD032B> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
             0x10d258000 -        0x10d2faff7 +com.adobe.ICUConverter (4.0 - 3.61) <4D6A813A-56D5-3CE1-8743-2BA65500FD20> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
             0x10d323000 -        0x10d43dff7 +com.adobe.ICUInternationalization (4.0 - 3.61) <36984DC1-7D78-3AB5-9891-CA6ACD116AEE> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/ICUInternationalization.framework/Versions/4.0/ICUInternatio nalization
             0x10d4c5000 -        0x10d5b6ff7 +com.adobe.ICUUnicode (4.0 - 3.61) <431F0368-6F63-3B0D-A215-D6866EEACA9A> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
             0x10d601000 -        0x10d61bff7 +com.adobe.dvaunittesting.framework (11.0.0 - 11.0.0.0) <6CE3AFE4-76E3-3736-A8F1-0D9F77104135> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
             0x10d650000 -        0x10d70dff7 +com.adobe.dvanet.framework (11.0.0 - 11.0.0.0) <1C849D2F-E4D8-37A1-83CF-7654802A9798> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/dvanet.framework/Versions/A/dvanet
             0x10d81b000 -        0x10d859ff7  com.apple.audio.midi.CoreMIDI (1.10 - 88) <5E2D1F53-B466-312E-AEA7-117B68C9A7F0> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
             0x10d881000 -        0x10d888fff +com.macromedia.testframework (1.0 - 1.0) <8A060B0A-3839-3CC6-A28E-DD188784FF4C> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/uwchar.framework/Versions/A/uwchar
             0x10d88e000 -        0x10d8c5fef +libtbb.dylib (0) <3441EB5B-2632-3B4C-B76C-9AE5849E7353> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/libtbb.dylib
             0x10d906000 -        0x10d929fe7 +libtbbmalloc.dylib (0) <81117D6A-D8E4-37C2-9766-0DC0BF86C06C> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/libtbbmalloc.dylib
             0x10daf3000 -        0x10daf5ffb  com.apple.textencoding.unicode (3.0 - 3.0) <450E3370-B9E4-3179-89E5-98858FD25F23> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
             0x10f617000 -        0x10f654dc7  dyld (433.5) <322C06B7-8878-311D-888C-C8FD2CA96FF3> /usr/lib/dyld
             0x10f6a2000 -        0x115e26ff7 +org.chromium.ContentShell.framework (31.0.1650.57 - 1650.57) <FBC0A1C1-A7AE-3E7C-A68F-E221117F79FE> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/Chromium Embedded Framework.framework/Chromium Embedded Framework
             0x11ca07000 -        0x1200b7f7f +com.adobe.psl (AdobePSL 15.1.0.37776 - 15.1.0.37776) <A0E737E5-E9BC-31D1-9CDA-A4EB1032519C> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
             0x14d98d000 -        0x14d9b7fff  GLRendererFloat (14.0.16) <6B57F70A-EFAC-3DB2-B9BA-E55D05D44DB5> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
             0x14dc6e000 -        0x14dc93fff  com.apple.carbonbundletemplate (3.0.2,9878 - 3.0.2) <0A4C43EE-DC3D-396B-ADED-60995A282938> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Bundles/JSExtensions/MMNotes.bundle/Contents/MacOS/MMNotes
             0x14dd85000 -        0x14dd88ff7  com.apple.carbonbundletemplate (17,5,0, 9878 - 17,5,0) <1543DB86-483F-3CF0-B7B4-66D301E809EC> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Bundles/JSExtensions/MM.bundle/Contents/MacOS/MM
             0x14ddf8000 -        0x14ddfafff  com.apple.carbonbundletemplate (17,5,0, 9878 - 17,5,0) <9B144D5E-92AE-3FDD-AE78-FAA28CCE0BA5> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Bundles/JSExtensions/DWfile.bundle/Contents/MacOS/DWfile
             0x14de00000 -        0x14dec5ffb  com.apple.carbonbundletemplate (1.0 - 1.0) <3747F859-9C63-3485-A839-0A350381C043> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Bundles/KnowledgeEngines/JS_KnowledgeEngine.bundle/Contents/MacOS/JS_Kn owledgeEngine
             0x14df15000 -        0x14e009ff7  com.apple.carbonbundletemplate (1.0 - 1.0) <7D8D1B93-85B2-35FA-BDFC-4D017ED0D30A> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Bundles/KnowledgeEngines/PHP_KE.bundle/Contents/MacOS/PHP_KE
             0x14e04e000 -        0x14e1b3ffb  com.apple.carbonbundletemplate (1.0 - 1.0) <5D38AF52-1786-3E48-A54D-74ABE0E3ADE4> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Bundles/KnowledgeEngines/Zend/Zend7.bundle/Contents/MacOS/Zend7
             0x14e326000 -        0x14e358ff7  com.apple.carbonbundletemplate (1.0 - 1.0) <AA4BE98F-5560-3948-B630-6AEC32E12F62> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/PlugIns/NetIOFTP.bundle/Contents/MacOS/NetIOFTP
             0x14e7a1000 -        0x14e8ecfef +IMSLib.dylib (10.0.0.19 - 10.0.0.19) <32EDDC00-4237-3F41-8B49-8B8010FAA72B> /Library/Application Support/Adobe/*/IMSLib.dylib
             0x14e90d000 -        0x14e986fff  com.apple.xquery (1.3.1 - 30) <031D5366-8C48-3124-93EC-3AB4A5758460> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
             0x154c2e000 -        0x154dd4fff  GLEngine (14.0.16) <08F2E804-13D2-3E80-9322-1A23A84A55F3> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
             0x158ee8000 -        0x158f22fff +com.adobe.pip (7.3.1.61) <5371E762-F32A-3330-BF9D-D090A074E2F3> /Applications/Adobe Dreamweaver CC 2017/Adobe Dreamweaver CC 2017.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
          0x7fffc46c6000 -     0x7fffc4a0bff7  com.apple.RawCamera.bundle (7.04 - 914) <86A67D11-9791-3CE6-9FF5-3387C0AB925B> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
          0x7fffc5018000 -     0x7fffc5865fff  com.apple.GeForceGLDriver (10.17.5 - 10.1.7) <CB32FE96-F197-3605-929B-DC4D7E8BBCA7> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
          0x7fffc5866000 -     0x7fffc612bff3  libclh.dylib (4.0.3 - 4.0.3) <2CA40E20-9E48-3A2E-A0A4-2AAAF150F723> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
          0x7fffc612c000 -     0x7fffc623cff7  com.apple.GeForceMTLDriver (10.17.5 - 10.1.7) <CE0C6DDC-FCB7-3137-A8C3-75DCEF5DEA61> /System/Library/Extensions/GeForceMTLDriver.bundle/Contents/MacOS/GeForceMTLDriver
          0x7fffc623d000 -     0x7fffc6241ffb  com.apple.agl (3.3.1 - AGL-3.3.1) <752FDB92-EF67-3D04-BF40-A352BF1075CF> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
          0x7fffc6242000 -     0x7fffc6403fff  com.apple.avfoundation (2.0 - 1187.36) <2F390EAD-07BB-3788-9E73-13104C2E04CD> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
          0x7fffc6404000 -     0x7fffc64a6ff7  com.apple.audio.AVFAudio (1.0 - ???) <7997D588-B542-3EBB-B822-D719C1114BB4> /System/Library/Frameworks/AVFoundation.framework/Versions/A/Frameworks/AVFAudio.framewor k/Versions/A/AVFAudio
          0x7fffc6571000 -     0x7fffc6571fff  com.apple.Accelerate (1.11 - Accelerate 1.11) <916E360F-323C-3AE1-AB3D-D1F3B284AEE9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
          0x7fffc6572000 -     0x7fffc6589ffb  libCGInterfaces.dylib (331.5) <17109679-A284-3C72-AA60-DBA815D3062B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/Libraries/libCGInterfaces.dylib
          0x7fffc658a000 -     0x7fffc6aa3feb  com.apple.vImage (8.1 - ???) <B58A7937-BEE2-38FE-87F4-5D5F40D31DC9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
          0x7fffc6aa4000 -     0x7fffc6c15ff3  libBLAS.dylib (1185.50.4) <4087FFE0-627E-3623-96B4-F0A9A1991E09> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
          0x7fffc6c16000 -     0x7fffc6c2affb  libBNNS.dylib (15) <254698C7-7D36-3FFF-864E-ADEEEE543076> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBNNS.dylib
          0x7fffc6c2b000 -     0x7fffc7021fef  libLAPACK.dylib (1185.50.4) <C35FFB2F-A0E6-3903-8A3C-113A74BCBCA2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
          0x7fffc7022000 -     0x7fffc7038fff  libLinearAlgebra.dylib (1185.50.4) <345CAACF-7263-36EF-B69B-793EA8B390AF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
          0x7fffc7039000 -     0x7fffc703ffff  libQuadrature.dylib (3) <EF56C8E6-DE22-3C69-B543-A8648F335FDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libQuadrature.dylib
          0x7fffc7040000 -     0x7fffc7054ff7  libSparseBLAS.dylib (1185.50.4) <67BA432E-FB59-3C78-A8BE-ED4274CBC359> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparseBLAS.dylib
          0x7fffc7055000 -     0x7fffc71dcfe7  libvDSP.dylib (600.60.1) <4155F45B-41CD-3782-AE8F-7AE740FD83C3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
          0x7fffc71dd000 -     0x7fffc728ffff  libvMisc.dylib (600.60.1) <E18365D7-DCC4-3304-A8D1-395E656D7B99> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
          0x7fffc7290000 -     0x7fffc7290fff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <7C5733E7-0568-3E7D-AF61-160F19FED544> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
          0x7fffc7291000 -     0x7fffc72ceffb  com.apple.Accounts (113 - 113) <8550BD08-7D05-3AC4-A0CC-B67ECB2DE950> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
          0x7fffc72cf000 -     0x7fffc754eff7  com.apple.AddressBook.framework (10.0 - 1756.20) <E512B69B-8DBE-3085-95BE-750B8EFC97FD> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
          0x7fffc754f000 -     0x7fffc8328ff3  com.apple.AppKit (6.9 - 1504.83.101) <AE51ACB3-D501-3F91-B369-3D3711F24D0A> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
          0x7fffc833a000 -     0x7fffc833afff  com.apple.ApplicationServices (48 - 48) <DA687F9A-7B2D-342B-8796-16E45344F853> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
          0x7fffc833b000 -     0x7fffc83a9ff7  com.apple.ApplicationServices.ATS (377 - 422.2) <A31D17BE-F747-39FB-9A84-5F2F8891204C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
          0x7fffc8443000 -     0x7fffc8572ff7  libFontParser.dylib (194.12) <73C3946D-EF92-3AC1-89C3-0E75B2A85325> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
          0x7fffc8573000 -     0x7fffc85bdfff  libFontRegistry.dylib (196.4) <EA96AE47-3369-3DEA-BB82-98348ADBD85B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
          0x7fffc861a000 -     0x7fffc864dfff  libTrueTypeScaler.dylib (194.12) <8944A23A-EE36-3657-9B4F-933231C8FDEC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
          0x7fffc86ba000 -     0x7fffc8764ff7  com.apple.ColorSync (4.12.0 - 502.2) <ACA4001E-A0E3-33F6-9CD6-EEC2AA15E322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
          0x7fffc8765000 -     0x7fffc87b6fff  com.apple.HIServices (1.22 - 593) <045870A9-1D92-3FEF-8722-671E99A35E71> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
          0x7fffc87b7000 -     0x7fffc87c6ff3  com.apple.LangAnalysis (1.7.0 - 1.7.0) <2CBE7F61-2056-3F96-99A1-0D527796AFA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
          0x7fffc87c7000 -     0x7fffc8814fff  com.apple.print.framework.PrintCore (12 - 491) <5027FD58-F0EE-33E4-8577-934CA06CD2AF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
          0x7fffc8815000 -     0x7fffc8850fff  com.apple.QD (3.12 - 313) <B339C41D-8CDF-3342-8414-F9717DCCADD4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
          0x7fffc8851000 -     0x7fffc885cfff  com.apple.speech.synthesis.framework (6.6.2 - 6.6.2) <7853EFF4-62B9-394E-B7B8-41A645656820> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
          0x7fffc885d000 -     0x7fffc8a69ff7  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <01518CAB-7DAD-3F09-83F8-B9FE0ABE998F> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
          0x7fffc8a6a000 -     0x7fffc8a6afff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <B92868F8-2F15-32C0-A5BE-4ABA546B8BE1> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
          0x7fffc8bd3000 -     0x7fffc8fadfff  com.apple.CFNetwork (811.5.4 - 811.5.4) <46B1227B-F38C-3F8E-B0B5-5D9861ABF36B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
          0x7fffc8fc7000 -     0x7fffc8fc7fff  com.apple.Carbon (154 - 157) <69F403C7-F0CB-34E6-89B0-235CF4978C17> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
          0x7fffc8fc8000 -     0x7fffc8fcbfff  com.apple.CommonPanels (1.2.6 - 98) <BF04BB22-D54C-309E-9F5C-897D969CAF70> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
          0x7fffc8fcc000 -     0x7fffc92d5fff  com.apple.HIToolbox (2.1.1 - 857.8) <5367366E-747E-32CF-8E76-93CD8E7424C7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
          0x7fffc92d6000 -     0x7fffc92d9ff7  com.apple.help (1.3.5 - 49) <B1A930E3-5907-3677-BACD-858EF68B172D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
          0x7fffc92da000 -     0x7fffc92dffff  com.apple.ImageCapture (9.0 - 9.0) <341252B4-E082-361A-B756-6A330259C741> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
          0x7fffc92e0000 -     0x7fffc9377ff3  com.apple.ink.framework (10.9 - 219) <1BD40B45-FD33-3177-A935-565EE5FC79D7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
          0x7fffc9378000 -     0x7fffc9392fff  com.apple.openscripting (1.7 - 172) <31CFBB35-24BD-3E12-9B6B-1FA842FB605B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
          0x7fffc9393000 -     0x7fffc9394ff3  com.apple.print.framework.Print (12 - 267) <E2F82F1F-DC27-3EF0-9F75-B354F701450A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
          0x7fffc9395000 -     0x7fffc9397ff7  com.apple.securityhi (9.0 - 55006) <DBD65629-535D-3669-8218-7F074D61638C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
          0x7fffc9398000 -     0x7fffc939eff7  com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <082895DC-3AC7-3DEF-ADCA-5B018C19C9D3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
          0x7fffc939f000 -     0x7fffc947effb  com.apple.cloudkit.CloudKit (651.14 - 651.14) <9F901E45-23E3-3F45-B66F-1BAB3AFC4462> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
          0x7fffc947f000 -     0x7fffc947ffff  com.apple.Cocoa (6.11 - 22) <85EDFBE1-75F0-369E-8CA8-C6A639B98FA6> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
          0x7fffc95c9000 -     0x7fffc9656fff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <78767F88-91D4-31CE-AAC6-1F9407F479BB> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
          0x7fffc9657000 -     0x7fffc966afff  com.apple.CoreBluetooth (1.0 - 1) <BCB78777-76F0-3CC1-8443-9E61AEF7EF63> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
          0x7fffc966b000 -     0x7fffc9966fff  com.apple.CoreData (120 - 754.2) <4C9CAB2C-60D4-3694-A0A0-5B04B14BD14E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
          0x7fffc9967000 -     0x7fffc9a14ff7  com.apple.CoreDisplay (1.0 - 1) <53D1EAFE-23A4-398D-BF52-E4299E670DB6> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
          0x7fffc9a15000 -     0x7fffc9eaeff7  com.apple.CoreFoundation (6.9 - 1349.8) <09ED473E-5DE8-307F-B55C-16F6419236D5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
          0x7fffc9eaf000 -     0x7fffca531fff  com.apple.CoreGraphics (2.0 - 1070.22) <FAB476BB-B5CD-3936-8AFC-41229DBDF0E8> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
          0x7fffca532000 -     0x7fffca775ffb  com.apple.CoreImage (12.4.0 - 451.4.9) <BE4303C9-C9D9-361D-AC94-DBE40EB6700E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
          0x7fffca776000 -     0x7fffca7dbff7  com.apple.corelocation (2101.0.63) <C4C6BE27-85E2-34D5-AEDC-EBB5A7CB78D1> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
          0x7fffca7dc000 -     0x7fffca88dfff  com.apple.CoreMedia (1.0 - 1907.59.1.6) <570690D8-A956-3629-9E46-4F8BDDB8A82C> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
          0x7fffca88e000 -     0x7fffca8d9ff7  com.apple.CoreMediaIO (805.0 - 4932) <03F2B863-BF99-36DF-9A14-1DB534A289F3> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
          0x7fffca8da000 -     0x7fffca8dafff  com.apple.CoreServices (775.19 - 775.19) <7255917D-EFBB-3BE2-A8FD-DAD631BC0949> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
          0x7fffca8db000 -     0x7fffca92cfff  com.apple.AE (712.5 - 712.5) <61F2AE2C-E04E-3FDF-9E88-201325136C83> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
          0x7fffca92d000 -     0x7fffcac08ff7  com.apple.CoreServices.CarbonCore (1159.6 - 1159.6) <08AC074C-965B-3EDF-8E45-0707C8DE9EAD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
          0x7fffcac09000 -     0x7fffcac3cfff  com.apple.DictionaryServices (1.2 - 274) <D23866E2-F7C8-3984-A9D4-96552CCDE573> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
          0x7fffcac3d000 -     0x7fffcac45ff3  com.apple.CoreServices.FSEvents (1230.50.1 - 1230.50.1) <2AD1B0E5-7214-37C4-8D11-A27C9CAC0F74> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
          0x7fffcac46000 -     0x7fffcadb2ff7  com.apple.LaunchServices (775.19 - 775.19) <B75A0C49-E376-358C-81EE-6EFB0F605801> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
          0x7fffcadb3000 -     0x7fffcae63ffb  com.apple.Metadata (10.7.0 - 1075.40) <B2FFCC10-5A9E-396B-B495-3D6C867669EE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
          0x7fffcae64000 -     0x7fffcaec3fff  com.apple.CoreServices.OSServices (775.19 - 775.19) <4140569A-1848-3765-A52B-BB61C35CF88F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
          0x7fffcaec4000 -     0x7fffcaf34fff  com.apple.SearchKit (1.4.0 - 1.4.0) <7A6DDA2B-03F1-3137-BA9E-1CC211973E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
          0x7fffcaf35000 -     0x7fffcaf7aff7  com.apple.coreservices.SharedFileList (38 - 38) <DA096678-93AB-3291-BDE2-482F1D544589> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.fr amework/Versions/A/SharedFileList
          0x7fffcb003000 -     0x7fffcb150ffb  com.apple.CoreText (352.0 - 544.15) <BF0EE575-BB7E-3BF9-9029-232B4ADC24E4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
          0x7fffcb151000 -     0x7fffcb186ff3  com.apple.CoreVideo (1.8 - 235.3) <AC11D5FB-C77B-34F5-B942-F698E84C229F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
          0x7fffcb187000 -     0x7fffcb1f8ffb  com.apple.framework.CoreWLAN (11.0 - 1200.31) <E47C0568-E37B-3052-9E77-F0F371DCDE7F> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
          0x7fffcb22b000 -     0x7fffcb236ff3  com.apple.DirectoryService.Framework (10.12 - 194) <45BEA292-4550-3082-8CE7-5D6CE7E0052A> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
          0x7fffcb2f6000 -     0x7fffcb2fbfff  com.apple.DiskArbitration (2.7 - 2.7) <70F56042-EF04-3BAF-9E04-90F423FB2BCC> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
          0x7fffcb48d000 -     0x7fffcb833fff  com.apple.Foundation (6.9 - 1349.91) <A37CB4EC-0730-3DD6-9358-60491BF40EF2> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
          0x7fffcb85f000 -     0x7fffcb890ff7  com.apple.GSS (4.0 - 2.0) <6FADED0B-0425-3567-A75A-040C5A4638EB> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
          0x7fffcb891000 -     0x7fffcb8a9ff7  com.apple.GameController (1.0 - 1) <DAC8C83B-7EC8-3A88-A725-E13DD905BF4F> /System/Library/Frameworks/GameController.framework/Versions/A/GameController
          0x7fffcb950000 -     0x7fffcb9f3fff  com.apple.Bluetooth (5.0.5 - 5.0.5f1) <913B97A6-9E18-3F15-992D-D522AA22EDE9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
          0x7fffcb9f4000 -     0x7fffcba8aff7  com.apple.framework.IOKit (2.0.2 - 1324.60.3) <7CE4C98B-107C-3AAA-B49A-F2ACFCBBF526> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
          0x7fffcba8b000 -     0x7fffcba91ffb  com.apple.IOSurface (159.9 - 159.9) <08F1A246-1367-32EC-B3CE-724379409729> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
          0x7fffcba92000 -     0x7fffcbae3ff7  com.apple.ImageCaptureCore (7.0 - 7.0) <A640CA2F-8093-34AB-947C-26679ECB8A6D> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
          0x7fffcbae4000 -     0x7fffcbc44fef  com.apple.ImageIO.framework (3.3.0 - 1599.12) <E54ADBF0-6001-3DEB-AEB0-3F857A781E06> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
          0x7fffcbc45000 -     0x7fffcbc49fff  libGIF.dylib (1599.12) <A0836C44-9566-32A3-ACCF-82A5BAF2E521> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
          0x7fffcbc4a000 -     0x7fffcbd3aff7  libJP2.dylib (1599.12) <0DB4F152-B36D-365C-97B1-34F1C114982B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
          0x7fffcbd3b000 -     0x7fffcbd5effb  libJPEG.dylib (1599.12) <2F66BA16-D569-35AD-A4BB-7A1909F1BF11> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
          0x7fffcbd5f000 -     0x7fffcbd86ff7  libPng.dylib (1599.12) <A068239E-7DB3-33AD-BEA9-499D8DEF771B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
          0x7fffcbd87000 -     0x7fffcbd89ff3  libRadiance.dylib (1599.12) <D26D6FC9-1175-38AB-ACAA-0CA073FD3978> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
          0x7fffcbd8a000 -     0x7fffcbdd8ffb  libTIFF.dylib (1599.12) <5D161E6A-D279-37A0-9F5F-A71A4C13BB09> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
          0x7fffcbf36000 -     0x7fffccb40fff  com.apple.JavaScriptCore (12603 - 12603.3.8) <9557271A-1838-38DD-93E3-D8A9ECDE3B6B> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
          0x7fffccb41000 -     0x7fffccb5aff7  com.apple.Kerberos (3.0 - 1) <B9D242EB-E325-3A21-9812-C77CBBFB0D51> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
          0x7fffccb5b000 -     0x7fffccb91fff  com.apple.LDAPFramework (2.4.28 - 194.5) <492ACA22-373E-3DD9-BAEB-9EF6AA962FD5> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
          0x7fffccde4000 -     0x7fffccdeafff  com.apple.MediaAccessibility (1.0 - 97.1.1) <0BD82735-6644-37CE-B13D-8E7CC59A1752> /System/Library/Frameworks/MediaAccessibility.framework/Versions/A/MediaAccessibility
          0x7fffcce00000 -     0x7fffcd339ff7  com.apple.MediaToolbox (1.0 - 1907.59.1.6) <FA068C6F-0506-35C3-A637-C4AFF82411DB> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
          0x7fffcd33a000 -     0x7fffcd395fff  com.apple.Metal (87.18 - 87.18) <E3618B54-C728-34CA-9E8A-9BD33A295D31> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
          0x7fffcdc7e000 -     0x7fffcdc86fff  com.apple.NetFS (6.0 - 4.0) <14A24D00-5673-330A-959D-87F72040DEFF> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
          0x7fffcde5d000 -     0x7fffcde65ff7  libcldcpuengine.dylib (2.8.5) <81563526-886E-37E4-BF85-4A6D75F93C65> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
          0x7fffcde66000 -     0x7fffcdeb4ff3  com.apple.opencl (2.8.6 - 2.8.6) <E78463D3-73B6-3002-BD71-9CC1D6722968> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
          0x7fffcdeb5000 -     0x7fffcdeceffb  com.apple.CFOpenDirectory (10.12 - 194) <A64E9A01-3F6E-36EA-9C10-88C564A68C9D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
          0x7fffcdecf000 -     0x7fffcdedaff7  com.apple.OpenDirectory (10.12 - 194) <4298FFD0-B1A7-3064-AF5B-708B3FA38671> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
          0x7fffcdedb000 -     0x7fffcdeddfff  libCVMSPluginSupport.dylib (14.0.16) <9E12EB67-6630-39A0-AB93-77405F5EC2A7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
          0x7fffcdede000 -     0x7fffcdee1ff7  libCoreFSCache.dylib (156.3) <687C4CC3-6537-344B-8BE1-5234C8CB2864> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
          0x7fffcdee2000 -     0x7fffcdee6fff  libCoreVMClient.dylib (156.3) <E7AEFCBE-B6BF-3C7C-9A4E-E78CB04DB794> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
          0x7fffcdee7000 -     0x7fffcdef0ff7  libGFXShared.dylib (14.0.16) <D10C7A01-8A11-3A42-A9FA-C411AE453B27> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
          0x7fffcdef1000 -     0x7fffcdefcfff  libGL.dylib (14.0.16) <0801F3B9-A525-32BB-9BC0-478947CE21D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
          0x7fffcdefd000 -     0x7fffcdf39ff7  libGLImage.dylib (14.0.16) <FE39C57B-056C-3CBF-B653-A8F2005631C1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
          0x7fffcdf3a000 -     0x7fffce0b0ff3  libGLProgrammability.dylib (14.0.16) <A95F26AD-D496-3581-A310-5131F61CFB4A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
          0x7fffce0b1000 -     0x7fffce0f2ff7  libGLU.dylib (14.0.16) <B285EAD6-B3AA-3753-BB85-75864BD6E76C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
          0x7fffcea5a000 -     0x7fffcea68fff  com.apple.opengl (14.0.16 - 14.0.16) <167C9883-A79E-3B7F-AFED-8CD6683B291D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
          0x7fffceb05000 -     0x7fffcec4cfff  com.apple.QTKit (7.7.3 - 2978.7) <49F88771-52FE-3989-AAB7-10A7494C4419> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
          0x7fffcec4d000 -     0x7fffceeb7ff7  com.apple.imageKit (3.0 - 1023) <9C547565-CBAA-3ACB-A3F6-1366A0DCDCB4> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
          0x7fffceeb8000 -     0x7fffcef7ffff  com.apple.PDFKit (1.0 - 1) <BE82F14C-B20C-3771-B16C-F0723F6552AD> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
          0x7fffcef80000 -     0x7fffcf4a6ff7  com.apple.QuartzComposer (5.1 - 356) <C66293F6-EF05-3B36-8524-081CEB9FADD7> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
          0x7fffcf4a7000 -     0x7fffcf4caffb  com.apple.quartzfilters (1.10.0 - 1.10.0) <365342ED-7A1A-3C75-AE60-90764E96034C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
          0x7fffcf4cb000 -     0x7fffcf5b8fff  com.apple.QuickLookUIFramework (5.0 - 720.7) <3136C23E-399E-3296-928A-B18EC9FC423C> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
          0x7fffcf5b9000 -     0x7fffcf5b9fff  com.apple.quartzframework (1.5 - 21) <09455972-8A33-3D61-B193-BA7E7CF984CA> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
          0x7fffcf5ba000 -     0x7fffcf7bafff  com.apple.QuartzCore (1.11 - 453.39.4) <A45AFBC4-87D4-3533-A0AC-1D6629C77984> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
          0x7fffcf7bb000 -     0x7fffcf810fff  com.apple.QuickLookFramework (5.0 - 720.7) <3BD7BA2F-924C-3EFF-B26E-3F930E62E6B4> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
          0x7fffcf811000 -     0x7fffcf826fff  com.apple.SafariServices.framework (12603 - 12603.3.8) <966BF0C8-B94B-3BDF-AFE1-0F99DAAE6D99> /System/Library/Frameworks/SafariServices.framework/Versions/A/SafariServices
          0x7fffcfd09000 -     0x7fffcfd20ff7  com.apple.ScriptingBridge (1.3.3 - 69) <F51B85CD-9C80-317E-B594-4A03612EAF52> /System/Library/Frameworks/ScriptingBridge.framework/Versions/A/ScriptingBridge
          0x7fffcfd21000 -     0x7fffd0023ff7  com.apple.security (7.0 - 57740.60.18) <005E8C96-40B6-35E3-B58B-888A5F5957C2> /System/Library/Frameworks/Security.framework/Versions/A/Security
          0x7fffd0024000 -     0x7fffd0099fff  com.apple.securityfoundation (6.0 - 55132.50.7) <15C53957-A9DE-31AE-A192-949244F47CD7> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
          0x7fffd009a000 -     0x7fffd00c3fff  com.apple.securityinterface (10.0 - 55079.50.4) <C9B0E11A-362B-3C0D-8B2E-B06510BCE20A> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
          0x7fffd00c4000 -     0x7fffd00c7ff3  com.apple.xpc.ServiceManagement (1.0 - 1) <BE0F9708-0B55-3E78-A15E-C287B8ED13BA> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
          0x7fffd044e000 -     0x7fffd04bdff7  com.apple.SystemConfiguration (1.14 - 1.14) <3FFD3930-B307-3E31-9FA6-12221EB0F969> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
          0x7fffd04be000 -     0x7fffd086cfff  com.apple.VideoToolbox (1.0 - 1907.59.1.6) <EB2577A4-DCDF-3FD1-B5FA-42A55653A74D> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
          0x7fffd2d14000 -     0x7fffd2d2fff3  com.apple.AppContainer (4.0 - 307.50.21) <C2E6BA3D-81FF-39C3-B4BF-DBB9A17DE078> /System/Library/PrivateFrameworks/AppContainer.framework/Versions/A/AppContainer
          0x7fffd2d30000 -     0x7fffd2d3dff3  com.apple.AppSandbox (4.0 - 307.50.21) <BF9FA426-8C11-358B-9E1F-A3901E3F2B14> /System/Library/PrivateFrameworks/AppSandbox.framework/Versions/A/AppSandbox
          0x7fffd2d3e000 -     0x7fffd2d60ffb  com.apple.framework.Apple80211 (12.0 - 1200.47) <C3033EEE-771A-3664-BBDD-BE1F6D075FC7> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
          0x7fffd2d61000 -     0x7fffd2d70feb  com.apple.AppleFSCompression (88.50.3 - 1.0) <478E8BFF-8BA2-375E-BE02-BA27F115C15A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
          0x7fffd2e5e000 -     0x7fffd2ee997f  com.apple.AppleJPEG (1.0 - 1) <B9E9570D-04A4-34E4-B756-D200043B25B8> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
          0x7fffd2efd000 -     0x7fffd2f18fff  com.apple.aps.framework (4.0 - 4.0) <6CA07CDF-1E35-34E9-95BF-BD565FF42BAD> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
          0x7fffd2f19000 -     0x7fffd2f21ffb  com.apple.AppleSRP (5.0 - 1) <6AAE93B6-9816-35B2-9C59-D5C3218065AF> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
          0x7fffd2f22000 -     0x7fffd2f25ff3  com.apple.AppleSystemInfo (3.1.5 - 3.1.5) <42A1731A-A576-307A-B07C-9F8F64696CB7> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
          0x7fffd2f26000 -     0x7fffd2f78fff  com.apple.AppleVAFramework (5.0.36 - 5.0.36) <7352078D-C230-397C-81A5-57A48CF218C0> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
          0x7fffd2f82000 -     0x7fffd2f89ff7  com.apple.AssetCacheServices (48.3 - 48.3) <C59F7295-36D8-3109-A910-C83D884CC92C> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServi ces
          0x7fffd331c000 -     0x7fffd339aff7  com.apple.backup.framework (1.8.5 - 1.8.5) <CC679891-E8F5-3166-8EB6-AEA06954A52D> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
          0x7fffd3a36000 -     0x7fffd3a5dfff  com.apple.CalendarAgentLink (8.0 - 250) <E50E29F6-2BAB-3B8B-BBEA-7DC0B8B077AD> /System/Library/PrivateFrameworks/CalendarAgentLink.framework/Versions/A/CalendarAgentLin k
          0x7fffd4025000 -     0x7fffd404cff3  com.apple.ChunkingLibrary (173 - 173) <FC2165F9-FC93-39C0-8323-C2F43A5E00A3> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
          0x7fffd404d000 -     0x7fffd40d9ff7  com.apple.CloudDocs (1.0 - 486.29) <392B87EC-0317-313F-8FE2-F571831C7F35> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
          0x7fffd4971000 -     0x7fffd497affb  com.apple.CommonAuth (4.0 - 2.0) <216950CB-269F-3476-BA17-D6363AC49FBC> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
          0x7fffd4a41000 -     0x7fffd4a92ff7  com.apple.AddressBook.ContactsFoundation (8.0 - 2250.11) <1324A70E-A093-3DB9-A802-07B8F4A499B5> /System/Library/PrivateFrameworks/ContactsFoundation.framework/Versions/A/ContactsFoundat ion
          0x7fffd4a93000 -     0x7fffd4ab5fff  com.apple.contacts.ContactsPersistence (1.0 - 2250.11) <7CDEB852-B3B7-328F-9537-DFB3A58B882C> /System/Library/PrivateFrameworks/ContactsPersistence.framework/Versions/A/ContactsPersis tence
          0x7fffd4aff000 -     0x7fffd4edeff7  com.apple.CoreAUC (226.0.0 - 226.0.0) <FBF6C5BC-5937-3957-B6BA-E101DF9B0DF6> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
          0x7fffd4edf000 -     0x7fffd4f0ffff  com.apple.CoreAVCHD (5.9.0 - 5900.4.1) <3F6857D1-AE7C-3593-B064-930F5BB7269E> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
          0x7fffd4faa000 -     0x7fffd4fb2ffb  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <2AB86FAF-37B3-3323-9EF0-CA591B6E357C> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
          0x7fffd50c3000 -     0x7fffd50d3fff  com.apple.CoreEmoji (1.0 - 40.3.3) <E9A28301-2D79-3A97-A046-028258A6ABE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
          0x7fffd5198000 -     0x7fffd51aeff3  com.apple.CoreMediaAuthoring (2.2 - 956) <AEBFF55F-BF1E-3CA5-AA9C-1CE22218A665> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
          0x7fffd51b5000 -     0x7fffd5245ffb  com.apple.CorePDF (4.0 - 4) <7F50E4A6-940C-33F5-BE4E-7E01AFE98A8F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
          0x7fffd540e000 -     0x7fffd543eff3  com.apple.CoreServicesInternal (276.2 - 276.2) <05EB7D45-DD4C-3A0F-AC63-A0C2A68E6481> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
          0x7fffd56cf000 -     0x7fffd575eff7  com.apple.CoreSymbolication (62046) <7839CD8E-011D-3567-88DE-3D472C661136> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
          0x7fffd575f000 -     0x7fffd589efe7  com.apple.coreui (2.1 - 431.3) <2E8FEC10-FC5B-3782-92DA-A85C24B7BF7C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
          0x7fffd589f000 -     0x7fffd596fff3  com.apple.CoreUtils (5.1 - 510.31) <E68BB8ED-8874-36EC-A7C5-1017C0E727CB> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
          0x7fffd59bf000 -     0x7fffd5a24ff3  com.apple.framework.CoreWiFi (12.0 - 1200.31) <DF0972EF-F817-3FD3-8C00-2D57B8738D8C> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
          0x7fffd5a25000 -     0x7fffd5a33ff7  com.apple.CrashReporterSupport (10.12 - 827) <802A9B81-E349-348B-90AB-10E40B654250> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
          0x7fffd5aa5000 -     0x7fffd5aafffb  com.apple.framework.DFRFoundation (1.0 - 104.25) <7CFF896C-EF22-3941-BB3D-F3615CE4C908> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
          0x7fffd5ab0000 -     0x7fffd5ab4ff3  com.apple.DSExternalDisplay (3.1 - 380) <4B5E3FF0-E8C3-38CC-BF72-418C928956AB> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDispla y
          0x7fffd5aea000 -     0x7fffd5b5fffb  com.apple.datadetectorscore (7.0 - 539.1) <74595F6C-8283-3C73-9F56-C6FA957F8B94> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
          0x7fffd5b9b000 -     0x7fffd5bdafff  com.apple.DebugSymbols (137 - 137) <58A70B66-2628-3CFE-B103-2200D95FC5F7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
          0x7fffd5bdb000 -     0x7fffd5cecfff  com.apple.desktopservices (1.11.5 - 1.11.5) <46A9D4F3-1EF8-373C-98A4-AD48D285E484> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
          0x7fffd5e2f000 -     0x7fffd5e3afff  com.apple.DisplayServicesFW (3.1 - 380) <0BDF6C17-5E5F-33F8-8E99-C7350C6F9667> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
          0x7fffd5fd4000 -     0x7fffd6405ff7  com.apple.vision.FaceCore (3.3.2 - 3.3.2) <9391D5A3-738C-3136-9D07-518CB43DBADA> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
          0x7fffd775c000 -     0x7fffd775cfff  libmetal_timestamp.dylib (600.0.49.9) <E5EED927-1671-3390-BCBB-D76201D63C73> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
          0x7fffd7769000 -     0x7fffd7774ff3  libGPUSupportMercury.dylib (14.0.16) <7EE3DA75-2F9D-3C6D-AECD-F73EA47BE81B> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport Mercury.dylib
          0x7fffd7a2d000 -     0x7fffd7a49fff  com.apple.GenerationalStorage (2.0 - 267.1) <3DE1C580-D089-362D-8582-8DE68A3C5F13> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
          0x7fffd7a62000 -     0x7fffd8114fff  com.apple.GeoServices (1.0 - 1228.24.9.30.34) <96BF97F6-8FF2-3FC4-A8C1-498CB7B0D9A0> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
          0x7fffd815a000 -     0x7fffd81d0ff3  com.apple.Heimdal (4.0 - 2.0) <8F9C9041-66D5-36C9-8A4C-1658035C311D> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
          0x7fffd87eb000 -     0x7fffd87f2ffb  com.apple.IOAccelerator (311.14 - 311.14) <278124AF-02DC-3785-9FA9-14EDB8E5FD56> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
          0x7fffd87f4000 -     0x7fffd8808ff7  com.apple.IOPresentment (1.0 - 29.10) <30DF04EE-10E2-353F-845F-A97B87DF3207> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
          0x7fffd8809000 -     0x7fffd882bfff  com.apple.IconServices (74.4 - 74.4) <218DDD05-35F4-3833-B98D-471ED0EBC031> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
          0x7fffd88c7000 -     0x7fffd88d7ff3  com.apple.IntlPreferences (2.0 - 216) <77C9C2E7-EF9F-34BB-A5E3-B8BEA4226B5F> /System/Library/PrivateFrameworks/IntlPreferences.framework/Versions/A/IntlPreferences
          0x7fffd8912000 -     0x7fffd8ac9fff  com.apple.LanguageModeling (1.0 - 123.2.5) <A8CA965F-0399-310D-91C3-B93DDDE9A442> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
          0x7fffd8bc5000 -     0x7fffd8c87ff3  com.apple.MMCS (1.3 - 385.4) <D3D76CE0-DE05-373E-B757-9E4B4920565D> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
          0x7fffd9139000 -     0x7fffd913cfff  com.apple.Mangrove (1.0 - 1) <98814966-FD65-302B-B47E-00928DC34E5C> /System/Library/PrivateFrameworks/Mangrove.framework/Versions/A/Mangrove
          0x7fffd93ea000 -     0x7fffd9463ff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <C323FC94-FFA5-3EE6-B2AC-7E61EA92F304> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerfo rmanceShaders
          0x7fffd95bf000 -     0x7fffd95cdfff  com.apple.MobileKeyBag (2.0 - 1.0) <D0983DB7-EF9D-3E19-A084-21319ECE5846> /System/Library/PrivateFrameworks/MobileKeyBag.framework/Versions/A/MobileKeyBag
          0x7fffd95de000 -     0x7fffd9606ff7  com.apple.MultitouchSupport.framework (368.16 - 368.16) <9E602B4A-22CD-3CF3-B284-78D5123C9AE8> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
          0x7fffd96b8000 -     0x7fffd96c3fff  com.apple.NetAuth (6.2 - 6.2) <97F487D6-8089-31A8-B68C-6C1EAC6ED1B5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
          0x7fffd9b10000 -     0x7fffd9b12fff  com.apple.OAuth (25 - 25) <D6E5F36D-71B8-3E12-9601-CE2A1D6ED60B> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth
          0x7fffd9f9b000 -     0x7fffd9fdcff3  com.apple.PerformanceAnalysis (1.148.3 - 148.3) <4E468BC7-F863-3674-909D-417231EB8C28> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
          0x7fffda01f000 -     0x7fffda026ff3  com.apple.phonenumbers (1.1.1 - 105) <B8EFDDD3-BA26-39B8-9EA0-3649184BF527> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
          0x7fffda689000 -     0x7fffda6c3ffb  com.apple.ProtectedCloudStorage (1.0 - 1) <8B32A7EC-D371-38E3-A286-F1BE1307F1E1> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
          0x7fffda6c4000 -     0x7fffda6defff  com.apple.ProtocolBuffer (1 - 249.1) <A1F1B0F3-078F-378F-A9A9-0DEEA70E816A> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
          0x7fffda6df000 -     0x7fffda6eeff7  com.apple.QuickLookThumbnailing (1.0 - 1) <173EE873-1700-3FCA-9782-C060FBB5BCAD> /System/Library/PrivateFrameworks/QuickLookThumbnailing.framework/Versions/A/QuickLookThu mbnailing
          0x7fffda6f7000 -     0x7fffda71aff3  com.apple.RemoteViewServices (2.0 - 124) <6B967FDA-6591-302C-BA0A-76C4856E584E> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
          0x7fffdb3e4000 -     0x7fffdb3e7fff  com.apple.SecCodeWrapper (4.0 - 307.50.21) <F8E957B2-D3F0-3B73-B38C-AE8868F00939> /System/Library/PrivateFrameworks/SecCodeWrapper.framework/Versions/A/SecCodeWrapper
          0x7fffdb476000 -     0x7fffdb503fff  com.apple.Sharing (696.2.67 - 696.2.67) <F681EE28-153F-3216-97A6-6F5E4148AB2E> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
          0x7fffdb524000 -     0x7fffdb78afeb  com.apple.SkyLight (1.600.0 - 170.3) <38AC05EF-3A9E-3E3E-9849-04E0223DF7B9> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
          0x7fffdb969000 -     0x7fffdb975ff7  com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <684BD1EA-8268-331C-A5A9-080EB375C658> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
          0x7fffdc061000 -     0x7fffdc0d5fdf  com.apple.Symbolication (62048.1) <1A30ED19-7532-3F46-9DD3-9879A973D0CF> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
          0x7fffdc514000 -     0x7fffdc51aff7  com.apple.TCC (1.0 - 1) <911B534B-4AC7-34E4-935E-E42ECD008CBC> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
          0x7fffdc5a6000 -     0x7fffdc66cff7  com.apple.TextureIO (2.8 - 2.8) <3D61E533-4156-3B21-B7ED-CB823E680DFC> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
          0x7fffdc6b5000 -     0x7fffdc6caff3  com.apple.ToneKit (1.0 - 1) <B709293D-0A79-398A-8AA9-50F6340C227C> /System/Library/PrivateFrameworks/ToneKit.framework/Versions/A/ToneKit
          0x7fffdc6cb000 -     0x7fffdc6d9ffb  com.apple.ToneLibrary (1.0 - 1) <F2ED5DFC-5F11-3012-BCD7-17753413141F> /System/Library/PrivateFrameworks/ToneLibrary.framework/Versions/A/ToneLibrary
          0x7fffdc6e0000 -     0x7fffdc6e1fff  com.apple.TrustEvaluationAgent (2.0 - 28.50.1) <EBE65DD5-1732-3747-8C6C-7BECEBF089A4> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
          0x7fffdc6e2000 -     0x7fffdc872ff3  com.apple.UIFoundation (1.0 - 490.7) <2A3063FE-1790-3510-8A0E-AEC581D42B7E> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
          0x7fffdd341000 -     0x7fffdd401fff  com.apple.ViewBridge (283 - 283) <25A635B3-C87C-3D3A-ADF3-539713FA1048> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
          0x7fffdd84c000 -     0x7fffdd852fff  com.apple.XPCService (2.0 - 1) <4B28B225-2105-33F4-9ED0-F04288FF4FB1> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
          0x7fffdd923000 -     0x7fffdd925ffb  com.apple.loginsupport (1.0 - 1) <F3140B97-12C3-35A7-9D3D-43DA2D13C113> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
          0x7fffdd951000 -     0x7fffdd978ff7  com.apple.contacts.vCard (1.0 - 2250.11) <DD615DAF-AF34-3AB4-9CB4-DA0A882D59A5> /System/Library/PrivateFrameworks/vCard.framework/Versions/A/vCard
          0x7fffdd97a000 -     0x7fffdd995ff7  libCRFSuite.dylib (34) <F78B7F5F-0B4F-35C6-AA2F-84EE9CB22137> /usr/lib/libCRFSuite.dylib
          0x7fffdd996000 -     0x7fffdd9a1fff  libChineseTokenizer.dylib (21) <0886E908-A825-36AF-B94B-2361FD8BC2A1> /usr/lib/libChineseTokenizer.dylib
          0x7fffdda33000 -     0x7fffdda34ff3  libDiagnosticMessagesClient.dylib (102) <84A04D24-0E60-3810-A8C0-90A65E2DF61A> /usr/lib/libDiagnosticMessagesClient.dylib
          0x7fffdda35000 -     0x7fffddc48fff  libFosl_dynamic.dylib (16.39) <E22A4243-D148-3C74-BA15-2D906A3D1F9E> /usr/lib/libFosl_dynamic.dylib
          0x7fffddc64000 -     0x7fffddc6bfff  libMatch.1.dylib (27) <70D4BD2A-9383-37F2-B0D6-9B592D236601> /usr/lib/libMatch.1.dylib
          0x7fffddc6c000 -     0x7fffddc6cfff  libOpenScriptingUtil.dylib (172) <90743888-C1E8-34E3-924E-1A754B2B63B9> /usr/lib/libOpenScriptingUtil.dylib
          0x7fffddc6d000 -     0x7fffddc71ffb  libScreenReader.dylib (477.40.6) <CBE6420C-EF60-3ACD-A0B6-7CBE936BA3B8> /usr/lib/libScreenReader.dylib
          0x7fffddc72000 -     0x7fffddc73ffb  libSystem.B.dylib (1238.60.2) <F18AC1E7-C6F1-34B1-8069-BE571B3231D4> /usr/lib/libSystem.B.dylib
          0x7fffddcdf000 -     0x7fffddd0aff3  libarchive.2.dylib (41.70.1) <A3FA7D6E-3D68-3524-8B48-EB2ECA44B13B> /usr/lib/libarchive.2.dylib
          0x7fffddd0b000 -     0x7fffddd87fc7  libate.dylib (1.12.13) <D0767875-D02E-3377-84D8-5F174C27BEA9> /usr/lib/libate.dylib
          0x7fffddd8b000 -     0x7fffddd8bff3  libauto.dylib (187) <34388D0B-C539-3C1B-9408-2BC152162E43> /usr/lib/libauto.dylib
          0x7fffddd8c000 -     0x7fffddd9cff3  libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
          0x7fffddd9d000 -     0x7fffdddabff7  libbz2.1.0.dylib (38) <ADFA329A-DCE7-356D-8F09-A3168DFC6610> /usr/lib/libbz2.1.0.dylib
          0x7fffdddac000 -     0x7fffdde02ff7  libc++.1.dylib (307.5) <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C> /usr/lib/libc++.1.dylib
          0x7fffdde03000 -     0x7fffdde2cff7  libc++abi.dylib (307.4) <BC271AD3-831B-362A-9DA7-E8C51F285FE4> /usr/lib/libc++abi.dylib
          0x7fffdde2d000 -     0x7fffdde3dffb  libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
          0x7fffdde3e000 -     0x7fffdde54fcf  libcompression.dylib (39) <F2726F95-F54E-3B21-BCB5-F7151DEFDC2F> /usr/lib/libcompression.dylib
          0x7fffdde55000 -     0x7fffdde55ff7  libcoretls.dylib (121.50.4) <64B1001E-10F6-3542-A3B2-C4B49F51817F> /usr/lib/libcoretls.dylib
          0x7fffdde56000 -     0x7fffdde57ff3  libcoretls_cfhelpers.dylib (121.50.4) <1A10303E-5EB0-3C7C-9165-021FCDFD934D> /usr/lib/libcoretls_cfhelpers.dylib
          0x7fffddf11000 -     0x7fffddff6ff7  libcrypto.0.9.8.dylib (64.50.6) <D34E16A7-990A-37A9-933A-DFAA46554EAA> /usr/lib/libcrypto.0.9.8.dylib
          0x7fffde194000 -     0x7fffde1e7ff7  libcups.2.dylib (450) <9950BFCB-7882-33C9-9ECF-CE66773C5657> /usr/lib/libcups.2.dylib
          0x7fffde1e8000 -     0x7fffde23afff  libcurl.4.dylib (95.70.1) <8987EFA8-0BF6-3E2A-8F04-7BD5803B9A37> /usr/lib/libcurl.4.dylib
          0x7fffde23b000 -     0x7fffde242ff3  libdscsym.dylib (148.3) <EF99B991-18D9-3A73-BE88-4DC55F036DEF> /usr/lib/libdscsym.dylib
          0x7fffde264000 -     0x7fffde264fff  libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
          0x7fffde272000 -     0x7fffde273fff  libffi.dylib (18.1) <49D03682-E111-351C-8266-4519B3B82BE9> /usr/lib/libffi.dylib
          0x7fffde274000 -     0x7fffde279ff7  libheimdal-asn1.dylib (498.50.8) <A40E3196-235E-34CE-AD9A-8D1AFC5DE004> /usr/lib/libheimdal-asn1.dylib
          0x7fffde27a000 -     0x7fffde36cff7  libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
          0x7fffde36d000 -     0x7fffde592ffb  libicucore.A.dylib (57166.0.1) <CCD2ED24-3071-383B-925D-8D763BB12A6F> /usr/lib/libicucore.A.dylib
          0x7fffde598000 -     0x7fffde599fff  liblangid.dylib (126) <2085E7A7-9A34-3735-87F4-F174EF8EABF0> /usr/lib/liblangid.dylib
          0x7fffde59a000 -     0x7fffde5b3ffb  liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
          0x7fffde5b4000 -     0x7fffde5caff7  libmarisa.dylib (5) <9030D214-5D0F-30CB-AC03-902C63909362> /usr/lib/libmarisa.dylib
          0x7fffde5cb000 -     0x7fffde873ff7  libmecabra.dylib (744.8) <D429FCC9-42A4-38B3-8784-44024BC859EF> /usr/lib/libmecabra.dylib
          0x7fffde8a6000 -     0x7fffde920ff3  libnetwork.dylib (856.60.1) <191E99F5-4723-3180-8013-02AF2F9AE4B8> /usr/lib/libnetwork.dylib
          0x7fffde921000 -     0x7fffdecf3047  libobjc.A.dylib (709.1) <70614861-0340-32E2-85ED-FE65759CDFFA> /usr/lib/libobjc.A.dylib
          0x7fffdecf6000 -     0x7fffdecfafff  libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib
          0x7fffdecfb000 -     0x7fffded2cfff  libpcap.A.dylib (67.60.1) <F6BC6ED6-AEE4-3520-B248-0C342636E2B0> /usr/lib/libpcap.A.dylib
          0x7fffded49000 -     0x7fffded65ffb  libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
          0x7fffded66000 -     0x7fffded9ffff  libsandbox.1.dylib (592.70.1) <9C428C49-9D9A-3F9F-9573-BF5202D1F933> /usr/lib/libsandbox.1.dylib
          0x7fffdeda0000 -     0x7fffdedb2ffb  libsasl2.2.dylib (209) <32107C59-22C6-3049-B86E-9C2F85FF549B> /usr/lib/libsasl2.2.dylib
          0x7fffdedb3000 -     0x7fffdedb4ff3  libspindump.dylib (231.3) <C7CEEB64-06F4-3ACA-AAC1-30ECA909501A> /usr/lib/libspindump.dylib
          0x7fffdedb5000 -     0x7fffdef03ff7  libsqlite3.dylib (254.8) <1ECF7DF7-7A07-3B4B-A63B-F4EFF6BC7ACF> /usr/lib/libsqlite3.dylib
          0x7fffdef5f000 -     0x7fffdefaffff  libstdc++.6.dylib (104.1) <A980E08C-A511-3D19-9881-1D79B7CFF2BA> /usr/lib/libstdc++.6.dylib
          0x7fffdeff8000 -     0x7fffdf005fff  libxar.1.dylib (357) <69547C64-E811-326F-BBED-490C6361BDCB> /usr/lib/libxar.1.dylib
          0x7fffdf006000 -     0x7fffdf0f5fff  libxml2.2.dylib (30.17) <D4C3E467-37C6-34DE-8A1B-E7BFC29985E9> /usr/lib/libxml2.2.dylib
          0x7fffdf0f6000 -     0x7fffdf11ffff  libxslt.1.dylib (15.9) <00735AD5-B62D-3E83-86AC-5533E4E2B102> /usr/lib/libxslt.1.dylib
          0x7fffdf120000 -     0x7fffdf131ff3  libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
          0x7fffdf140000 -     0x7fffdf144ff7  libcache.dylib (79) <093A4DAB-8385-3D47-A350-E20CB7CCF7BF> /usr/lib/system/libcache.dylib
          0x7fffdf145000 -     0x7fffdf14ffff  libcommonCrypto.dylib (60092.50.5) <8A64D1B0-C70E-385C-92F0-E669079FDA90> /usr/lib/system/libcommonCrypto.dylib
          0x7fffdf150000 -     0x7fffdf157fff  libcompiler_rt.dylib (62) <55D47421-772A-32AB-B529-1A46C2F43B4D> /usr/lib/system/libcompiler_rt.dylib
          0x7fffdf158000 -     0x7fffdf160fff  libcopyfile.dylib (138) <819BEA3C-DF11-3E3D-A1A1-5A51C5BF1961> /usr/lib/system/libcopyfile.dylib
          0x7fffdf161000 -     0x7fffdf1e4fdf  libcorecrypto.dylib (442.50.19) <65D7165E-2E71-335D-A2D6-33F78E2DF0C1> /usr/lib/system/libcorecrypto.dylib
          0x7fffdf1e5000 -     0x7fffdf216fff  libdispatch.dylib (703.50.37) <6582BAD6-ED27-3B30-B620-90B1C5A4AE3C> /usr/lib/system/libdispatch.dylib
          0x7fffdf217000 -     0x7fffdf21cffb  libdyld.dylib (433.5) <9B2AC56D-107C-3541-A127-9094A751F2C9> /usr/lib/system/libdyld.dylib
          0x7fffdf21d000 -     0x7fffdf21dffb  libkeymgr.dylib (28) <7AA011A9-DC21-3488-BF73-3B5B14D1FDD6> /usr/lib/system/libkeymgr.dylib
          0x7fffdf21e000 -     0x7fffdf22afff  libkxld.dylib (3789.70.16) <BD02EF3F-6E09-3A64-AB21-553D5B1D2859> /usr/lib/system/libkxld.dylib
          0x7fffdf22b000 -     0x7fffdf22bfff  liblaunch.dylib (972.70.1) <B856ABD2-896E-3DE0-B2C8-146A6AF8E2A7> /usr/lib/system/liblaunch.dylib
          0x7fffdf22c000 -     0x7fffdf231ff3  libmacho.dylib (898) <17D5D855-F6C3-3B04-B680-E9BF02EF8AED> /usr/lib/system/libmacho.dylib
          0x7fffdf232000 -     0x7fffdf234ff3  libquarantine.dylib (85.50.1) <12448CC2-378E-35F3-BE33-9DC395A5B970> /usr/lib/system/libquarantine.dylib
          0x7fffdf235000 -     0x7fffdf236ffb  libremovefile.dylib (45) <38D4CB9C-10CD-30D3-8B7B-A515EC75FE85> /usr/lib/system/libremovefile.dylib
          0x7fffdf237000 -     0x7fffdf24fff7  libsystem_asl.dylib (349.50.5) <096E4228-3B7C-30A6-8B13-EC909A64499A> /usr/lib/system/libsystem_asl.dylib
          0x7fffdf250000 -     0x7fffdf250ff7  libsystem_blocks.dylib (67) <10DC5404-73AB-35B3-A277-A8AFECB476EB> /usr/lib/system/libsystem_blocks.dylib
          0x7fffdf251000 -     0x7fffdf2defef  libsystem_c.dylib (1158.50.2) <E5AE5244-7D0C-36AC-8BB6-C7AE7EA52A4B> /usr/lib/system/libsystem_c.dylib
          0x7fffdf2df000 -     0x7fffdf2e2ffb  libsystem_configuration.dylib (888.60.2) <BECC01A2-CA8D-31E6-BCDF-D452965FA976> /usr/lib/system/libsystem_configuration.dylib
          0x7fffdf2e3000 -     0x7fffdf2e6fff  libsystem_coreservices.dylib (41.4) <7D26DE79-B424-3450-85E1-F7FAB32714AB> /usr/lib/system/libsystem_coreservices.dylib
          0x7fffdf2e7000 -     0x7fffdf2fffff  libsystem_coretls.dylib (121.50.4) <EC6FCF07-DCFB-3A03-9CC9-6DD3709974C6> /usr/lib/system/libsystem_coretls.dylib
          0x7fffdf300000 -     0x7fffdf306fff  libsystem_dnssd.dylib (765.50.9) <CC960215-0B1B-3822-A13A-3DDE96FA796F> /usr/lib/system/libsystem_dnssd.dylib
          0x7fffdf307000 -     0x7fffdf330ff7  libsystem_info.dylib (503.50.4) <611DB84C-BF70-3F92-8702-B9F28A900920> /usr/lib/system/libsystem_info.dylib
          0x7fffdf331000 -     0x7fffdf353ff7  libsystem_kernel.dylib (3789.70.16) <34B1F16C-BC9C-3C5F-9045-0CAE91CB5914> /usr/lib/system/libsystem_kernel.dylib
          0x7fffdf354000 -     0x7fffdf39bfe7  libsystem_m.dylib (3121.6) <86D499B5-BBDC-3D3B-8A4E-97AE8E6672A4> /usr/lib/system/libsystem_m.dylib
          0x7fffdf39c000 -     0x7fffdf3baff7  libsystem_malloc.dylib (116.50.8) <A3D15F17-99A6-3367-8C7E-4280E8619C95> /usr/lib/system/libsystem_malloc.dylib
          0x7fffdf3bb000 -     0x7fffdf414ffb  libsystem_network.dylib (856.60.1) <369D0221-56CA-3C3E-9EDE-94B41CAE77B7> /usr/lib/system/libsystem_network.dylib
          0x7fffdf415000 -     0x7fffdf41eff3  libsystem_networkextension.dylib (563.60.2) <B021F2B3-8A75-3633-ABB0-FC012B8E9B0C> /usr/lib/system/libsystem_networkextension.dylib
          0x7fffdf41f000 -     0x7fffdf428ff3  libsystem_notify.dylib (165.20.1) <B8160190-A069-3B3A-BDF6-2AA408221FAE> /usr/lib/system/libsystem_notify.dylib
          0x7fffdf429000 -     0x7fffdf431fe7  libsystem_platform.dylib (126.50.8) <897462FD-B318-321B-A554-E61982630F7E> /usr/lib/system/libsystem_platform.dylib
          0x7fffdf432000 -     0x7fffdf43cff7  libsystem_pthread.dylib (218.60.3) <B8FB5E20-3295-39E2-B5EB-B464D1D4B104> /usr/lib/system/libsystem_pthread.dylib
          0x7fffdf43d000 -     0x7fffdf440ff7  libsystem_sandbox.dylib (592.70.1) <4B92EC49-ACD0-36AE-B07A-A2B8152EAF9D> /usr/lib/system/libsystem_sandbox.dylib
          0x7fffdf441000 -     0x7fffdf442ff3  libsystem_secinit.dylib (24.50.4) <F78B847B-3565-3E4B-98A6-F7AD40392E2D> /usr/lib/system/libsystem_secinit.dylib
          0x7fffdf443000 -     0x7fffdf44affb  libsystem_symptoms.dylib (532.50.47) <3390E07C-C1CE-348F-ADBD-2C5440B45EAA> /usr/lib/system/libsystem_symptoms.dylib
          0x7fffdf44b000 -     0x7fffdf45eff7  libsystem_trace.dylib (518.70.1) <AC63A7FE-50D9-3A30-96E6-F6B7FF16E465> /usr/lib/system/libsystem_trace.dylib
          0x7fffdf45f000 -     0x7fffdf464ffb  libunwind.dylib (35.3) <3D50D8A8-C460-334D-A519-2DA841102C6B> /usr/lib/system/libunwind.dylib
          0x7fffdf465000 -     0x7fffdf48eff7  libxpc.dylib (972.70.1) <BF896DF0-D8E9-31A8-A4B3-01120BFEEE52> /usr/lib/system/libxpc.dylib
      External Modification Summary:
        Calls made by other processes targeting this process:
          task_for_pid: 1
          thread_create: 0
          thread_set_state: 0
        Calls made by this process:
          task_for_pid: 0
          thread_create: 0
          thread_set_state: 0
        Calls made by all processes on this machine:
          task_for_pid: 1064
          thread_create: 0
          thread_set_state: 0
      VM Region Summary:
      ReadOnly portion of Libraries: Total=735.8M resident=0K(0%) swapped_out_or_unallocated=735.8M(100%)
      Writable regions: Total=880.1M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=880.1M(100%)
                                      VIRTUAL   REGION
      REGION TYPE                        SIZE    COUNT (non-coalesced)
      ATS (font support)                31.9M        5
      ATS (font support) (reserved)        8K        3         reserved VM address space (unallocated)
      Accelerate framework               128K        2
      Activity Tracing                   256K        2
      CG backing stores                 30.7M       11
      CG image                            24K        6
      CG raster data                     240K        2
      CoreAnimation                       56K        6
      CoreUI image data                  864K        9
      CoreUI image file                  184K        4
      Foundation                           4K        2
      Image IO                           968K      113
      Kernel Alloc Once                    8K        2
      MALLOC                           292.4M       67
      MALLOC guard page                   48K       11
      Memory Tag 242                      12K        2
      Memory Tag 251                      12K        2
      STACK GUARD                       56.2M       41
      Stack                            480.4M       52
      VM_ALLOCATE                       18.0M       39
      __DATA                            63.7M      380
      __GLSLBUILTINS                    2588K        2
      __IMAGE                            528K        2
      __LINKEDIT                       279.0M       77
      __TEXT                           456.8M      353
      __UNICODE                          556K        2
      mapped file                      725.3M      180
      shared memory                     16.4M       17
      TOTAL                              2.4G     1366
      TOTAL, minus reserved VM space     2.4G     1366
